06 de Abril de 2026, 01:22 *
Autor Tema: Muramasa Phantomix v1.0  (Leído 40 veces)
« : 07 de Septiembre de 2025, 12:29 »
Free Download Muramasa Phantomix v1.0 | 13.5 Mb
Don't Just Compress. Create. In a world where every sonic nuance matters, why let anything go to waste? Phantomix redefines audio processing by embracing the philosophy that nothing should be discarded, only transformed. Our revolutionary approach takes what conventional compressors strip away - the subtle dynamics, the vibrant transients - and masterfully recycles these elements, feeding them into a powerful suite of effects to craft something truly extraordinary and impactful.
Phantomix Key Features
The Revolutionary Dynamic Splitter
Phantomix's unique Dynamic Splitter isolates the dynamic nuances typically compressed out of the original signal, routing these "removed" elements directly into the powerful effects section. In a way, it lets you process only the prominent or the subtle parts of your audio material and leave the other intact.
Reverb & delay that doesn't clutter
Adding just the right amount of reverb, that would give the atmosphere, but wouldn't clutter the mix, is usually virtually impossible. Well, was. By sending only prominent parts of your signal to the reverb, you get the atmosphere, but you still keep the signal clean. By sending the subtle parts of the signal instead, you can fill the voids in your audio without drowning the transients in reverb. And the same thing is true with a delay.
Getting some smack without murdering your audio
We all a bit of saturation, distortion or limiting, but it's a slippery road - too much makes everything horrible. So, how about not drowning everything in some sort of distortion and giving the mojo only to the prominent parts? Phantomix lets you easily give some smack to the transients, but leaves the rest intact, making things sound rich but not distorted.
Processing dynamics of a dynamically processed audio?
What on earth could that be for? Turns out there's a load of gems hidden here. Say you have a percussive instrument, drums, for instance, and the levels vary. Sure, you can compress the hell out of it, but doing that cleanly is quite a challenge. So, how about compressing just the transients - the prominent parts of the signal? That's Phantomix's Compressor module. Or if the transients are not prominent enough, use the Transient module. Or maybe the subtle hits need to be more prominent, so you just switch the Phantomix to gate mode. The possibilities are endless...
Modulation Suite
Dive into a world of sonic movement with Phantomix's comprehensive Modulation module, featuring Chorus, Flanger, Phaser, and Tremolo effects. From lush, swirling textures and dramatic jet-like sweeps to psychedelic phase shifts and rhythmic amplitude variations, this suite provides everything you need to add unique character, width, and motion to your tracks. But only the prominent or the subtle parts! You don't want to drown everything in flanger, right?
Precision EQ & Filters
Sometimes you just have a signal, that's messy, ringy, just something isn't right. So you EQ it and you find that it has lost all the character and is, well, dead now. Phantomix's solution is simple - only process a part of it, the prominent or the subtle one. All that ugly stuff you have there may be exactly what you need, just without making your ears hurt.
Realistic 3D yet flexible GUI
The photorealistic graphic user interface of the plugin gives you the feeling you are touching the real hardware. But it easily adapts to your needs. You can always drag the arrow in the bottom right corner to change its size - make it smaller to save valuable screen space, or enlarge it to make it easier to use.
FREE 15-Day unlimited trial
All the descriptions are nothing compared to putting your hands on the plugin. No saving limits. No noises. No boundaries. Engage the plugin in your project for real and fully exploit its powers for two weeks.
64-bit audio quality at ANY sampling rate
The plugin provides the maximum audio quality you can get. It uses internal 64-bit audio processing and can handle any sampling rate. 192 kHz or even higher.
Smart bypass
The intelligent way our plugins manage bypassing ensures that you don't get any clicks or harmful noises when automating the parameter. It also compensates for latency, ensuring that the bypass states are perfectly in sync with each other.
Intelligent sleep on silence
This plugin intelligently detects whether it makes sense to perform processing at all. If not, it temporarily turns on sleep mode. In such a state, it requires virtually no CPU at all to save the computing sources for other processes.
https://unitedplugins.com/Phantomix/
Uploady
y9hcz.Muramasa.Phantomix.v1.0.rar
y9hcz.Muramasa.Phantomix.v1.0.rar.html
