05 de Abril de 2026, 01:43 *
Autor Tema: VoosteQ Material Comp & Model N Channel Bundle v2025.9  (Leído 51 veces)
« : 08 de Septiembre de 2025, 02:43 »
Free Download VoosteQ Material Comp & Model N Channel Bundle v2025.9 | 68.8 Mb
A cutting-edge compressor that is equipped with "DFP" a technology that VoosteQ spent 3 years developing to thoroughly reproduce the nuances of an analog circuit. Mastering grade signal processing technology can be achieved with an extremely low CPU load. The internal processing is fully 64 bit and produces sounds with unbelievable transparency.
6 analog model compressors
"Modern", "60's FET", "Luxe VCA", "Studio Master", "OPTO", "TUBE".
6 saturation models of high-end analog preamps
This is used to generate skillfully designed analog preamp drive sounds, rather than strong distortion.
8 flavors that reproduce sounds from analog circuits
It thoroughly analyzes the ambiance, frequency, changes to the sound phases,
and other elements made when actually passing through the circuit of hardware and reproduces them.
It produces a completely analog sounds that cannot be reproduced using EQ.
4 original glues developed by VoosteQ that bring together all sounds
It is extremely effective, such as when blending further after adjusting the compressor.
It also has an effect on acoustic guitar and vocals, in addition to mix buss.
"Special Section"
The 3 features of the "Special Section" make the sounds of the Material Compressor even more appealing.
It is equipped with "Punch," which produces a more offensive attack to enhance the features of the sounds,
"Groove," which adds a groove that undulates in real time with the entry signals,
and "Imager," which expands in stereo using techniques used at mastering studios.
Model N Channel
This plug-in models British-made preamps, compressors, equalizers, and transmitters.
It models multiple actual units, including vintage units, recent units, and modified units, and can be used in combination with them.
Model N Channel is not just modeling the sound of the original preamp, comp, and EQ alone.
It features modeling of the sound qualities and tones routed in large recording studios, including sounds through British consoles, cables, bantam patch bays, and even AD/DA, which can add a strong analog texture.
Preamp Section
Modeling of vintage 70's units to recently released units.
Compressor Section
This is a feedback type compressor modeled after two vintage British 70's units. THD, frequency response, etc. change organically and automatically according to the input signal and the amount of reduction.
Equalizer Section
This is a modeling of three equalizers, including vintage 70's units to recently released units. Not only the frequency response of each EQ, but also the distortion and texture are modeled.
Analog Flavor
Switches between sounds that simulate transformers and analog circuits. In addition to frequency response, it also simulates a comped feel and texture.
Included:
Material Comp: v1.7.11
Model N Channel: v1.0.5
https://www.voosteq.com/
Uploady
j1tet.VoosteQ.Material.Comp..Model.N.Channel.Bundle.v2025.9.rar
http://peeplink.in/f56d6269f966
j1tet.VoosteQ.Material.Comp..Model.N.Channel.Bundle.v2025.9.rar.html
