06 de Abril de 2026, 00:24 *
Autor Tema: ECam Pro 5.0.432 Multilingual  (Leído 37 veces)
Conectado Conectado
« : 09 de Septiembre de 2025, 11:59 »
Free Download ECam Pro 5.0.432 Multilingual Fast Links | 199.8 Mb
Ecam is designed to speed up the g-code generation for simple part. In short, if most of your production consist in simple component , and you feel common cad/cam are an overkill for your jobs , give a try to ecam , probably it will fit your needs.
How Ecam is different?
ECam combines features of CAD/CAM system with typical features of conversational programming.
3D Stock modelling
The 3D rappresentation is the effective result of all toolpath movements applied to the stock model.
Fast Shapes
Is possible define the most common and recurrent geometry profile by just insert some parameters.
Create slot, slot d on circle, text , regular polygons and much more without touching any cad tool.
Timeline
The purpose of TIMELINE feature is too see at glance , what operations are taking most of the machining time.
Every operation has a different colour , if you hover it with mouse cursor you can see the related operation in the viewport.
Setup Sheet
Create documentation for the shop floor with a click.
Containing all the information to setup the cnc machine . The setup sheet is an html file, so you can view it through your internal company LAN.
BackDescriptionting
Understand better the generated toolpath with a tool animation.
You can control the animation speed . It shows the current position and the current values of feed and speed.
Integrated cut simulation
Check tool rapid collision and see the effective result of the tool movements on the stock.
View Cube
Use View Cube and other available methods to change camera position .
If needed, toggle the section and trasparency mode for better visualization of 3D model.
Cad file import
Import existing 2D geometry from cad file ( DXF and DWG file format)
Home Page-http://www.e-cam.it
kisz6.ECam.Pro.5.0.432.Multilingual.7z.html
