05 de Abril de 2026, 05:42 *
Autor Tema: Hexagon Vero Edgecam 2025.1 Build 2535 Win x64 English  (Leído 73 veces)
« : 10 de Septiembre de 2025, 10:19 »
Free Download Hexagon Vero Edgecam 2025.1 Build 2535 Win x64 English  | 7.0 Gb
Download Hexagon Vero Edgecam 2025.1 Build 2535 Win x64 English - powerful CAD/CAM software for CNC milling, turning, and machining, delivering efficient programming and high-quality results
Vero Software, a part of Hexagonhas releasedEdgeCAM 2025.1 (2535) is a market-leading computer aided manufacturing (CAM) system for NC part programming.
Owner:Hexagon
Product Name:EdgeCAM
Version:2025.1 Build 2535
Supported Architectures:x64
Website Home Page :www.edgecam.com
Languages Supported:english
System Requirements:Windows *
What's new in EDGECAM version 2025.1
Built to Get CNC Programming Done Faster
Released with a powerful set of enhancements designed to accelerate productivity, optimize machining processes, and deliver an even more intuitive programming experience. From Wire EDM to 2-axis turning, 3-axis milling, and all the way to 6-axis machining, EDGECAM 2025.1 delivers enhancements across the board to speed up your workflow and boost shop-floor efficiency.
Top Highlights - EDGECAM 2025.1
-Smarter Automation:upgraded Technology Assistant and PCI-driven Five-Axis strategies boost repeatability and speed.
-Enhanced Simulation:Advanced, mesh-based comparison delivers more visual and precise verification of toolpaths.
-Race Line Finishing Cycle:A new intelligent milling cycle that automatically finds the fastest path across complex profiles to reduce cycle time.
-Stronger Security:Your database runs on Microsoft SQL Server 2022 with TLS 1.3 support for faster, more secure operations.
-Cloud Connectivity:NEXUS 3D Whiteboard for real-time sharing of parts, tooling, and setups.
Enhanced Automation
Users will have greater control when automatically determining cutting data thanks to EDGCAM 2025.1 enhancing not only its 'Technology Types' but also adding turning data to its 'Depth of Cut' algorithm. The overall effect will be greater control when using the Technology Assistant.
EDGECAM 2025. 1 delivers a better user experience for customers working with multiple components by enhancing Fixture and Stock identification. Extended names are now easily identified through various display windows and the data is accessible to the code generator and macro scripts.
Cloud Connectivity
Nexus Apps:EDGECAM is now cloud-connected, allowing users to share projects and collaborate using the NEXUS platform. The 3D whiteboard feature enables users to share complete machine setups and collaborate on design reviews, either on the actual part or on the fixture on the tooling design.
Close
Turning Enhancements
-    B-Axis Contour Cycle Support: Mill-Turn users with 5-axis head-table rotary machines can now program and simulate B-axis turning toolpaths, unlocking more flexibility and efficiency.
-    Advanced Turning Enhancements: Turning automation is boosted by smarter Depth of Cut logic, enhancing precision and control in complex parts.
Close
Milling Enhancements
-Race Line Finishing Cycle:A new high-speed toolpath designed for machining complex profiles such as gearbox sealing faces and precision castings. Includes automatic fixture detection and stock sensitivity.
Close
-Parallel Lace Cycle:New "Point Distribution" control allows for finer toolpath resolution, improving surface finish and NC code quality.
-Rough Milling - Prioritise Additional Cuts:Ensures gouge-free toolpaths for complex multi-region components by optimizing cutting order dynamically.
-Profiling Enhancements:Extended helical support improves surface finish and reduces cycle time on undercut components.
Close
Guides, Toolstore & Simulation
-Improved Fixture and Stock Recognition:Better naming conventions and display help streamline multi-component setups and make data more accessible to post-processors and macros.
-ToolStore Security Upgrade:Upgraded to SQL Server 2022 with support for TLS 1.3, ideal for projects requiring high data protection
Close
-Simulation Enhancements:The new mesh-based comparison in the simulator allows interactive analysis for a more visual and dynamic validation process.
Five Axis Perfection
-Automatic Lead Type:Removes guesswork when defining entry and exit strategies, making 5-axis programming more efficient.
Close
-Flowline Strategy:Adds greater control and smoother finishes on individual component faces.
- Multiaxis Enhancements:
.    Avoid Small Profile Ramp: Better ramp diameter control.
.    Trim Line Ramps: Dynamic toolpath adjustment based on stock.
.    Fade Lead In/Out: New option for smoother transitions.
.    Floor Parallel Pattern: Improved surface quality for wall finishing.
EDGECAM 2025.1.2535 Maintenance Report
ECAM-69747 Solid Machinist for Creo - Support Creo 11 (via Solidlink) Implemented in Solidlink 2024.3 onwards (Fixed)
ECAM-71374 Language - Mapping missing strings in Properties window for language translations (It is now possible to translate the header of the properties window for stock and fixture.)
ECAM-42148 Profiling - CRC deactivated when using Spring Cuts and Use Subroutines (Fixed. To ensure correct, NC Subroutines are automatically disabled if CRC and Spring cuts are in use. This is not currently supported.)
ECAM-46275 Feature Finder - Hole Feature Thread found full length due to counterbore on reverse (Fixed)
ECAM-46935 Roughing - Current Stock - Detect Flat Land causes flat areas above level to be machined (Fixed)
ECAM-58001 Profile cycle - Generate wrong toolpath and gouge the part (Fixed)
ECAM-62555 Profiling Cycle - Wrong lead move due to Geometry compensation (Fixed)
ECAM-66402 Profiling Cycle - Start/End Preference change due to Regenerate Sequence (Fixed)
ECAM-69512 Roughing - Undercut Stock option load incorrect stock values after Index (Fixed)
ECAM-70559 Roughing Cycle - Collision between shank and stock not avoided (Fixed)
ECAM-71344 Feature Find - Face Turn feature is broken (Fixed)
ECAM-71357 Technology Assistant - Cutting data not applied when Depth of Cut is less than 1mm (Fixed. Can now use up to 15 decimal places in cut depth)
ECAM-71359 Language - Strategy Manager - AND and OR conditionals not working in other languages (Fixed. It's now possible to use conditional operators in Strategy Manager decision node while in a language other than English.)
ECAM-71484 Profiling cycle - Wrong links with CRC Geometry compensation causes a collision (Fixed)
ECAM-71596 Code Wizard - Ship the template.txt generated in build process (Implemented)
EdgeCAM, a market leading Computer-Aided Manufacturing (CAM) system for NC part programming, offers a complete solution for milling, turning and mill/turn programming with unparalleled ease of use and sophisticated toolpath generation. Edgecam dramatically simplifies programming for all machining applications from production milling and tool making to mill/turn multi-task machining. With a range of 2 through 6-Axis milling cycles and full turning capability, it combines seamlessly with CAD integration and sophisticated automation tools.
EDGECAM 2025 1 what's new webinar
Catch up on this webinar to discover how to get the most out of the new release, including demonstrations on the main features:
- Machine Simulator - improved View Comparison due to Mesh-based technology
- New Race Line Finishing Cycle - Ideal for face milling engine block or gearbox seal faces
- Parallel Lace Cycle - New "Point Distribution" promoting improved surface accuracy
- Roughing Cycle - New "Prioritise Additional Cuts" modifier
- B Axis Contour Cycle support in Mill Turn Machine configurations.
- Parting Off Cycle - greater accuracy with new Compensation support
- Profiling Cycle - helical machining support for undercut profiles
- Face Mill Cycle - Cycle time reduction with new "Optimise Lace Layer Start" option
- Five Axis Cycle - multiple enhancements including new Lead Types and Strategies
- Advanced Five Axis Cycle - Improved Rotary Machining and Multiaxis functions
- Technology Assistant - Enhanced data information and new Turning "Depth of Cut"
- Fixture and Stock Names improvements
- Nexus Apps: EDGECAM is now cloud-connected though the NEXUS platform
Hexagonis a leading global provider of design, measurement and visualisation technologies. Hexagon has more than 14,000 employees in over 40 countries and net sales of about 2,400 MEUR. Our products are used in a broad range of industries including surveying, power and energy, aerospace and defence, construction, safety and security, automotive and manufacturing.Vero Software, a part of Hexagon Manufacturing Intelligence's Production Software business. Hexagon acquired Vero Software, a specialist in CAD/CAM software, in 2014 and has continued to expand and diversify its offering.
HexagonVeroEdgecam202512535.html
6ohak.Hexagon-Vero-Edgecam-2025-1-2535.part1.rar.html
6ohak.Hexagon-Vero-Edgecam-2025-1-2535.part2.rar.html
6ohak.Hexagon-Vero-Edgecam-2025-1-2535.part3.rar.html
