05 de Abril de 2026, 23:48 *
Autor Tema: Construction Calc Pro v6.99  (Leído 34 veces)
« : 11 de Septiembre de 2025, 16:54 »
Free Download Construction Calc Pro v6.99 | Android | 14.5 MB
Paid version
Save money by quickly estimating materials. Save time by calculating angles, measurements and quantities. The ideal handy pocket calculator for anyone in the construction industry. 83 Powerful, Proven & Precise Estimators & Calculators in one app. Enter measurements for the calculators in feet/inches or metric.
Aggregate
- Inputs: Width, Length, Thickness, Density, Wastage
- Outputs: Estimate Weight, Volume
Asphalt
Balusters
- Inputs: Run length, Baluster width, Baluster spacing
- Outputs: Qty of balusters, Qty spaces, Baluster spacing (center-to-center), Baluster spacing (edge-to-edge), Measurements to far side of each baluster
Board / lineal foot
- Inputs: Thickness, Width, Length, Quantity
- Outputs: Board feet, Lineal feet
Concrete - rectangle
- Inputs: Width, Length, Thickness, Use rebar option, Rebar spacing along width, Rebar spacing along length
- Outputs: Estimate Volume, 60lb premixed bags, 80lb premixed bags, 10kg premixed bags, 25kg premixed bags, 50kg premixed bags, Rebar required
Crown moulding
- Inputs: Wall angle (corner of wall), Crown (spring) angle
- Outputs: Miter angle, Bevel angle
Drop ceiling
- Inputs: Length at ceiling, Width at ceiling, Tile , Distance (anchor to drop ceiling)
- Outputs: Estimate Ceiling area, Ceiling tiles, Perimeter moulding, Main supports, Tee support peices, Wire length (each), Wire length (total), Wire anchors
Drywall
- Inputs: Room width, Room length, Room height, Panel width, Panel height, Include ceiling option
- Outputs: Estimate Area - surface area. Materials - Drywall panels. Joint compounds - Readymixed, Lightweight readymixed, Setting-type, Lightweight setting-type. Fastener - Drywall nails, Drywall screws. Additional items: Joint tape, Primer, Adhesive
Flooring
- Inputs: Width, Length, Wastage, Square Ft or M per box
- Outputs: Total area, Boxes needed
Insulation
- Inputs: Total area width, Total area length, Batt/roll width, Batt/roll length
- Outputs: Batts/rolls required, Total area
Linear cost estimator
- Inputs: Single panel length, Qty of panels, Cost per linear foot, Cost per linear meter
- Outputs: Total cost, Total length
Paint
- Inputs: Wall length, Wall height, Number of coats, Surface type
- Outputs: Estimate Gallons required, Liters required
Rafter
- Inputs: Run, Pitch (/12")
- Outputs: Rafter length
Rise/run/angle
- Inputs: Rise, Run, Angle (Enter rise and either run or angle)
- Outputs: Angle, slope, Run
Roofing
- Inputs: Width, Length, Pitch, Sq ft or M per pack, Type, Nails, Safety margin
- Outputs: Roof surface area, Packs needed, Nails
SQ cost estimator
- Inputs: Width, Length, Cost per Sq ft or M
- Outputs: Total cost, Total area, Total area (acres)
Squaring (3-4-5)
- Outputs: Diagonal
Stairs
- Inputs: Total rise, Custom rise, Custom run
- Outputs: Riser height, Total risers, Tread run, Total treads, Total run, Stringer board length, Elevation, Running stringer points
Requirements: Android 7.0+
https://play.google.com/store/apps/details?id=com.lightraystudio.constructioncalc&hl=en
jg8pq.Construction.Calc.Pro.v6.99.apk.html
