06 de Abril de 2026, 02:09 *
Autor Tema: AOMEI Partition Assistant Professional Edition 10.9.0 Multilingual Portable  (Leído 120 veces)
« : 12 de Septiembre de 2025, 19:31 »
Free Download AOMEI Partition Assistant Professional Edition 10.9.0 Multilingual Portable Fast Links | 80.9 Mb
AOMEI Partition Assistant is a highly-efficient, easy-to-use and multifunction partition management software, with user friendly operations to assist you mange the partitions of your hard drives. Under the help of Partition Assistant, you can easily & fast create/delete and merge/split the partition and the most advantage is that it resize/move your partition to readjust the partition volume on the basis that it ensures the security of your data.
AOMEI Partition Assistant Professional Edition is reliable and professional disk partition software for computer. It provides you with the most popular disk partition technology which snap-in Basic Disk Partition Manager, Convert dynamic disk to basic and Dynmiac Disk Partition Manager. This professional tool could help you manage Primary partition, Logical Partition, Simple, Spanned, Striped(Raid0), Mirrored(Raid) and RAID-5 volume.
Main Capabilities:
Extend/Shrink partition
Resize/Move partition
Merge/Split partition
Allocate Free Space
Copy disk/partition
Create/delete/format partition
Set partition label
Wipe partition/wipe hard drive
Rebuild MBR
Convert to GPT/MBR disk
Disk surface test
View properties of partition and disk
Advanced Capabilities:
Change and Remove drive letter
Hide and Unhide drive
Convert Logical to Primary or contrary
Set drive as active
Convert FAT/FAT32 to NTFS
Check partition
Wipe unallocated space
Change partition type
Change serial number
Partition Alignment
Disk & Partition Wizard:
Extend Partition Wizard
Disk Copy Wizard
Partition Copy Wizard
Migrate OS to SSD or HDD
Partition Recovery Wizard
Create Bootable CD Wizard
Operating System:
Windows 11/10/8.1/8/7/Vista/XP
Windows Server 2022
Windows Server 2019
Windows Server 2016
Windows Server 2012 and 2012 R2
Windows Server 2008 and 2008 R2
Windows Server 2003 and 2003 R2
Windows SBS 2003, 2008, 2011
https://www.diskpart.com/
hjs4r.AOMEI.Partition.Assistant.Professional.Edition.10.9.0.Multilingual.Portable.rar.html
