05 de Abril de 2026, 23:03 *
Autor Tema: Ashampoo UnInstaller 16.00.02 Multilingual + Portable  (Leído 56 veces)
« : 12 de Septiembre de 2025, 19:32 »
Free Download Ashampoo UnInstaller 16.00.02 Multilingual + Portable Fast Links | 45.8/44.1 Mb
With Ashampoo UnInstaller 16, you can install, test, and remove programs without leaving a trace-giving you full control over what stays on your PC! The software thoroughly monitors and logs every installation, and a logged installation is the ideal method for a complete, clean uninstallation. If no logs are available e.g., with older programs, the forensic analysis can still detect and record all relevant changes after the fact.
Even programs without installation logs are carefully removed using the five-stage uninstall procedure with deep cleaning! You can also remove unwanted add-ons and toolbars with a single click. In addition, the snapshot feature tracks and shows every modification made to your system between two points in time.
Removes unwanted programs without a trace!
Ashampoo UnInstaller 16 provides a comprehensive solution for all your uninstallation needs in one robust software package. With its forensic analysis capabilities, you can remove even older supported programs without leaving any traces, regardless of whether their installation was monitored. The advanced cleaning modules and the new Registry Optimizer offer noticeable improvements in speed and cleanliness for your PC. Additionally, the software includes powerful tools like the Crash Analyzer, which provides insights into system issues and assists in troubleshooting problems. All these features are integrated into a faster, more stable, and modern version!
Forensic analysis: Create uninstall logs for existing installations
Registry Optimizer 2 with lightning-fast registry cleaning
Super Safe Mode: Extra cautious Registry cleaning for sensitive systems
Crash Analyzer with system-wide crash report analysis
Optimized cleaning modules: Up to 50% faster and more efficient
Greatly accelerated deep cleaning
Export uninstall logs to HTML, CSV, and TXT
Background guard up to 10x faster
Significantly reduced memory and CPU footprint
More reliable and precise detection of installation phases
Better privacy with Privacy Traces Cleaner
Deletion history for all cleaners
Detects even complex installation routines
Also perfect for aging or weaker systems
State-of-the-art cleaner modules
Unified Explorer theme plus hot-tracking
Significantly accelerated snapshot comparisons
Enhanced security and stability
Forensic analysis: Clean removal of existing programs
With forensic analysis, you can now create detailed uninstallation logs for existing programs that were installed without monitoring. This advanced post-install analysis scans all supported software and creates comprehensive logs with just one click. If preferred, you can even process all compatible applications simultaneously. This allows for the thorough removal of older installations, ensuring no traces are left behind.
Precise installation logging can distinguish between different installer types, making it easier to accurately track what software is doing on your system. In most cases, the start and end of an installation are automatically detected and recorded, so you can simply sit back and watch! Installations are also clearly separated from updates, virtually eliminating false detections. And even if a program was installed in the past, the forensic analysis can often retroactively create a complete uninstallation log.
Maximize Registry cleaning speed and flexibility
The new Registry Optimizer 2 offers enhanced and significantly faster Registry cleaning. With modern algorithms, the process is accelerated by up to 100 times compared to previous versions. The module now intelligently identifies and removes related or problematic entries. For added safety, the optional Super Safe Mode ensures sensitive systems are cleaned with extra caution!
Keep system crashes under control with Crash Analyzer
Crash Analyzer gives you clear insights into system crashes and errors that would otherwise remain buried in Windows event logs. The module scans all relevant logs and filters out crash and error reports. Entries are sorted intelligently by frequency and timestamp, while a search field and numerous filter options help you find exactly what you're looking for. All original details from the Windows event log are available for deeper analysis, and you can export results or search for solutions online with a single click.
New technology, enhanced performance, and more!
In addition to the Registry Optimizer, the cleaning modules have been redesigned for 25-50% faster performance. You'll also feel the difference during deep cleaning, where speed and efficiency are unmatched by any other uninstaller! Installation logs can now be exported in HTML, CSV, and TXT formats, making them easy to use in other applications or for further analysis. And in case you're wondering why Ashampoo UnInstaller 16 feels faster, looks smoother, or just works flawlessly: We've made countless improvements under the hood!
More efficient, less resource-hungry
Ashampoo UnInstaller 16 now works even more efficiently! With a significantly reduced memory and CPU footprint, your system runs smoother while you benefit from optimized log creation and processing. Even on older or weaker systems, real-time analysis is now buttery smooth! And the accelerated snapshot comparisons ensure you can instantly track changes between two system save states.
Privacy Traces Cleaner and deletion history
Privacy is our top priority! The new Privacy Traces Cleaner reliably removes all traces of your activities on your PC. The module reliably scans and cleans folders, files, and the Registry-keeping your system private and secure. Additionally, the deletion history built into all cleaners provides a comprehensive overview of all past cleaning operations. This way, you always have an overview and can ensure that nothing unwanted gets deleted or left behind on your PC.
Perfect system integration and enhanced compatibility
Ashampoo UnInstaller 16 is future-proof: Our software now supports new advanced and complex installation methods as well as the latest browser and Windows versions. Benefit from optimized profiles for all popular browsers and extended plug-in support for Microsoft Edge and Google Chrome. You get the latest versions of Internet Cleaner, Registry Optimizer, and Drive Cleaner! The unified user interface with hot-tracking offers smooth and pleasant handling so you can quickly navigate and manage your programs even better.
Five-way uninstall action with new Registry deep cleaning
UnInstaller users know and the multiphasic software removal with in-depth cleaning. UnInstaller 15 takes it one step further! You can now optionally perform in-depth Registry scanning to detect and eliminate even the most deeply nested orphaned entries. What used to be a scan covering the most likely Registry sections a program would have impacted can now be massively extended! Naturally, wide-area scans take a bit longer but you'll be rewarded with a cleaner machine!
Operating System:Windows® 11, Windows® 10, Windows® 8, Windows® 7
https://www.ashampoo.com/
djeql.AshampooUninstallerPortable16.00.02.rar.html
djeql.UnInstaller16.rar.html
