06 de Abril de 2026, 13:24 *
Autor Tema: CSI SAP2000 Ultimate 26.3.0.3220 (x64)  (Leído 46 veces)
« : 14 de Septiembre de 2025, 13:16 »
Free Download CSI SAP2000 Ultimate 26.3.0.3220 (x64) | 990.3 Mb
The SAP name has been synonymous with state-of-the-art analytical methods since its introduction over 30 years ago. SAP2000 follows in the same tradition featuring a very sophisticated, intuitive and versatile user interface powered by an unmatched analysis engine and design tools for engineers working on transportation, industrial, public works, sports, and other facilities.
From its 3D object based graphical modeling environment to the wide variety of analysis and design options completely integrated across one powerful user interface, SAP2000 has proven to be the most integrated, productive and practical general purpose structural program on the market today. This intuitive interface allows you to create structural models rapidly and intuitively without long learning curve delays. Now you can harness the power of SAP2000 for all of your analysis and design tasks, including small day-to-day problems.
Complex Models can be generated and meshed with powerful built in templates. Integrated design code features can automatically generate wind, , bridge, and seismic loads with comprehensive automatic steel and concrete design code checks per US, Canadian and international design standards.
Advanced analytical techniques allow for step-by-step large deformation analysis, Eigen and Ritz analyses based on stiffness of nonlinear cases, catenary cable analysis, material nonlinear analysis with fiber hinges, multi-layered nonlinear shell element, buckling analysis, progressive collapse analysis, energy methods for drift control, velocity-dependent dampers, base isolators, support plasticity and nonlinear segmental construction analysis. Nonlinear analyses can be static and/or time history, with options for FNA nonlinear time history dynamic analysis and direct integration.
From a simple small 2D static frame analysis to a large complex 3D nonlinear dynamic analysis, SAP2000 is the easiest, most productive solution for your structural analysis and design needs.
OS:Microsoft® Windows 7, Microsoft® Windows 8 or Microsoft® Windows 10
CPU:Intel Pentium 4 or AMD Athlon 64 / ntel i5/i7, AMD Athlon X4/Ryzen, or better A 64-bit CPU
Memory:8 GB RAM The problem size that can be solved and the speeds for solution & response recovery increase considerably with more RAM.
Space:6 GB to install the software. Additional space will be required for running and storing model files and analysis results, dependent upon the size of the models / 500GB or larger PCIe Solid State Drive (SSD). External and network drives are not recommended.
Display: Supporting 1024 by 768 resolution and 16 bits colors for standard (GDI+) graphics mode / Discrete video card with NVIDIA GPU or equivalent and dedicated graphics RAM (512 Mb or larger) for DirectX graphics mode. The card must be DirectX 11 Compatible.
https://www.csiamerica.com/
sy8nd.CSI.SAP2000.Ultimate.26.3.0.3220.x64.rar.html
