06 de Abril de 2026, 00:24 *
Autor Tema: Soniccouture Flowstate v1.1.0 KONTAKT  (Leído 41 veces)
Conectado Conectado
« : 14 de Septiembre de 2025, 16:06 »
Free Download Soniccouture Flowstate v1.1.0 KONTAKT | 582.5 Mb
Flowstate will instantly transform any audio clip into a malleable, shifting musical form. Drag and drop your own audio to create morphing textures as you move between 5 different harmonic states. Everything from drum loops to pure noise can be transformed into a living, pitched musical soundscape.
STATE RUNES | FLOW DIAL | WAVE DRAG
The Flowstate main panel is a playground for experimentation, where it doesn't help to know too much. Drag your audio, turn the dial. Click the 5 State runes to hear it morph.
FORMANT BANK | PURITY CONTROL | FORMANT MORPH | SAMPLE SETUP
The Harmonics panel is where you set the formant filters .The eight faders in the centre adjust the level of the 8 harmonics. The horizontal fader between A and B morphs between two diferent setups (as does the FLOW DIAL on the main panel).
ADSR ENVELOPE | LOW PASS FILTER
LFO WITH PHASE OFFSET FOR HARMONIC FORMANTS
A comprehensive set of synthesis parameters for each state. As with harmonics, each parameter morphs its settings from one state to the next.
USER CONFIGURABLE EFFECTS INSERTS
REVERBS, DELAYS, DISTORTION, COMPRESSORS ETC
The FX panel features 3 configurable inserts with 26 different effects to chose from. These FX are NOT part of the separate states and are global.
Built For Your Audio
Soniccouture Flowstate v1.1.0 KONTAKT screenshotFlowstate includes 100 presets + samples.
BUT, it's really built for Drag + Drop.
Take any audio sample you have laying around - a field recording, a breakbeat, a stem of a track - and see what Flowstate can turn it into.
Tune Your World.
Requires free NI Kontakt Player or NI Kontakt FULL v7.10.2 or later!
https://www.soniccouture.com/en/products/g87-flowstate/
http://peeplink.in/7a5aae98dc29
s7tpn.Soniccouture.Flowstate.v1.1.0.KONTAKT.rar.html
