05 de Abril de 2026, 19:40 *
Autor Tema: Ample Sound Ample Guitar PF v4.0.0 (Win/macOS)  (Leído 39 veces)
« : 14 de Septiembre de 2025, 21:16 »
Free Download Ample Sound Ample Guitar PF v4.0.0 (Win/macOS) | 6.25 GB
Ample Guitar PF aim to bring a PRS Custom 24 Artist Guitar sound to your studio.
* Windows: Windows 7/8/10, 64-bit only (32-bit not supported).
* Mac: 10.9 or higher.
* VST2, VST3, AU, AAX and Standalone host.
* 10 GB Hard Disk, Intel i5 or higher.
Sampling:
* Size:6.6 GB
* Neck, Bridge, Both pickup three sample libraries.
* Stereo and Mono Modes.
* Sustain, Hammer On & Pull Off, Legato Slide, Slide in & out, Palm Mute, Pop, Natural Harmonic, Pinch Harmonic, Slide Guitar 11 articulations, Legato at random length & pitch & poly.
Technology:
* CPC (Customized Parameters Control) - any controller can be controlled by MIDI CC or Automation.
* Double Guitar.
* Poly Legato and Slide Smoother.
* Alternate Tuner.
* Multiple Capo Logics - providing various options of automatic fingering logic to cover different performance such as solo, chorus, and so on.
* Grainy - Enhance grainy of attack and produce the random humanization.
AMP Simulator:
* Built-in AMP system, including 6 classic AMP models: Metal Double (modeled on Mesa Boogie Dual), Metal Treble (modeled on Mesa Boogie Triple), Lead 800 (modeled on Marshall JCM800), Jazz 120 (modeled on Roland JC120), 65 Twang (modeled on Fender 65 Twin Reverb) and 57 Delight (modeled on Fender 57 Deluxe).
* 7 matching cabinets:1x12 57D, 2x12 65T, 2x12 120, 4x12 60A, 4x12 60B, 4x12 Ro and 4x12 Ri.
* Each Cabinet has 8 mic options: U87, C414, MD421, SM57, E609, C414 XLS, R121 and M160.
* Room Mics.
* Hundreds presets, each preset featured a riff which users can go to Riffer panel and have a preview.
Riffer:
* String Roll Editor: can clearly show fingering, articulation, expression and even playing noise. Every note has 8 attributes - pitch, velocity, length, off velocity, articulation, legato, vibrato and bend, with which you can make a delicate lick.
* Dice - Random Riff Generator: A click will create a new inspiration because it is not simply a random algorithm. Rather, it summarizes the rules through analyzing a bunch of music scores.
* Multiple selection and operation, undo and redo etc. multiple MIDI tools, including fixed velocity, length legato and restrict, select, move, draw, erase, split, glue etc.
Strummer:
* 14 Strum notes + 28 ways to play for every chord.
* Strum Legato - legato articulations can be played while strumming.
* 4 humanization settings.
* Select and Detect 2 chord modes, any chords could be customized.
* Strum SEQ with customized rhythm.
* Delicate presets with MIDI export.
FX:
* High order 8-band EQ, intuitive control of frequency response, real-time visualization of input and output spectrum, support of soloing single band..
* 2-Line Compressor, real-time visualization of input and output signal, two detection modes RMS & Peak, support of soft knee, auto release and auto makeup.
* 6-Tap Echo, real-time visualization of the processing of stereo signal, can tweak the parameters of 6 echo points individually: feedback, pan, volume etc.
* IR Reverb, providing four types of IR: Room, Studio, Hall, and Larger Hall. 3D visualization of IR spectrum.
Tab Reader:
* The Tab Player can load and play several prevalent guitar tablature file formats. Users can load, display and playback any specific track inside a tablature file. When used in DAWs, the Tab Player also allows users to export the tablature as an audio file.
This release was given by our member vatsugrelham
https://www.amplesound.net/en/pro-pd.asp?id=3
AmpleSoundAmpleGuitarPFv400WinmacOS.html
7sujo.Ample.Sound.Ample.Guitar.PF.v4.0.0.WinmacOS.part1.rar.html
7sujo.Ample.Sound.Ample.Guitar.PF.v4.0.0.WinmacOS.part2.rar.html
7sujo.Ample.Sound.Ample.Guitar.PF.v4.0.0.WinmacOS.part3.rar.html
7sujo.Ample.Sound.Ample.Guitar.PF.v4.0.0.WinmacOS.part4.rar.html
7sujo.Ample.Sound.Ample.Guitar.PF.v4.0.0.WinmacOS.part5.rar.html
7sujo.Ample.Sound.Ample.Guitar.PF.v4.0.0.WinmacOS.part6.rar.html
7sujo.Ample.Sound.Ample.Guitar.PF.v4.0.0.WinmacOS.part7.rar.html
