04 de Abril de 2026, 15:03 *
Autor Tema: Siemens NX 2412 Build 8502 (NX 2412 Series) Win x64 Multilanguage  (Leído 40 veces)
« : 16 de Septiembre de 2025, 00:15 »
Free Download Siemens NX 2412 Build 8502 (NX 2412 Series) | 18.6 Gb
Languages Supported: English, 中文, Čeština, Español, Français, Deutsch,
Italiano, 日本語, 한국어, Polski, Português, Русский
Siemens Digital Industries Softwarehas releasedNX 2412 Build 8502 (NX 2412 Series). This software helps designers and manufacturers deliver better products faster using powerful, integrated CAD and CAM solutions that realize the full value of the digital twin
Owner:Siemens Digital Industries Software
Product Name:NX Series
Version:NX 2412 Build 8502 (NX 2412 Series)
Supported Architectures:x64
Website Home Page :www.plm.automation.siemens.com
System Requirements:Windows *
What's new in NX 2412 Build 8502 (NX 2412 Series)
2412,8500   10849358   About prt files that cannot be opened in NX 2212   CORRUPTED_PARTS   MODELING   ALL
2412,8500   10909604   Can't set value for attribute with dynamic LOV   NXMANAGER   ATTRIBUTES   LOV
2412,8500   11149498   Ordinate dimension values in exported DXF are incorrect   TRANSLATOR   DXF_DWG   EXPORT_DRAFTING
2412,8500   11212954   HEEDs wavelink fails to update when certain expression is active   DESIGN   WAVE   UPDATE
2412,8500   11237794   The result of tcftsindexerfilecontentnxindex is TERMINAL   SYSENG   NXOPEN   JOURNALING
2412,8500   11253384   [NX CAM] In PLUNGE MILL, there are areas where paths are not generated for the mill area (paths are generated when set individually).   CAM   PLUNGE_MILLING   USER_INTERFACE
2412,8500   11275956   [NX CAM] Collision occurs during transition in PLUNGE_MILL.   CAM   PLUNGE_MILLING   USER_INTERFACE
2412,8500   11306911   tool correction is broken with NX2412   CAM   ISV   MACH_CODE_BASED
2412,8500   11309899   ISV : Unexpected Behavior during Simulate ToolPath for Fanuc Control when Tool is Place on a Duo Turn Holder   CAM   ISV   MACH_CODE_BASED
2412,8500   11310353   UDF with internal Suppression by expression is now also controlled by Top FeatureGroup suppression by expression   DESIGN   FEATURE_MODEL   UDF_UPDATE
2412,8500   11322404   Japanese Translation of Surface Finish Symbol   DRAFTING   ANNOTATION   SURFACE_FINISH
2412,8500   11329964   WHEN GENERATING DXF FILE FROM NX2412 USING XML OUT, A \BOX\ IS PRODUCED AROUND THE TEXT BLOCK.   SHIP_DESIGN   MANUFACTURING   MANUXML_OUT
2412,8500   11339257   MW Ejector Pin Post Processing now trims all Pins to active Family Mold Trim Sheet   TOOLING_DESIGN   MOLDWIZARD   EJECTOR_PIN
2412,8500   11339310   BIW3510 - File Open not possible after save   DESIGN   FEATURE_MODEL   MIRROR_BODY
2412,8500   11339407   MW Pocket now creates symbolic thread for threaded hole AND clearance hole   TOOLING_DESIGN   MOLDWIZARD   POCKET_DESIGN
2412,8500   11340222   Cannot open .sim created in version 2406.   CAE   ADV_SIMULATION   FILE_OPERATIONS
2412,8500   11344675   Tracking point self changing when pax counfiguration being used.   CAM   TOOLS   TURN_TRACK_PNT
2412,8500   11346763   Hole and Thread Callout function gives incorrect hole depth for holes applied on an angle to the surface   PMI   DIMENSION   HOLE_CALLOUT
2412,8500   11346846   Preferred Naming Convention Of The SuperPlate DXF File   SHIP_DESIGN   MANUFACTURING   MANUXML_OUT
2412,8500   11347498   Stock Size decimal values are not updated.   TOOLING_DESIGN   MOLDWIZARD   STOCK_SIZE
2412,8500   11351707   \Fail to open a part file due to \Invalid file contents\   CORRUPTED_PARTS   MODELING   ALL
2412,8500   11351920   OCX export endcuts not proper displayed in BV-viewer   SHIP_DESIGN   BASIC_DESIGN   STRUCTURE_XML
2412,8500   12060839   file fails to open invalid file contents in NX2406, worked in NX1953-73   CORRUPTED_PARTS   MODELING   ALL
Siemens NXis a powerful software suite used for product design, engineering, and manufacturing. As technology evolves, various versions of Siemens NX, including the latest NX version, have been released, each with improved features and capabilities. Understanding the key versions of Siemens NX is crucial for professionals in design and engineering fields. The major releases typically include significant enhancements that improve usability and performance. Each NX version is designed to enhance user experience and streamline workflows, making it vital for professionals to stay updated on the latest features and improvements introduced in each NX version. Understanding the capabilities of each NX version allows users to fully leverage the software's potential in their design and engineering tasks. For those seeking to improve their understanding of the software, reviewing the unique characteristics of each NX version can be invaluable. This knowledge empowers users to select the most appropriate NX version for their specific projects and tasks.
In this series, Esfandiar Khaleghi provides an overview of NX, sharing what you need to know to start using this flexible solution to develop products. In this tutorial, Esfandiar takes you through various 2D modelling techniques.
Introduction to CAD using Siemens NX - Tutorial 1
Introduction to CAD using Siemens NX - Tutorial 2
Introduction to CAD using Siemens NX - Tutorial 3
Introduction to CAD using Siemens NX - Tutorial 4
Siemens Digital Industries Softwareis a global leader in the growing field of product lifecycle management (PLM), manufacturing operations management (MOM), and electronic design automation (EDA) software, hardware, and services. Siemens works with more than 100,000 customers, leading the digitalization of their planning and manufacturing processes. At Siemens Digital Industries Software, we blur the boundaries between industry domains by integrating the virtual and physical, hardware and software, design and manufacturing worlds.
SiemensNX2412Build8502NX2412Series.html
dxu04.Siemens-NX-2412-Build-8502-NX-2412-Series.part1.rar.html
dxu04.Siemens-NX-2412-Build-8502-NX-2412-Series.part2.rar.html
dxu04.Siemens-NX-2412-Build-8502-NX-2412-Series.part3.rar.html
dxu04.Siemens-NX-2412-Build-8502-NX-2412-Series.part4.rar.html
dxu04.Siemens-NX-2412-Build-8502-NX-2412-Series.part5.rar.html
dxu04.Siemens-NX-2412-Build-8502-NX-2412-Series.part6.rar.html
