08 de Abril de 2026, 14:43 *
Autor Tema: Auto Presentation Switcher 3.1.3.19  (Leído 32 veces)
« : 18 de Septiembre de 2025, 06:19 »
Free Download Auto Presentation Switcher 3.1.3.19 | 60.5 Mb
On shows and events where different speakers bring their own presentations, APS is an indispensable tool for the AV-technician responsible for the visual content: You no longer have to search the Finder-menu for the next presentation. By using our commands instead, you get a smoother workflow when dealing with Powerpoint, Keynote and PDF files.
Work faster
Use buttons and shortcuts to switch between Keynote, Powerpoint and PDF-presentations
Freeze the slide while you go out of the presentation to do edits
Display other images on top of your presentation
Simplify your setup
In large coorporate events, APS can reduce the number of computers and switcher-inputs needed to handle presentations
For smaller conference-setups, APS can replace the traditional hardware presentation-switcher
Switch presentations with shortcuts
With APS, Ctrl + right arrow (PC) or Command + right arrow (Mac) will display the next presentation in the folder. This makes it easy to create a playlist of presentations: The only preparation you need is to sort them numerically in a folder. Then, during the show, just push the APS-shortcut to display the next file.
Display images and
Our new image-viewer tries to solve the problem of what the presentation-computer should show to the audience when there is no presentation to display. For example, what if you are in the middle of a presentation and you discover that there is a mistake in the next slide? With APS you can now freeze the screen, exit the presentation, do edits and go back, and the audience won't know what just happened.
And with our image-bank of 10 images you can easily display backdrops and logos before, between and after the presentations, creating a seamless and flexible workflow inside the box.
https://www.presentationtools.com/aps/
dpkwu.Auto.Presentation.Switcher.3.1.3.19.7z.html
