05 de Abril de 2026, 05:40 *
Autor Tema: PTC Mathcad Prime 11.0.1.0 Win x64 Multilanguage  (Leído 80 veces)
« : 18 de Septiembre de 2025, 18:19 »
Free Download PTC Mathcad Prime 11.0.1.0 | 1.0 Gb
Languages Supported: : English, 日本語, Français, Deutsch, Русский,
Italiano, Español, 한국어, Traditional 中文, Simplified 中文
PTChas releasedMathcad Prime 11.0.1.0. This release continues PTC's work on improving the math engines, enhancing the performance of existing features, and adding entirely new functionality
Owner:Parametric Technology Corp.
Product:Mathcad Prime
Version:11.0.1.0
Supported Architectures:x64
Website Home Page :www.ptc.com
System Requirements:Windows *
Mathcad Prime 11 released on April 2, 2025, with brand-new application additions, engine enhancements, and usability improvements to make the software even more powerful, flexible, and accessible for your needs. These new additions include manual calculation mode with Calculate Now, custom unit systems, and Python as a scripting language for advanced controls.
What's New in PTC Mathcad Prime 11
Mathcad Prime 11 Application Advancements
Manual Calculation Mode:You will be able to choose when and how to calculate your Mathcad worksheets. Before Mathcad Prime 11, you could only recalculate your entire worksheet whenever you had a new change, but with the new Calculate Now option, you can update only relevant regions up to the page currently in view.
Custom Unit Systems:You can create your own unit systems, alongside the built-in SI, USCS, and CGS systems, providing you with increased flexibility and control over the default units that display in your worksheet.
Result Threshold Formatting:You have the option to set thresholds for exponential, complex, and zero results.
Binary, Octal, and Hexadecimal Support:You can now perform calculations and format results in these number systems, in addition to the decimal system. There is also a menu option to select the default format for displaying results.
Region Borders:You may toggle borders on or off for regions in the worksheet. These can be displayed for individual regions or with multiple regions selected.
Python for Advanced Controls:Use Python scripting for advanced controls, in addition to the VBScript and JScript languages that were available when advanced controls were first introduced in Mathcad Prime 10.
Mathcad Prime 11 Engine Enhancements
New decomp Keyword:Use decomp to decompose large symbolic expressions for easier analysis.
Symbolic Calculation Improvements:You should see improved performance for symbolic calculations, including the simplify keyword and calculus operators.
New vec() and IsRange() Functions:The vec() function creates a simple vector with start, step, and stop values, or by converting an existing range variable to a vector. IsRange() is a new data type identification type function, determining if an expression is of a range data type, returning a 1 if it is a range, and 0 otherwise.
Solve Block Improvements:The solve block has been enhanced, providing you with superior support for scaling objective functions and constraints, in addition to expanding the role of your worksheet's CTOL settings during calculations.
Description Processing Improvements:2D Descriptions now have faster display times. This encompasses native XY Descriptions, contour Descriptions, polar Descriptions, and Chart Components.
Mathcad Prime 11 Usability Improvements
Simplified Insert Image:Streamline insertion of images into the worksheet. Instead of an empty Browse for Image... button region appearing, Mathcad Prime 11 will now immediately search your file browser system when clicking Insert Image.
Radio Button Selected by Default:The Radio Button Advanced Control now has a preselected choice for improved clarity. You can manage this with the SetSelectedButton State Property in the script. If placed in the Start event and if you have the option to run scripts on worksheet recalculate enabled, the Radio Button will default to this selection when the worksheet is recalculated.
Slider Invert and Min/Max Properties:There are new options to invert slider points, as well as to display the minimum and maximum values on the slider control itself.
Page Number Format:There are new page number formats for headers and footers. These formats do not contain text.
Convert Password-Protected Areas:You can now convert legacy PTC Mathcad worksheets, such as those saved in Mathcad 15, that contained collapsed password-protected areas. Those areas will remain password-protected with the same passwords they originally had.
PTC Mathcad Primeis the industry standard for engineering mathematics software, enabling you to solve your most complex problems, and share your engineering calculations. And withPTC Mathcad Prime 9, engineering calculations just got better. This release introduces enhancements to the application, the symbolic and numeric engines, and to product usability that will make you more productive than ever.
What is Mathcad Prime? An Overview
Parametric Technology Corp. (PTC)enables global manufacturers to realize double-digit impact with software solutions that enable them to accelerate product and service innovation, improve operational efficiency, and increase workforce productivity. In combination with an extensive partner network, PTC provides customers flexibility in how its technology can be deployed to drive digital transformation - on premises, in the cloud, or via its pure SaaS platform. At PTC, we don't just imagine a better world, we enable it.
435ru.PTC-Mathcad-Prime-11-0-1-0.rar.html
