05 de Abril de 2026, 18:51 *
Autor Tema: Adobe Substance 3D Sampler 5.1.1 Multilingual (x64)  (Leído 34 veces)
« : 19 de Septiembre de 2025, 00:29 »
Free Download Adobe Substance 3D Sampler 5.1.1 (x64) Multilingual Fast Links | 986.3 Mb
Substance 3D Sampler allows you to create and iterate on material collections by tweaking and mixing existing materials, or by extracting new materials from scans (single or multiple images).
A new set of powerful tools combining different technologies and creation methods (procedural-based, capture-based, AI-based and manual) will help you manage entire material libraries, and export them to other applications.
Digitize and enrich assets for 3D.
Substance 3D Sampler is at the heart of your 3D workflow. Easily transform a real-life picture into a photorealistic surface or HDR environment.
Transform real-world pictures into 3D materials.
Easily import a reference photo and transform it into a high-quality 3D material with features powered by Adobe Sensei. Closely match the original real-life surface and create seamless tileable materials from your captures.
Combine and mix materials.
Combine multiple materials and parametric filters to create more advanced surfaces. Access thousands of materials on Substance 3D Assets and Substance 3D Community Assets. The possibilities are endless.
An extensive content library to get you started.
Drag and drop your image, add a couple of prebuilt filters, and voila - a library of one-click generators, filters, and effects lets you quickly experiment and get results in just a few clicks. Send your assets directly to Substance 3D Painter and Stager.
The heart of your 3D workflow.
Use generators and filters from Designer, composite light environments for Stager, or send materials and lights to Painter. You can even edit your 2D inputs directly in Adobe Photoshop. Choose from a variety of export presets for all major 3D apps.
The features in Substance 3D Sampler give you a complete material digitizer toolbox.
AI-powered scan processing
The Image to Material feature removes shadows and generates albedo, roughness, normal, and displacement maps with unparalleled accuracy.
open ecosystem
Use your content anywhere. Send your assets directly to Painter and Stager, or use them in your favorite 3D applications.
IBL creation
Create HDR environment lights in real time from 360° images. Enrich and edit them with parametric effects or even other lights.
Edit in Photoshop
Send any input image to Photoshop and take advantage of its extensive image editing toolset, with direct feedback in Sampler.
Atlas Splatter
Scatter leaves, pebbles, and more on your material. Choose from a vast library of atlases made by our team of 3D experts or use your own scanned content.
Parametric effects
Add filters. Combine weathering and natural effects such as moss, snow, water, or dirt with any existing material.
Minimum:
OS: Windows 10 (64bit, version 1909)
CPU: Intel Core i5 / AMD Ryzen 5
GPU: Nvidia Geforce GTX 1060 / Nvidia Quadro P2200 / AMD Radeon RX 580
VRAM: 4GB
RAM: 16GB
Hard drive: SSD type with 30GB of free space
https://www.substance3d.com/
vj4zu.Adobe.Substance.3D.Sampler.5.1.1.x64.Multilingual.rar.html
