04 de Abril de 2026, 12:33 *
Autor Tema: Autodesk Vault 2026.1.1 Products Update Win x64  (Leído 31 veces)
« : 19 de Septiembre de 2025, 00:29 »
Free Download Autodesk Vault 2026.1.1 Products | 853.0 mb
Languages Supported: English, Čeština, Français, Deutsch, Magyar, Italiano, 日本語, 한국어,
Polski, Português, Русский, Simplified 中文, Traditional 中文, Español
Owner:Autodesk Inc.
Product Name:Vault Client & Vault Server
Version:2026.1.1 Update with language packs *
Supported Architectures:x64
Website Home Page :www.autodesk.com
System Requirements:Windows **
Software Prerequisites:pre-installed Autodesk Vault 2026.0 Products and above
Autodeskhas releasedVault 2026.1.1 Products. This release of Vault delivers enhancements requested by you and the Vault user community, enabling you to accelerate overall design creation and data management experience significantly.
Known Issues
Client
- 'Sign in' bar will be hidden when user clicks in top bar area in Vault client window. PDM-47630
- Attachments dialog window becomes un-responsive, when trying to 'Attachments' row is visible in the Users tab and attachment workflow is initiated. PDM-46758
Installation
- File Server Update 2026.1.1 cannot be re-installed after clicking Cancel button in prompt message. As a workaround - user will need to uninstall AVFS and start from 2026RTM level. DEPLOY-13622
Server
- Delete master vault and Restore backup will lead to error 'Master Vault doesn't exist'. As a workaround - user can create a master vault before initiating 'Restore' command. PDM-48622
Vault Connector
- Vault help for connector is not correctly launched, when user presses F1 keyboard key. PDM-47824
- Attaching very large size files (size > 1 GB) from Vault to Fusion manager items fails. PDM-47750
- BOM Creation Fails When Adding Existing Item in Fusion Manage. PDM-47739
- Property Data Type Not Localized in Vault Connector Mapping UI. PDM-47848
- Item Resync fails after purging Fusion Manage workspace. PDM-47847
- BOM structure is deleted from Fusion Manage, when the 'sync updated BOM Item' returns error. As a workaround - User need to manually add the BOM Item OR correct the error and sync again. PDM-47878
- Incorrect error message is seen when user tries to sync Item, without setting up the Vault Connector mapping. PDM-47670-
- When the user syncs the parent and child items together at once - this results in failure to create an items in Fusion Mange. As a workaround - user can select the error Item and resync again. PDM-47832
- 'Sync to Fusion Manage' command is enabled when user selects all versions of the item from 'History' tab and initiates sync, which leads to error. PDM-47889
- Properties related to sync status are updated only for main parent item, this is not updated for all the BOM Items in this structure. As a workaround - user can click 'Edit' and then exit edit mode to get the status updated. PDM-47886
- New Item gets created in Fusion Manage instead of updating the existing item, when Item number is changed and sync to fusion manage is done. PDM-47893
Fixed Issues
Add-ins - Inventor
- Resolved issue where Content Center components were not recognized after updating Content Center parts. PDM-48265
Installation
- Resolved issue where the installer encountered ERROR -1 in specific environments, such as a German operating system with an English locale setting for the system's administrative language. DEPLOY-13717
Vault Connector
- Resolved an issue where creating an Item failed due to a duplicate Item number by ensuring the historical releases of the Item number were scanned. PDM-48340
- Resolved issue and improved stability during Vault connector activation. PDM-48095
- Resolved issue where BOM creation returned an error when a repeated Item was present in the BOMs. PDM-48101
- Resolved issue where an Item was not able to be synced when the Job Processor was disabled. PDM-48327
Server - Performance
- Resolved an issue where the error message "The file does not exist or is invalid" appeared when attempting to get files from a folder or delete this folder. PDM-47371
Server
- Resolved the issue with command line incremental backup, where using INCR as command line argument was resulting in error. PDM-47551
Autodesk Vaultdata management software, part of the Autodesk solution for Digital Prototyping, helps you organize, manage, and track design, engineering, and simulation data and documentation. Get more control over your designs with revision management capabilities and quickly find and reuse data for better management of your design and engineering projects. Whether your team sits in the same office or across multiple sites, Autodesk Vault helps you collaborate more effectively and share information with other departments, maximizing your design data value.
What's New in Vault 2026 | Full Feature Breakdown
This in-depth walkthrough covers the latest enhancements designed to streamline data management, improve team collaboration, and simplify everyday tasks.
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Autodesk_VaultClient_2026.1.1_Update.exe
Autodesk_VaultServer_2026.1.1_Update.exe
VaultClientLP_2026.1_chs.exe
VaultClientLP_2026.1_cht.exe
VaultClientLP_2026.1_csy.exe
VaultClientLP_2026.1_deu.exe
VaultClientLP_2026.1_enu.exe
VaultClientLP_2026.1_esp.exe
VaultClientLP_2026.1_fra.exe
VaultClientLP_2026.1_hun.exe
VaultClientLP_2026.1_ita.exe
VaultClientLP_2026.1_jpn.exe
VaultClientLP_2026.1_kor.exe
VaultClientLP_2026.1_plk.exe
VaultClientLP_2026.1_ptb.exe
VaultClientLP_2026.1_rus.exe
Uploady
g8ahk.Autodesk.Vault.2026.1.1.Products.rar
g8ahk.Autodesk.Vault.2026.1.1.Products.rar.html
