06 de Abril de 2026, 22:52 *
Autor Tema: Kaslaan AImage Tools 1.0  (Leído 42 veces)
Conectado Conectado
« : 19 de Septiembre de 2025, 18:00 »
Free Download Kaslaan AImage Tools 1.0 | 1.87 GB
This is a new application from KaslaanSoft called Kaslaan AI Image Tools. It brings AI-based image manipulation tools together in one place. Right now, it includes a background removal tool and an upscale tool.
Let's start with the background removal tool. You can process a single image or, for bulk processing, select a folder containing multiple images. In the model selection section, choose a model that works best for your image or images. The output background can be transparent or a solid color, depending on your preference. Additionally, it can trim the subject out of the source image. Finally, specify the output directory, and you're good to go!
Now, let's move on to the upscale tool. This feature enhances low-resolution images by upscaling them. As before, you can select a single file or a folder for bulk processing. Simply specify the scale factor, choose the output directory, and start the process. Log tab: This section logs and lists all processed files with relevant details-unless you disable it using the checkbox at the bottom left. You can export the log to a local CSV file or clear it using the dedicated buttons.
Features
- Supports various file types: JPG (or JPEG), PNG, and BMP
- Supports bulk processing
- AI-based image background removal
- AI-based image upscaler
- Files processing logging
System Requirements
Windows 10 version 17763.0 or higher
Microsoft Store - Full Version
https://apps.microsoft.com/detail/9pdd648wrcct?hl=en-US&gl=US
il1bf.Kaslaan.AImage.Tools.1.0.rar.html
