04 de Abril de 2026, 12:12 *
Autor Tema: Autodesk Revit 2026.3.0 with Updated Extensions Win x64 Multilanguage  (Leído 122 veces)
« : 19 de Septiembre de 2025, 22:08 »
Free Download Autodesk Revit 2026.3.0 with Updated Extensions | 12.9 Gb
Languages Supported *: English US, English UK, Deutsch, Français, Español, Brazilian Português,
Italiano, Русский, Polski, Čeština, Simplified 中文, Traditional 中文, 日本語, 한국어
Autodeskhas released REVIT 2026.3.0 is arrives as a targeted update, delivering important productivity gains-particularly for residential designers-while raising the bar for performance, automation, and documentation across all disciplines.
As Autodesk Revit marks its 25th anniversary since its initial release on April 5, 2000, the launch of Revit 2026 brings a suite of eagerly awaited enhancements that promise to streamline your BIM workflows. Key features include the Accelerated Graphics Tech Preview and the ReCap Pro Mesh Revit plugin. Continuing our commitment to meeting the needs of customers and directly incorporating your feedback and requests, Revit 2026 delivers substantial improvements across modeling capabilities, design coordination workflows, and documentation processes.
2026.3 Update - Release Date: September 16, 2025
The Revit 2026 updates are cumulative and include all changes from previously released Revit 2026 updates.
After this update is applied successfully, the build information specified on the Help > About dialog will be:
-    26.3.0.37
-    20250908_1515(x64)
-    2026.3
Software embedded in the update executable:
Generative Design For Revit - version 26.5.6.0
Interoperability Engine Manager - version 1.3.2.2
OpenUSD for Revit 2026 - version 26.3.0.37
Core Package - Component for Revit 2026 - version 26.3.0.37
Core Package - ATF for Revit 2026 - version 26.3.0.37
Core Package - Cloud for Revit 2026 - version 26.3.0.37
Core Package Component Shared for Revit 2026 - version 26.3.0.37
Core Package - RVT Component for Revit 2026 - version 26.3.0.37
Dynamo Core for Revit 2026 - version 26.3.0.37
Dynamo Docs - version 26.3.0.37
TwinMotion Package Component for Revit 2026 - version 26.3.0.37
Unit Schemas for Revit 2026 - version 26.3.0.37
Product Feedback for Revit 2026 - version 26.3.0.37
Carbon Insights for Revit 2026 - version 26.3.0.37
Important Notes
The Revit 2026.3 Update does not support uninstall. Once Revit 2026.3 Update is applied Revit 2026 cannot be reverted to its pre-update state.
API
- Added Revit API to return all regions supported for Revit cloud models.
Boundary Conditions
- Enhanced ease of boundary conditions definition by enabling application on multiple elements in a single bulk operation.
Coordination Model
- Added Coordination Model API to manage the Coordination Model links in Revit files and set their visibility control in Revit views.
Dynamo
- Upgraded Dynamo Core version to 3.6. See the release notes for details.
IFC
- Made improvements for Japanese certification of IFC export.
Revit Cloud Worksharing
- Updated error messages to inform users if a naming standard or required attributes are preventing a model from being initiated to the cloud.
Reinforcement
- Added the ability to split rebar sets at the selected bar position or intersecting line reference.
Structural Analytical Model
- Added the ability to use the Pin feature to lock analytical model elements in place during editing and automation operations.
Structural Loads
- Enhanced ease of structural loads definition by enabling application on multiple elements in a single bulk operation.
Walls
- Enhanced Create Walls by Room and by Segment functionalities by enabling the non-room-bounding walls to be the target while creating new walls with these tools.
General
- Addressed potential security vulnerabilities.
- Addressed PDF File Parsing Vulnerabilities. More details.
Coordination Model
- Fixed an issue that could cause Revit to close unexpectedly when working with the same Coordination Model in two Revit sessions side-by-side or in two Revit models in the same Revit session.
- Improved the numbers reporting for modified and deleted elements in Coordination Model Changes.
Edit
- Improved stability while clicking Cable Tray connector placement options on the ribbon.
Export PDF
- Improved stability when selecting views and sheets to export to PDF.
MEP Systems Analysis
- Fixed an issue that grouped unassigned analytical spaces into one thermal zone when the voxel mode was used to generate the energy analytical model.
Revit Cloud Model (workshared)
- Fixed an issue with the Revit Link API to ensure cloud models initiated via API can be published as expected.
Schedules
- Improved stability of schedules with combined parameters.
Stair
- Fixed an undefined behavior when the cut plane level is equal to the height of the top nosing (tread).
- Fixed stability issues when accessing the Member Forces dialog when creating the Analytical Member.
- Fixed stability issues when adding invalid characters in the Member Forces dialog for Analytical Members.
- Fixed an issue in which Physical to Analytical automation could create columns and walls aligned to levels out of Level tolerance for non-English installations.
- Fixed an issue in which the "Analytical Model Automation" dialog displayed truncated strings in some languages.
- Fixed an issue in which the "No Automation Tool Found" dialog displayed a truncated title for Spanish.
Structural Loads
- Fixed an issue occurring when Structural Area Load was moved inside an incorrect work-plane when using the Copy command.
- Fixed an issue with API methods PointLoad.IsPointInsideHostBoundaries and LineLoad.IsCurveInsideHostBoundaries that did not detect correctly as being inside host when the host is an Analytical Member.
- Fixed an issue in which the Point Load couldn't be copied with precision in 3D views.
Units
- Fixed an issue when opening and upgrading a Revit model.
User Interface
- Fixed an issue that Revit UI became unresponsive in some cases with Windows 11.
Autodesk Revit, Autodesk's leading Building Information Modeling (BIM) solution, supports multi-discipline teams throughout the project lifecycle. Available individually or as part of the Autodesk architecture, engineering, and construction industry collection, Autodesk Revit features industry-specific tools for architectural design, mechanical, electrical, and plumbing (MEP), structural engineering, and construction.
Revit 2026 - What's New? | Revit 2026 New Features Tutorial
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Owner:Autodesk
Product Name:REVIT
Version:2026.3.0 with Updated Extensions *
Supported Architectures:x64
Website Home Page :www.autodesk.com
Languages Supported:multilanguage *
System Requirements:Windows **
*NOTE: For each of the supported languages, the Revit software contains translations for the user interface. Revit does not use language packs. Instead, the base language for the software is determined as follows:
-When installing Revit on a single computer:The language (and locale) for the software is based on the computer's regional settings specified for the operating system.
-When creating a Custom Install:The language (and locale) for the deployment image is based on the regional settings specified for the operating system of the computer used to create the deployment.
Languages for Revit content
In a default Revit installation essential language content packs for the 14 supported languages in Revit will be installed. Essential language content is option within Custom Install workflows.
RVT_2026_NA_win_db_001_002.exe
RVT_2026_NA_win_db_002_002.7z
Revit_2026_3_0_Update.exe
Autodesk Data Exchange Connector for Revit 2026 v1.9.0
Autodesk Shared Components 2026.3
Interoperability Tools Model Checker Configurator v10.0.9.4966 for Revit 2026 and Validation Tool 2026
Interoperability Tools v10.0.9.4966 for Revit 2026
Issues Addin v8.0.1 for Revit 2026
US English Residential Content Pack for Revit 2026
Uploady
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part1.rar
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part2.rar
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part3.rar
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part4.rar
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part5.rar
AutodeskRevit202630withUpdatedExtensions.html
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part1.rar.html
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part2.rar.html
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part3.rar.html
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part4.rar.html
9fzdi.Autodesk-Revit-2026-3-0-with-Updated-Extensions.part5.rar.html
