05 de Abril de 2026, 02:13 *
Autor Tema: Autodesk AutoCAD LT 2025.1.3 Update Only (x64)  (Leído 63 veces)
« : 23 de Septiembre de 2025, 23:19 »
Free Download Autodesk AutoCAD LT 2025.1.3 Update Only (x64) | 921 Mb
AutoCAD LT 2025 is designed to develop and detail 2D drawings. The program automates most of the stages of the project. A full set of 2D commands allows you to create drawings, modify them and release working documentation for projects.The program provides built-in support for DWG format and reliability of work, and also contains powerful tools to improve drawing performance.Thanks to this project files can be easily transferred to other specialists. In addition, you can customize the user interface of the program to fit your needs.
OS: Microsoft Windows 10 (64-bit only) (version 1803 or higher)
CPU: Basic:2.5-2.9 GHz processor / Recommended:3+ GHz processor
Multiple processors:Supported by the application
RAM: 8 GB / Recommended: 16 GB
Display Resolution
Conventional Displays:1920 x 1080 with True Color
High Resolution & 4K Displays:Resolutions up to 3840 x 2160 supported on Windows 10, 64-bit systems (with capable display card)
Disk space: 6.0 GB
https://www.autodesk.com/
Uploady
davfc.Autodesk.AutoCAD.LT.2025.1.3.Update.Only.x64.rar
davfc.Autodesk.AutoCAD.LT.2025.1.3.Update.Only.x64.rar.html
