04 de Abril de 2026, 17:33 *
Autor Tema: Gilisoft Image Converter 8.2  (Leído 26 veces)
« : 23 de Septiembre de 2025, 23:22 »
Free Download Gilisoft Image Converter 8.2 | 683.2 Mb
The image converter is a powerful tool with multiple practical functions, which can meet various needs of users for image processing. It not only supports the conversion between multiple image formats, but also can compress images, reduce ✅File Size, and facilitate storage and sharing. In addition, it can also convert images to PDF format, making it easier to manage and save images. For users who need to process a large number of images, this converter provides the function of batch modifying size, cropping, renaming, and rotating, which greatly improves work efficiency.
At the same time, it also supports the batch classification of images, allowing users to manage and organize images more easily. Whether you need to process individual images or process a large number of images efficiently, this image converter can provide you with a convenient and efficient solution, making your image processing work more relaxed and smooth.
Exclusive Features of Gilisoft Image Converter
Format conversion
It supports the conversion of hundreds of image formats, which can easily convert image formats such as jpg, png, bmp, and gif, and also batch add files for conversion.
Raw conversion
Not only does it support the conversion of common image formats, but also supports the quick conversion between Heic and Raw formats and other image formats, which can be operated singly or in batches.
HEIC Conversion
"HEIC Conversion" can refer to converting images in HEIC format to other common formats, such as JPEG or PNG, for use on other devices or platforms, or it can also refer to converting images in other formats to HEIC format.
Image compression
It means to reduce the size of the image file by reducing the amount of data in the image file, while trying to maintain the quality and visual effect of the image.
Image to PDF
Converting images to PDF format can integrate multiple images into one file, which is convenient for saving, sharing, and printing. This makes it easier to manage and view images, while also retaining the original quality of the images.
Batch Image size modification
A process of adjusting the dimensions of multiple images simultaneously. With this Image resizer, multiple images can be handled concurrently to have the same or different dimensions.
Batch Image cropping
You may need to crop a batch of photos to the same size, or crop multiple images according to specific rules. This function is very useful when processing a large number of images, which can improve efficiency and ensure that the cropped images have consistent size or format.
Batch Image renaming
You can rename a set of images according to certain rules to make them more easily identifiable and manageable. This feature is very convenient when it comes to renaming a large number of images, as it can save time and increase work efficiency.
Batch Image rotation
Rotate multiple images at the same or different angles. This function is very useful when it is necessary to unify the orientation of a large number of images, such as rotating all horizontally oriented images to a vertical orientation, or correcting tilted images.
Batch Image classification
Classify based on format, resolution, and time. You can put images of the same format, resolution, or shooting time together for better organization and management.
https://www.gilisoft.com/
1aksj.Gilisoft.Image.Converter.8.2.rar.html
