07 de Abril de 2026, 09:37 *
Autor Tema: DBF Viewer 2000 v8.83 Multilingual  (Leído 38 veces)
« : 23 de Septiembre de 2025, 23:27 »
Free Download DBF Viewer 2000 v8.83 Multilingual Fast Links | 4.8 Mb
If you're seeking a fast, effective solution for viewing and editing all sorts of DBF files, DBF Viewer 2000® is the answer. This feature-rich program can handle files from dBase, Visual dBase, Foxpro, Visual FoxPro and Clipper, to name just a few, with a performance that easily rivals costly professional database utilities.
Its optimised proprietary engine means that no matter what your ✅File Size, DBF Viewer 2000 is incredibly fast, performing any task you set it - from a simple query and duplicate clean-up to data export - at lightning speed.
With DBF Editor's simple, dynamically generated visual dialogues, you can easily see the structure of your DBF files and edit them exactly as you would with native database management tools. In addition to being able to view the contents and structure of DBF files, you can also view and edit dBase III, dBase IV, dBase Level 7, FoxPro and Visual FoxPro format memo fields.
Command line automation is fully supported, making it simple to repeat activities including data import, replacement and export and clean-up of duplicate records. Because DBF Viewer 2000 is completely independent of database engines, drivers and database management systems, you can simply install the program and start viewing and editing DBF files immediately.
Operating System:Windows from 2000 through XP, Windows 11, 10, 8, 7 and Server Editions
https://www.dbf2002.com/
nz7ed.DBF.Viewer.2000.v8.83.Multilingual.rar.html
