05 de Abril de 2026, 22:44 *
Autor Tema: Fiedler Audio Dolby Atmos Composer v1.6.2  (Leído 37 veces)
« : 28 de Septiembre de 2025, 20:58 »
Free Download Fiedler Audio Dolby Atmos Composer v1.6.2 | 26.9 Mb
Next generation workflow for Dolby Atmos mixing. When you want to get creative or just need to get work done, you need tools which do the heavy lifting. The Dolby Atmos Composer does that and thereby enables you to quickly get convincing results while mixing in Dolby Atmos. No matter which DAW you use, if you have a sophisticated multichannel mixing room or just use headphones for monitoring, the features and the ease of use of the Dolby Atmos Composer are unrivalled.
Key Features
Approved by Dolby Labs: Dolby Atmos mixing on any DAW, even if the DAW is not capable of multichannel audio
Monitoring on multichannel speakers from any DAW directly from the Dolby Atmos Composer plug-in
Supports monitoring on: stereo, binaural, 5.1, 5.1.2, 5.1.4, 7.1, 7.1.2, 7.1.4, 9.1.4, 9.1.6
NEW: Master Channel for processing your Atmos mix with OBAM plug-ins
Instant loudness measurement for loaded ADM/BWF files
Easy setup without the need of manual routing configuration, no external app required
Connects to Dolby Atmos Beam and Spacelab series 3D reverb plug-ins
Dolby Atmos Beam
Position the inputs as objects around the listener easily
Automate complex movement patterns
Panning to composite (bed) or as dynamic objects
Quickly set objects to predefined speaker positions
Connection to Spacelab reverb
Direct connection of our world class 3D reverb to the Dolby Atmos Composer circumventing DAW limitations
Spacelab sources as can be configured as dynamic objects in Dolby Atmos
Use arbitrary speaker layouts for your reverb in Dolby Atmos
Export & Import
Export your Dolby Atmos mix as ADM/BWF files for distributing to all major platforms
Simultaneous export of speaker and headphone outputs of the renderer
Import ADM/BWF files for playback, corrections and re-export
https://fiedler-audio.com/dolby-atmos-composer/
Uploady
bsqrn.Fiedler.Audio.Dolby.Atmos.Composer.v1.6.2.rar
http://peeplink.in/c2bc0badb49a
bsqrn.Fiedler.Audio.Dolby.Atmos.Composer.v1.6.2.rar.html
