05 de Abril de 2026, 14:11 *
Autor Tema: Fiedler Audio Gravitas MDS v1.0.7  (Leído 32 veces)
« : 28 de Septiembre de 2025, 20:58 »
Free Download Fiedler Audio Gravitas MDS v1.0.7 | 33.8 Mb
The ultimate mix bus & mastering compressor. Gravitas MDS is our highend mix bus and mastering compressor which excels on anything, from single sources, groups, buses to complete mixes. It is the only multi-channel compressor capable of giving your Dolby Atmos mix the same glue and shine you know from countless stereo records. Treat it gently to sound marvellously transparent almost as if not existing but miraculously shaping the dynamic range. Or compress your drums to give them a punch never heard before. And everything in between.
Key Features
Mix bus & mastering compressor for any track format, from mono and stereo up to 128 channels
Access to all 4 types of dynamics (compression/expansion, upward/downward)
Complex compression/expansion curves for the entire dynamic range in one dynamics circuit
Separate filters for processing and for level detection
Optional Mid/Side processing on stereo tracks
Manual LFE volume adjustment when used as a multi-channel compressor
Unique limiter function for gain reduction / gain increase
External side chain with up to 64 channels (depends on DAW)
"3DET" mode for complex dynamics inspired by the legendary AMEK mastering compressor
Gradual channel linking and gradual peak mode
Comprehensive input configuration options for both processing and detection
Parameter linking accross all instances in a session
The only mix bus and mastering compressor for Dolby Atmos!
(requires Dolby Atmos Composer v1.6+)
Up to 128 channels for complete Atmos mix processing
External sidechain with up to 64 channels through sidechain input of the Dolby Atmos Composer
Easy processing of imported ADM/BWF files with multiple LFE channels
https://fiedler-audio.com/gravitas/
Uploady
5m4pw.Fiedler.Audio.Gravitas.MDS.v1.0.7.rar
http://peeplink.in/6e036649c52b
5m4pw.Fiedler.Audio.Gravitas.MDS.v1.0.7.rar.html
