07 de Abril de 2026, 03:06 *
Autor Tema: FlowHeater 4.5.1  (Leído 36 veces)
« : 28 de Septiembre de 2025, 21:05 »
Free Download FlowHeater 4.5.1 | 27 Mb
The functionality of FlowHeater closely resembles the concept of a continuous-flow water heater. A wide variety of data sources can be interconnected with FlowHeater and by making use of exchangeable Adapters there is no restriction to possible data flow and conversion.
Text files
for reading and writing text files (CSV, TXT, ASCII, FlatFile, etc). Of course differing codepages and locales are handled automatically
MS Access
used for importing and exporting data  directly into and out of Microsoft Access MDB, MDE, ACCDB, ACCDE databases. All versions of Access 97 thru Access 2019 are supported
MS Excel
used for the import/export of spreadsheet data directly into/out of Microsoft Excel (XLS, XLSX) files. The Adapter supports all versions of Excel in Office 97 thru Office 2019
MySQL
makes it possible to import, export and update data in MySQL / MariaDB Server databases. The Adapter supports MySQL Server 3.x and above, including MariaDB
MS SQL Server
used to import, export and update data directly in MS SQL Server databases / tables. All versions of SQL Server 7.0 thru SQL Server 2019 are supported
Oracle Databases
used for the direct import, export and update of Oracle databases. The Adapter can cope with database versions from Oracle 7.3 thru Oracle 19c
SQLite
used for the direct import, export and update of data in SQLite3 databases. The Adapter also supports the creation of a new SQLite database
PostgreSQL
used for the direct import, export and update of data in PostgreSQL databases. The Adapter supports PostgreSQL database server up to version 12.x
System requirements:
Windows 7 / 8 / 10 / 11 or Windows 2008 / 2012 / 2016 / 2019 / 2022 Server
.NET Framework 4.5, you can get the Framework from here. Note: Only required for Windows 7 and Server 2008. The framework is already included in later versions (Windows 8, 10 and Server 2012 / 2016 / 2019 / 2022) and so it is not necessary to install this software on those operating systems.
Any processor (x86 32 Bit or x64 64 Bit) capable of running the operating system
Minimum 2 GB main memory. More memory means more performance!
20 MB hard disk space
https://flowheater.net/en/
llat1.FlowHeater.4.5.1.7z.html
