04 de Abril de 2026, 15:03 *
Autor Tema: DraftSight Enterprise Plus 2025 SP4 Win x64 Multilanguage  (Leído 34 veces)
« : 29 de Septiembre de 2025, 03:58 »
Free Download DraftSight Enterprise Plus 2025 SP4 | 1.1 Gb
Languages Supported: Čeština, Deutsch, English, Français, Italiano, 日本語, 한국어,
Polski, Português, Русский, Español, Türkçe, 中文 (Simplified)
Dassault Systemesis pleased to announce the availability ofDraftSight 2025 FD04 (SP4)is major software powerful, and includes your most asked-for capabilities and functionality. DraftSight lets you create, edit, view and markup any kind of 2D and 3D DWG file with greater ease, speed and efficiency.
Owner:Dassault Systèmes SolidWorks Corp.
Product Name:DraftSight
Version:Enterprise Plus 2025 FD04 (SP4)
Supported Architectures:x64
Website Home Page :www.draftsight.com
System Requirements:Windows *
DRAFTSIGHT 2025 SP4  - List of Fixed IRs
Annotation Issues
IR-1395169 With dimension styles selected, dragging a dimension line causes the alternate unit text to move above the line, despite being set to display below.
IR-1395308 Chinese versions of DraftSight incorrectly enable/disable tolerance options based on the Calculation setting.
IR-1399467 Multiline Text Editor issues in 2025 SP2: unable to delete multiple lines.
IR-1408171 In DraftSight 2025, deleting a line of text in a "Note" object also deletes the second line below it.
IR-1362172 DraftSight users cannot double-click a simple note to edit it, which disrupts workflow.
Drafting Issues
IR-1389194  Incorrect representation of LINESTYLE in DraftSight Mechanical when copied over from other 2D CAD programs.
IR-1395169 Fails to create a fillet when the specified fillet radius is equal to the radius of one of the circles being filleted.
IR-1396699 Unable to select faces using UCS command in DraftSight Enterprise.
IR-1396737 DraftSight 2025 SP1 hangs and gives an incorrect "Selected entity is not a component" error when the EDITCOMPONENT command is used on a dimension.
File Operations
IR-1418830 DraftSight Mechanical 2025 SP2 crashes when copying and pasting a drawing between files.
IR-1406125 DraftSight 2024 SP4 shows a "drawing file is not valid" error when opening a specific file.
IR-1401794 In DraftSight 2025 SP2, the editing dimensions in a drawing file result in an "A dependent expression cannot be evaluated" error.
IR-1409453 DraftSight 2024 SP4 crashes when opening files created in 2020 and stored in Enovia.
Printing Issues
IR-1389181 Print Setting Location in Options > System Options > Printing does not change.
IR-1395896 The logo in the title block shifts when printing in portrait mode after upgrading to DraftSight 2023.
IR-1384468 Printed DWF files from DraftSight don't reflect the specified scale, causing incorrect dimensions.
System & User Interface
IR-1424433 Crash occurs after switching to Model Space following use of the View Tiles Manager feature in a Layout Sheet.
IR-1424743 Typing Korean text in the Options > System Options search box crashes DraftSight.
IR-1408398 DraftSight crashes after moving a grip cycling option and saving the changes.
Blocks
IR-1409163 Blocks sometimes fail to automatically snap to the correct rotation of an infinite line during insertion.
DraftSightis a feature-rich 2D and 3D CAD solution for architects, engineers and construction service providers, as well as professional CAD users, designers, educators and hobbyists, and includes your most asked-for capabilities and functionality. DraftSight lets you create, edit, view and markup any kind of 2D and 3D DWG file with greater ease, speed and efficiency. Its familiar user interface facilitates a quick transition from your current CAD application. Real design freedom is letting you work the way you want to work. It's the ability to effortlessly go from 2D drafting to 3D modeling and back again in order to optimize and maximize designs. And the capability to seamlessly integrate with other Dassault Systèmes and SOLIDWORKS solutions, including SOLIDWORKS PDM to easily manage your DWG file designs from first inspiration to final outcome.DraftSight 2025promises to elevate your design workflows with improved efficiency and intuitive tools. Whether you're a seasoned DraftSight user or just starting your CAD journey, there's something to look forward to here.
DraftSight - What's New 2025
Explore some of the best of "What's New" in DraftSight 2025!  See how combining DraftSight and SOLIDWORKS can empower and optimize your 2D and 3D workflows all while working in a familiar user interface.
Dassault Systèmes SolidWorks Corp.offers complete 3D software tools that let you create, simulate, publish, and manage your data. SolidWorks products are easy to learn and use, and work together to help you design products better, faster, and more cost-effectively. The SolidWorks focus on ease-of-use allows more engineers, designers and other technology professionals than ever before to take advantage of 3D in bringing their designs to life.
DraftSightEnterprisePlus2025SP4.html
6i3si.DraftSight-Enterprise-Plus-2025-SP4.rar.html
