Free Download iCare SD Memory Card Recovery 4.0.1.1 Multilingual + Portable Fast Links | 7.5/7.5 MbYou can easily lose files on a variety of storage devices, and it doesn't have to be your fault entirely. Drives can become corrupt, or items may have been deleted by mistake. Regardless of the case, iCare SD Memory Card Recovery can help you bring them back from damaged USB flash drives and SD memory cards.
Surface and deep scan to use
The main window of the application lets you select the scan method to use. If you know for sure you just deleted a bunch of files among which is the one of interest, you can rely on the deleted file recovery mode for a quick scan. On the other hand, the deep scan recovery can be used to thoroughly look up data in all sectors.
Needless to say that the first method is faster, but doesn't work for all files, especially if the drive got formatted in the meantime. After a scan operation the application displays an organized navigator. On one side you find the folder tree list for comfortable navigation, while the second panel is where files are shown with details or as thumbnails.
Select files to save and the destination
There's also the possibility to search for a particular file with the built-in functions. If you're not sure by name, the application offers a file viewer which is fitted with features to display text content, HEX code, as well as a preview if possible.
The last step of the operation is to choose a save location for selected files. A tree list is put at your disposal for selection of a folder, but you can also paste the path in the dedicated field. It's highly recommended to use a different drive. The application issues a warning when attempting to save to the same drive.
In conclusion
Taking everything into consideration, we can state that iCare SD Memory Card Recovery is sure to come in handy if you can't access files on your SD card or USB flash drive or you just accidentally deleted files you need. It also comes with an in-depth scan operation for file lost during a format operation.
- Memory card recovery When:
Formatted card by mistake/intentionally, card asking for reformatting, Not format error, data become inaccessible after format, virus removed files, deleted photo/video on phone/camera, wiped out phone/card, etc.
- Device Supported:
Mobile/Camera SD Memory Card, MicroSD/tf, xd, CF Card, SDXC, etc.
- File Systems Supported:
RAW, FAT32, FAT16, FAT12, NTFS5, NTFS, exFat
- Recover data from All kinds of memory card eg:
Sandisk, Samsung, Kingston, Silicon Power, Beeway, Generic, PNY, Transcend...
Home Page -https://www.icare-recovery.com/card-recovery/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator86rsp.iCare.SD.Memory.Card.Recovery.4.0.1.1.Portable.rar.html86rsp.iCare.SD.Memory.Card.Recovery.4.0.1.1.rar.htmlFikper86rsp.iCare.SD.Memory.Card.Recovery.4.0.1.1.Portable.rar.html86rsp.iCare.SD.Memory.Card.Recovery.4.0.1.1.rar.htmlFreeDL86rsp.iCare.SD.Memory.Card.Recovery.4.0.1.1.Portable.rar.html86rsp.iCare.SD.Memory.Card.Recovery.4.0.1.1.rar.htmlLinks are Interchangeable - No Password - Single Extraction
