06 de Abril de 2026, 07:17 *
Autor Tema: Autodesk Moldflow Simulation Software 2026 Update 1 Win x64  (Leído 49 veces)
« : 30 de Septiembre de 2025, 22:48 »
Free Download Autodesk Moldflow Simulation Software 2026 Update 1 | 12.9 Gb
Languages Supported: English, Français, Deutsch, Italiano, 日本語,
Português, Simplified 中文, Español, Traditional 中文
Autodeskhas released Autodesk Moldflow Simulation Software 2026 Update 1. This release introduces new features and enhancements that expand the capabilities, enhance solution accuracy, and reduce time to solution.
Owner:Autodesk
Product Name:Moldflow Simulation Software
Version:2026 Update 1 *
Supported Architectures:x64
Website Home Page :www.autodesk.com
System Requirements:Windows **
Download Autodesk Moldflow Simulation Software 2026 Update 1 Win x64 - advanced plastic injection molding simulation tool for product design, optimization, and manufacturing efficiency
Autodesk Moldflow Adviser 2026
Adviser-2026-bundle-Update1.exe
Autodesk Moldflow Material Database 2026.1
Autodesk Moldflow Synergy 2026
Autodesk Moldflow Insight 2026
The new Moldflow 2026 version offers numerous enhancements and improvements that further increase calculation accuracy, accelerate simulation results, and optimize user-friendliness.
Moldflow 2026.0 Release highlights
The main features for the 2026 release are:
-    A new warpage result that allows for easier comparison between Moldflow and 3D scanned data on real parts.
-    Very targeted performance improvements modelling operations (eg. Merge nodes on large 3D models).
-    The ability to save animation in .mp4 format.
-    Export of .zip project archives and .mfr files (Communicator files) larger than 2Gb.
-    STAMP is now the default shrinkage model for 3D models with shrinkage data.
-    Speed improvements on 3D solves and meshing.
Besides this, there are other smaller improvements and new capabilities, and we fixed 91 bugs from previous releases.
What's New in 2026.0.1
User interface and workflow enhancements for 2026.0.1
A great deal of effort goes into improving the user interface and workflow for each release, based on feedback from you, our customers. Each year we send out surveys, release beta builds and encourage you to tell us about your experience so we can make it more enjoyable. We encourage you to let us know, via social media, product forums, surveys, or support, how we can help make your experience even better. CAD supported platform updates.
The following CAD file formats are also supported:
-    Alias 2026
-    Parasolid V37
-    SOLIDWORKS 2025
-    JT 10.10
-    NX 2406 Series
Mesh enhancements for 2026.0.1
This release fixes minor bugs to improve mesh quality, stability, and speed.
Solver Enhancements for 2026.0.1
The following enhancements to the analysis solvers provide you with better solutions and improved accuracy.
Simulation Compute Manager updates for 2026.0.1
The Moldflow job management system is known as the Simulation Compute Manager (SCM). The SCM has only one instance per system regardless of how many separate users are on that system. SCM 2.6 is installed by Moldflow Adviser 2026.0.1. Refer to Simulation Compute Manager Version 2.6 for What's New In SCM. If your machine's local firewall is active, refer to Opening firewall ports for SCM.
What's New in MDB 2026.1
The Moldflow Material Database update includes newly tested materials from both testing laboratories and material suppliers. It also incorporates updates to existing materials from suppliers and removes materials that are no longer available.
Outdated and Duplicated Materials
In this update, while we have incorporated newly tested materials, we have made a concerted effort to eliminate outdated and duplicated materials from the database. Consequently, a larger number of materials have been removed compared to previous updates.
Autodesk Moldflow simulation softwareprovides plastic injection molding and compression molding insights to improve manufactured part quality. Advanced tools and a simplified user interface help you address manufacturing challenges such as part warpage, cooling channel efficiency, material selection, and cycle time reduction.
Moldflow Adviseris the small and cost-effective solution for simulating the design during component development. The Adviser allows the simple import of CAD data from all common systems such as Catia, Creo or SolidWorks, as well as the fast simulation of the component - often only within a few minutes. Despite the extremely simple handling, the Adviser uses functions, solvers and, above all, the Autodesk Moldflow Insight material database, which contains over 10,000 data records.
Moldflow Insightprovides detailed material flow, cooling, and warpage results for both injection molding and compression molding processes. Additional control on materials, machines, molds, and processes is possible with Moldflow Insight. Automation with scripts/API accelerate setup and post-processing capabilities. Thermoplastic and thermoset materials are supported, along with customization of materials for part inserts and mold inserts. Advanced molding methods, such as gas-assisted injection molding, injection compression molding, co-injection molding, microcellular injection molding, and many more, are available to discover the best option for your part. Moldflow Insight also has advanced customization of the process including the ability to select the molding machine, specify valve gates, adjust mold materials, solve for a Design of Experiments (DOE) or parametric study, and much more.
Moldflow Synergyis the graphical user interface (GUI) while Moldflow Insight is the solver.  Both programs must be installed to analyze a model.
Autodesk Moldflow Mold Simulation
Workflow on importing and Analyzing complete Mold. Assigning attributes and creating 3D Mold Mesh. Cool FEM Analysis
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Uploady
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part1.rar
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part2.rar
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part3.rar
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part4.rar
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part5.rar
AutodeskMoldflowSimulationSoftware2026Update1.html
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part1.rar.html
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part2.rar.html
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part3.rar.html
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part4.rar.html
5bm0p.Autodesk-Moldflow-Simulation-Software-2026-Update-1.part5.rar.html
