05 de Abril de 2026, 13:35 *
Autor Tema: Fiedler Audio Spacelab Interstellar v1.5.14  (Leído 23 veces)
« : 03 de Octubre de 2025, 00:21 »
Free Download Fiedler Audio Spacelab Interstellar v1.5.14 | 50 Mb
The future of 3D reverb. Whether you produce music or mix for film/video, broadcast, games or VR/AR, Spacelab opens up a revolutionary new way of putting all of your tracks into the right acoustic perspective. Spacelab is more than just reverb, more than just panning and more than just spatial audio. It combines these three into one plugin because they naturally belong together.
Key Features
Ultra realistic room simulation, from small boxes to huge venues
Arbitrary speaker layouts, from mono to full sphere 3D-audio, with up to 256 speakers
Spectral and spatial sculpting of the reverb tail with the Spatial EQ
Reverb time separately adjustable on 9 frequency bands
Individual early reflection pattern for each object depending on its position, continuously changing when moving through space
Up to 256 inputs (objects), using the Spacelab Beam plugin to bypass routing limitation of your DAW
Full sphere binauralizer, monitor through and produce for headphones
Distance-dependent rendering of object motion and corresponding reverb changes
Automate snapshots to switch between different reverb settings throughout your session
Dynamic automation for simplifying complex automation of hundreds of parameters
Create individual speaker layouts with the speaker layout editor
Classic mode for send/return operation / Object mode for object based mixing
3D panning
Position your objects around the listener in the virtual room
3D-view for best overview of your object arrangement
Listener with 6 degrees of freedom, perfect for film and VR/AR
Individual dry/wet and spread for each source
Source Automation via Spacelab Beam
Dolby Atmos
Direct integration into our Dolby Atmos Composer workflow
MPEG-H
Export your work in the MPEG-H production format using the optional MPEG-H Exporter
https://fiedler-audio.com/spacelab-interstellar-immersive-3d-reverb/
Uploady
v6cx4.Fiedler.Audio.Spacelab.Interstellar.v1.5.14.rar
http://peeplink.in/a248acf1917b
v6cx4.Fiedler.Audio.Spacelab.Interstellar.v1.5.14.rar.html
