06 de Abril de 2026, 02:37 *
Autor Tema: Light Wrap Fantastic 1.3.0 (x64)  (Leído 46 veces)
« : 14 de Octubre de 2025, 19:32 »
Free Download Light Wrap Fantastic 1.3.0 (x64) | 35.4 Mb
The Light Wrap Fantastic enables better composites by easily allowing users to blend the background with the foreground in such a way that it appears the light of the background is affecting the foreground. Essentially simulating backlighting. The plugin has all the controls you need to create a realistic light wrap making it a quick and easy process.
A Plugin for More Convincing Composites
- Creating convincing green/blue screen composites has always been a challenge.
Fast and Easy
GPU acceleration allows the plugin to render HD and 4K footage quickly. It easily fits into whatever workflow you use when compositing with a variety of options and modes. This flexibility and speed make it the perfect choice for video editors, colorists and compositors.
Just One Plugin
Light Wrap Fantastic has everything you need to create a great light wrap in one plugin. Lighting, masking, and blend modes are just some of the features for better video compositing. You don't need to buy an expensive package with tools you don't need. It's all here in one plugin.
Easy compositing of green or blue screen
Light wrap simulates backlighting, making the compositing of two images look more realistic. Background light would normally affect the foreground in a real scene. Most green or blue screen footage looks 'cut out' when put on a different background because it lacks the same lighting as the background. The Light Wrap Fantastic makes it easier to eliminate the 'cut out' look.
LWF takes the background layer and 'wraps' it around the edge of the foreground, simulating backlighting. This makes for a more realistic green screen composite.
Control every aspect of the light wrap within one plugin
While it's usually possible to create a light wrap effect within most host applications, it requires multiple layers, masks and effects. The Light Wrap Fantastic simplifies this by giving you complete control in one plugin. This includes being able to mask the effect from within the plugin to simulate light coming from one direction.
Works with any blue or green screen plugin
It doesn't matter what blue/green screen keying plugin you use... Primatte, Keylight, Ultimatte... The Light Wrap Fantastic works great and will help you blend your foreground and background more realistically. If you've roto'd something with Mocha Pro or the like, LWF will make that look great too!
Fast Rendering using Your GPU
Fast rendering is essential to fitting into a your workflow. We use both CUDA and OpenCL to completely optimize the rendering for Nvidia and AMD GPUs.
Standalone Plugin that Fits Different Workflows
As a standalone plugin, it makes it much more affordable to get great green or blue screen composites! Since Light Wrap is so effective at improving composites, we wanted to make it available without needing to buy a whole keying package. Usually you end up paying for tools that already ship for free in your host application or that you don't need. This way you get the most powerful light wrap plugin available at a great price!
Requirements:
- Windows 10 and later
- Adobe After Effects and Premiere Pro CC 2019 and later
Homepage -
https://digitalanarchy.com
0nowu.Light.Wrap.Fantastic.1.3.0.x64.rar.html
