05 de Abril de 2026, 23:03 *
Autor Tema: ManicTime Pro 2025.2.3 Multilingual  (Leído 55 veces)
« : 14 de Octubre de 2025, 19:32 »
Free Download ManicTime Pro 2025.2.3 Multilingual Fast Links | 160.8 Mb
ManicTime allows you to keep up with your employees' work, send accurate progress reports, and manage your time better than ever before. This kind of software can help your business be more efficient when it comes to internal employee affairs as well as the external partnerships.
Automatic tracking
ManicTime automatically records your computer usage. It remembers which apps you've used and for how long. It will also remember which web sites you've visited and which documents you've worked on. All this data will help you keep track of your work hours.
Privacy
Data, which ManicTime collects, is stored on your machine and not sent anywhere. It is not shared with us or any third party and exists only on your machine.
Offline work
ManicTime is not a cloud based service, instead it uses a local datastore, so all recorded data will be kept on your machine. This also means that it will work the same with or without internet connection.
Accurate timekeeping
All the data ManicTime collects will be presented in a easy to understand graphical interface. This will help you to quickly figure out when you went to lunch and when you've switched tasks. From now on, your logged hours will be accurate and simple to track.
Easy timesheets
From the hours you logged its easy to create almost any kind of report. Once you create the report, you can easily copy it to Excel or some other tool and create an invoice there.
Integrate with other systems
ManicTime can integrate with task based systems, like Jira or GitHub. You can use ManicTime to enter your work hours, then send the timesheet back to specific issue.
Company wide reports
Use ManicTime in your company or your team. ManicTime Server will collect all data and generate useful reports.
Auto tagging
ManicTime captures a lot of data and you can use this data to create work activities. For example you can say that all facebook activity is "Browsing" and that all MS Word usage is "Work".
Away time
Equally important as tracking computer usage is tracking non usage. When you step away from the computer, ManicTime will track this as Away time. When you return, you can create a note of what you were doing during Away.
Stopwatch
Even though ManicTime excels at automatic time tracking, you can still use a stopwatch to manually track your time.
https://www.manictime.com/
z29fu.ManicTime.Pro.2025.2.3.Multilingual.7z.html
