05 de Abril de 2026, 19:40 *
Autor Tema: SysTools Outlook Recovery 9.2 Multilingual  (Leído 83 veces)
« : 14 de Octubre de 2025, 19:50 »
Free Download SysTools Outlook Recovery 9.2 Multilingual Fast Links | 92.1 Mb
Software to recover Outlook PST data and safely restore all lost Emails, Contacts, Calendars, Tasks, Journals etc. with 100% integrity. The SysTools Outlook PST Recovery advanced scan mechanism can parse highly corrupted PST file and reconstruct mailbox data with high precision. And save recovered Outlook data in a PST, EML, MSG, PDF, HTML or in Office 365.
Overcome All Common Scenarios
- Error has been detected in PST file
- File is not a Personal Folders File
- Outlook cannot open the data file
- xyz.pst has reached maximum size limit
- Outlook.pst was not cleanly closed
- Cannot start Microsoft Outlook
- Oversized PST file corruption issues
- Outlook file xxx.PST could not be found
- Scanpst repaired PST is empty
- Outlook reported error 0x8004010f
- Outlook can't start in Safe mode
- Outlook PST Unreadable Email issue
Deleted Outlook Email Recovery
Using Outlook PST Recovery tool, users can repair Outlook PST files & quickly recover damaged Outlook files. This PST Fix tool can easily recover permanently deleted emails in Outlook PST file items which includes contacts, calendars, tasks, notes, journals, etc. One need to choose Advanced Mode to recover deleted Outlook emails in bulk. The tool previews recovered deleted emails in Red Color in the preview panel. Read More on Outlook PST Repair tool
Fix & Restore PST File as Outlook email recovery wizard
Outlook Recovery Software allows to import PST to Office 365 - user mailbox, admin mailbox and shared mailbox. Move PST file items to the desired destination mailbox of Outlook email recovery wizard account just via entering account ID & password. SysTools PST Recovery will validate the credentials and migrate the selected data items directly. With user impersonation option, it exports items to a shared mailbox.
Batch PST File Recovery
The Outlook Recovery Wizard supports to search multiple PST files from any drive on your local system. Once the entire searching is completed, you can check multiple PST files to repair multiple PST files at once. This provides advanced functionality to repair severely damaged PST Files in Batch Mode quickly using Search All Drive or Search Selected Drive option.
Outlook PST Repair Modes
To repair Outlook archive PST or scanPST bak file; software quickly scans a selected file automatically to repair damaged Outlook PST file. The application then loads the preview of emails with attachments, contacts, calendars, tasks in Personal Storage File (.pst). However, if the PST or BAK file has a severe level of corruption then you are recommended to go for Advance Scan mode.
Save as PST / PDF/ EML / MSG / HTML
After performing Outlook PST recovery, you can restore Outlook PST file in .pst, .pdf, .eml or .msg formats. Repair Outlook data file .pst and saving it as EML, HTML & MSG will allow you to open & read emails in Windows Live Mail & Outlook respectively. Outlook Recovery provides the option for selective export items.
Supports Embedded Attachments
The software is designed in a smart way that it facilitates users to recover the embedded attachments also. These attachments are recovered as a normal attachment by this Outlook Recovery application. The formatting of recovered embedded attachment retains as original after PST file recovery.
Remove Encryption from Outlook Email
The Outlook PST Recovery Tool provides the option to decrypt & remove SMIME / OpenPGP encryption from Outlook email messages. The software decrypts protected emails with its respective certificates, keys, and passwords. The tool also previews SMIME or OPENPGP encrypted emails and save them in PST, PDF, MSG, HTML, and in Office 365 account without encryption. This PST Repair & Recovery utility allows bulk decryption of Outlook email messages along the attachments.
Email Preview in 8 Formats outlook repair application
The SysTools PST repair Tool can generate an instant preview of PST items like Mails, contacts, calendars, tasks, notes, journals, etc separately in the panel. SysTools Outlook Recovery tool allows to view PST file emails in Normal, Hex, MIME, Message Header, HTML, RTF formats along with its properties in the in-built viewer. PST recovery Tool can also preview all the attachments that are recovered from an Outlook PST or BAK files. Detailed Email previews help to users to analysis it technically.
Select & Recover Outlook BAK File
The application can also be called as a Outlook.BAK file Recovery Tool. The user can select a corrupted Outlook.bak file (created by ScanPST.exe) directly using Select File / Search File option. The software will scan, repair and load all retrieved data items from the selected Outlook BAK file in the preview panel. You can save this recovered BAK files data items into a PST or PDF, EML, MSG, HTML, etc. Make sure, you have selected BAK file (backup of Outlook PST file) generated by Inbox repair Tool before loading it in software.
Repair PST and Save in PDF Format
This PST Recovery tool allows to recover and repair PST file data items like emails, contacts, calendars, tasks, notes, journals, etc. along with attachments. You can save these retrieved PST data items in Adobe PDF format. The utility provides various advanced settings option like, date filter, naming option, messgae header inclusion, Page Layout (Margin, Paper Orientation, Size) & Bates Number (Format, Date Stamp, Position) settings. Export repaired and recovered data from a corrupted PST file to PDF format easily without data loss.
Flexible & Useful Naming Options
Outlook PST recovery tool allows you to rebuild PST file as EML, PDF, HTML or MSG file formats then you can select one of the multiple naming options available to save emails for better manageability.
Filter and Sort Items Option in Preview
After performing complete PST file recovery, the Outlook Recovery utility displays a list of complete recovered PST data. Now users can sort the data items on To, Cc, Bcc, Subject etc. (for mails) & export desired items. The date filter option sets a date range & filter emails to recover PST file and restore Outlook PST as PST / EML / HTML or MSG. This option within the Outlook Recovery Wizard helps to save selective data in a date range specified after fixing damaged Outlook PST files.
Recover & Preview Items with Metadata
Once the PST file recovery process gets completed successfully, the tool lists all the recovered items along with their meta properties intact. Users can sort the data items directly from the preview pane using this meta-data. Also, one can preview and recover all the email data like To, Cc, Bcc, Subject, Contacts (Personal and Contact Details), Calendar, Tasks, Notes, and Journals along with their attributes.
Retains Read & Unread Email Status
The Outlook PST Recovery software performs complete recovery of lost email items from loaded PST file. After successful Outlook Email Recovery, when users access recovered PST in MS Outlook, all the mailbox folders will be managed with read and unread count as it was in the original PST file. This is a helpful option provided by the tool, as the users won't face difficulty while using the recovered PST data.
Selective Export for Data Items
The application provides 'Export Selected' option to save selected items (like a single email message) in required format. You can also Save Outlook folders selectively like Inbox, Drafts, Sent Items etc locally. You need to check / uncheck the PST folders to be saved. i.e, Outlook PST recovery tool not only allows to export repaired PST file items in bulk, but it also provides option to selectively export specific items from PST file.
Retrieve Distribution List In Outlook
Users spend so much of their time in assembling an Outlook Distribution List and the accidental deletion of this list feels like a major catastrophe. However, with SysTools Outlook Recovery Tool it is very simple to recover permanently deleted distribution list of MS Outlook PST data file. The software recovers all components of a distribution list such as All Members, Email Addresses, Contacts etc. without any data loss.
Option to Divide Large PST
You can break the PST ✅File Size into smaller parts with split PST option, and recover Outlook PST file. Select any required size in MB or GB (Minimum 100MB and Maximum 45 GB) & create PST's of same sizes that are easier to manage. This Microsoft Outlook PST Repair tool helps to rebuild Outlook PST data files without corruptions and errors into multiple smaller PST data files.
Outlook Style Interface
Graphic interface of the Outlook PST repair tool to fix PST files resembles Microsoft Outlook UI (User Interface). The similar appearance of Microsoft Outlook 2016 / 2019 interface on software panel makes it more user-friendly for all kind of users. So this Outlook PST Recovery Software enables naive and non-technical users to repair PST file from Outlook without any confusions.
Provide Ignore System Folder Option
The software includes Ignore System Folder option that can be used to avoid or exclude the 'Top of the personal folder' in the ROOT (Non-Imp Subtree) folder that comprises Common Views, Favourites, Finder, Freebusy Data, Recoverable Items etc. In addition, it keeps the successive folder intact or unchanged.
Maintain Folder Hierarchy
The feature helps the user to saves Outlook PST Data items like emails, contacts, calendars, tasks, notes, journals according to same folder hierarchy as they are saved in source file. The order and name of files and folders will not be changed even after saving PST files into PST, PDF, MSG, EML, HTML or in Outlook email recovery wizard using this feature.
Save Export Report
Once all the items get successfully exported into required file format, the Outlook PST Repair software will generate an Export Report. It provides the success and failure count of items after complete PST data Recovery & Export process. You can also save this Export Report regarding the details of recovered damaged Outlook PST files as .csv for future reference by specifying the destination location.
Don't Export Empty Folders outlook repair application
The Outlook PST Recovery Tool provides "Don't Export Empty Folders" option for the users to exclude or delete Empty Folders in original PST file. For this, you need to Uncheck the "Maintain Folder Hierarchy" option and check "Don't Export Empty Folders" option for not saving folders which do not contain any data. By enabling this facility, the application will skip all the folders that are empty during the export process.
Microsoft Windows - 7 / 8 / 8.1 / 10 (32-Bit & 64-Bit), Windows 11 (64-Bit), & Windows Server 2008 / 2012 R2 / 2016 / 2019
Microsoft Outlook - 2000, 2003, 2007, 2010, 2013, 2016, 2019, 2021 (32-Bit & 64-Bit)
Office 365 - Enterprise E1 / E3 / E5 / Business Premium / Essentials & Exchange Online Plan 1 / Plan 2 & Office 365 A1 / A3 / A5 / F1
https://www.systoolsgroup.com/
o95o3.SysTools.Outlook.Recovery.9.2.Multilingual.rar.html
