05 de Abril de 2026, 17:17 *
Autor Tema: OpenBridge Designer 2024 Update 2 v24.00.02.015 Win x64  (Leído 51 veces)
« : 15 de Octubre de 2025, 11:59 »
Free Download OpenBridge Designer 2024 Update 2 v24.00.02.015  | 5.2 Gb
OpenBridge Designer 2024 Update 2 v24.00.02.015 Win x64 is the latest integrated solution from Bentley Systems for bridge design, analysis, and construction modeling. This version combines the power of OpenBridge Modeler and LEAP Bridge Concrete/Steel into one seamless application, providing engineers with advanced tools for parametric modeling, structural analysis, and detailed documentation. With improved performance, enhanced interoperability, and full BIM integration, OpenBridge Designer 2024 Update 2 streamlines the entire bridge lifecycle - from concept to construction - ensuring accuracy, efficiency, and compliance with global standards.
Category: Software / Civil Engineering / Bridge Design
Bentley Systems Inc.has releasedOpenBridge Designer 2024 Update 2 (24.00.02.015)is a unique application that combines modeling, analysis, and design into one comprehensive bridge product. This minor release includes fixes and optimizations to existing tools and software security
Owner:Bentley Systems Inc.
Product Name:OpenBridge Designer (OBD)
Version:2024 Update 2 (24.00.02.015)
Supported Architectures:x64
Website Home Page :www.bentley.com
Languages Supported:english
System Requirements:Windows *
The major release  and its components OpenBridge Modeler (OBM), RM Bridge (RMB), LEAP Bridge Concrete (LBC), and LEAP Bridge Steel (LBS) includes many new enhancements and improvements to existing tools and software security.
What's new in OpenBridge Designer 2024.00.02
This release fixes the 2024 Update 1 OpenRoads Circular Referencing of DGNs issue.  Files from older versions are automatically upgraded when opened in this newer release. This release automatically evaluates and heals files to ensure they are not impacted by the issue from 2024 Update 1. When a file is detected as previously opened with 2024 Update 1, the software will evaluate and heal it if required. One of four dialogs will appear based on the success of the healing process. See this section from help file for more details.
OpenBridge Designer 2024.00.02 (OBD 2024.00.02) and its components OpenBridge Modeler (OBM), RM Bridge (RMB), LEAP Bridge Concrete (LBC), and LEAP Bridge Steel (LBS) contains the following error corrections.
Enhancements
This release is primarily a maintenance release.
Technology Stack
MicroStation PowerPlatform (v24.0.2.383)
Civil Platform (24.0.2.18)
OpenRoads 2024 (v24.0.1.62)
ProStructures 2024 (24.0.2.10)
Certified with PW v 24.0.01.8001
Generative Components (24.0.2.10)
GINT (24.0.2.7)
Descartes (24.0.2.38)
CONNECTION Client (24.01.02.06)
RM Bridge Enterprise
This release is primarily a maintenance release only.
Error Corrections in The Components
OpenBridge Modeler:
The list of issues fixed are as below:
-        Updated Visual C++ RedistributableLibrarysupporting Visual Studio 2022
-        Input Echo Report missing segment material input
-        Material details missing from Input Echo Report
-        Build order missing in Segments table
-        Missing material details for Steel used for Steel girder definition
-        2024 Update 1 OpenRoads Circular Referencing of DGNs isue
RM Bridge
-        D D E - Dynamic Data Exchange > Stages and Tendon Actions - There was a mistake in the report generated by this DDE module; especially, "dl" and "l" quantities were reported wrong. The same report (stress.lst) is also produced by the solver during analysis where these were reported correctly. Now this has been addressed.
-        While importing RM TCL file, parser used to crash, without any indication why, if there was a missing keyword, "BEGIN" next to "RMSCHED". Now this has been fixed. It is not always necessary to use "BEGIN" keyword. The program assumes its presence in the absence of it.
-        Analyzer > Properties > Variables > EC8_DESIGN_SPEC > EC8d_sd_Tab > EC8d_TD - There was a mistake in generating Elastic Design Spectrum based on EN 1998-1 when equations 3.15 or 3.16 governed. The limits of these two equations do not involve multiplying with S (defined in 3.2.2.2). In previous versions, by default, Swas multiplied along with the product of b and ag.
-        IRC-112:2020 has the wrong formula for Relative Humidity, BetaRH. RM Bridge also implemented the wrong expression in the variables that need correction. The formula got corrected in errata later on. RM Bridge needed to adapt to that correction.
Wrong expression was,
BetaRH = -1.55 (1 - RH/100)^3
which will be,
BetaRH = -1.55 (1 - (RH/100)^3)
-        Training Examples were not available in the latest v.24.00.01.* out in the market. Now this is fixed. Also, the links shown on the training page were not accessible. Now those links are effective and lead to proper YouTube videos.
-        Analyzer > View Options > Draw RmSet - This option used to crash the application. This is now addressed.
-        Certain Bridge models generated using Wizard were making the application to crash. This is now fixed.
-        Analyzer > Results > Load Cases > Diagram (lower right corner) - PDF report generator was always throwing error when accessed from Diagram window. This has been addressed now.
None
-        The program crashed due to uninitialized variables being used to store cross-frame data in LEAP Bridge Steel.
-        The analytical model of a steel plate girder bridge with pile bents was created incorrectly in LEAP Bridge Steel due to an error in the exchange of a spiral alignment dataset when the physical model was transferred from OpenBridge Modeler.
OpenBridge Designeris a unique application that combines modeling, analysis, and design into one comprehensive bridge product. The application utilizes the modeling capabilities of OpenBridge Modeler and the analysis and design features of LEAP Bridge Concrete, LEAP Bridge Steel and RM Bridge to meet the design and construction needs of all types of bridges. OpenBridge Designer offers direct interoperability for analysis and design, produce detailed reports, clash detection and construction simulation, quantities, geometry reports, and more. The application provides 3D parametric modeling, analysis, and load-rating software for bridges. Integrates with OpenRoads design applications, ProStructures for concrete rebar detailing and LumenRT for leveraging enhanced visualization.
What is New in OpenBridge 2024
Overview of the new enhancements in our OpenBridge Designer and OpenBridge Modeler 2024 release
Bentley Systems Inc.is a software development company that supports the professional needs of those responsible for creating and managing the world's infrastructure, including roadways, bridges, airports, skyscrapers, industrial and power plants as well as utility networks.  Bentley delivers solutions for the entire lifecycle of the infrastructure asset, tailored to the needs of the various professions.
Conclusion:
OpenBridge Designer 2024 Update 2 v24.00.02.015 delivers a powerful, unified platform for bridge engineers and infrastructure professionals. Featuring faster workflows, smarter modeling tools, and comprehensive analysis capabilities, it enables users to design and manage complex bridge projects with confidence. Download this latest version today to experience the next level of bridge design and construction innovation with Bentley OpenBridge Designer 2024
Uploady
som0d.OpenBridge-Designer-2024-Update-2-24-00-02-015.part1.rar
som0d.OpenBridge-Designer-2024-Update-2-24-00-02-015.part2.rar
http://peeplink.in/78645f3de4b8
som0d.OpenBridge-Designer-2024-Update-2-24-00-02-015.part1.rar.html
som0d.OpenBridge-Designer-2024-Update-2-24-00-02-015.part2.rar.html
