Free Download OpenTunnel Designer 2024 Update 2 v24.00.02.006 Win x64 English | 3.8 GbOpenTunnel Designer 2024 Update 2 v24.00.02.006 Win x64 English is the latest release from Bentley Systems, offering a comprehensive solution for tunnel design, analysis, and documentation. Built on the proven Bentley Open modeling environment, this version integrates seamlessly with other civil engineering tools such as OpenRoads and OpenRail, enabling multidisciplinary collaboration. With enhanced 3D modeling capabilities, geotechnical data integration, and precise alignment tools,
OpenTunnel Designer 2024 Update 2 helps engineers design safer and more efficient tunnels with reduced risk and optimized workflows. The updated version delivers better performance, improved visualization, and full BIM compatibility.
Category: Software / Civil Engineering / Tunnel Design
The
OpenBuildings development teamis pleased to announce the availability of
OpenTunnel Designer 2024 Update 2 (24.00.02.006)is the first and only purpose-built software for tunnel modeling and design
Owner:Bentley Systems Inc.
Product Name:OpenTunnel Designer
Version:2024 Update 2 (24.00.02.006)
Supported Architectures:x64
Website Home Page :www.bentley.comLanguages Supported:english
System Requirements:Windows *
contains error corrections, and also includes many new enhancements and improvements to existing tools and software security.What's new in OpenTunnel Designer 2024.00.02This minor release includes de fix for the civil issue from 2024 update 1. Files from older versions are automatically upgraded when opened in this newer release. This release automatically evaluates and heals files to ensure they are not impacted by the issue from 2024 Update 1. When a file is detected as previously opened with 2024 Update 1, the software will evaluate and heal it if required. One of four dialogs will appear based on the success of the healing process. The following is a summary of some of the key features available in the 2024.00.02 release.
Key Features- Model conventional and TBM tunnels (including universal tapered rings)
- Model linear transition (lofting) tunnels for conventional tunnel type
- Model excavation subspaces for conventional and TBM tunnels
- Model reinforcement for conventional tunnels
- Model shotcrete for TBM tunnels
- Estimated quantities and cost reports
- Generate i-models with engineering attributes
- Create construction stages
- ProjectWise integration
- Built on MicroStation PowerPlatform Update 24.00.02 (2024.00.02.62 release)
- Built on Civil Platform (OpenRoads Designer) 2024.00.02 release
- Optional install of Lumen RT from Software Downloads
- Certified with ProjectWise 2023 or Higher
OpenTunnel Designer (OTD) 2024.00.02 contains the error corrections mentioned in the following paragraphs.
Fixed the issue that caused 2024 Update 1 to be removed, which was related to circular referencing of DGNs in child or derived profiles. Not all files opened with 2024 Update 1 were affected.
2024 Update 2 now automatically scans and repairs affected DGN files when opened, making sure they are not affected by the previous issue. If a file was previously opened with 2024 Update 1, the software will check and fix it if needed. One of four dialogs will appear depending on whether the repair is successful.
- The file was not affected by the issue.
Close
- The file was affected and has been successfully repaired.
Close
- The file was affected and has been repaired except for some objects that need to be recreated if they are still needed. These objects are shown in bold red and grouped for easy identification.
Close
- The file was affected and has been repaired, but some pre-existing issues remain. It should still be fine to use. If problems arise, contact support.
Close
OpenTunnel Designeris a comprehensive tunnel information modeling application built on OpenRoads technology addressing the geometric layout, connection to analysis and design, visualization and documentation for conventional and mechanized (TBM) tunnels at any scale of tunnel project. Built using MicroStation CONNECT Edition PowerPlatform and the Civil Framework technology, it allows you to collaborate more efficiently across disciplines, facilitating data re-use across the tunnel life cycle from concept to design and analysis to construction, and all the way to maintenance and operations. OpenTunnel Designer features several custom modeling tools geared to rapidly build accurate physical tunnel models, tied together parametrically, allowing for instant updates to the tunnel based on potential changes to roadway/rail geometry. OpenTunnel Designer leapfrogs the need for proficiency in 3D drafting, by allowing you to parametrically define, re-use and assemble components making the tool easy to use for tunnel, structural engineers as well as roadway/rail engineers. Preliminary cost estimates provide quick insights into structure costs, and you can quickly leverage the tools in the product to rapidly develop realistic renderings for project pursuits or public presentations.
What's New in OpenTunnel Designer 2024Bentley Systems Inc.is a software development company that supports the professional needs of those responsible for creating and managing the world's infrastructure.
Conclusion: OpenTunnel Designer 2024 Update 2 v24.00.02.006 provides tunnel engineers with a powerful and reliable platform for modern infrastructure projects. Featuring advanced modeling, automation, and analysis tools, it simplifies complex workflows and enhances design accuracy. Download this latest version today to experience a smarter, more integrated approach to tunnel engineering with
Bentley OpenTunnel Designer 2024.
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeUploadyasue6.OpenTunnel-Designer-2024-Update-2-24-00-02-006.part1.rarasue6.OpenTunnel-Designer-2024-Update-2-24-00-02-006.part2.rarRapidgatorhttp://peeplink.in/9fe0362e6130Fikperasue6.OpenTunnel-Designer-2024-Update-2-24-00-02-006.part1.rar.htmlasue6.OpenTunnel-Designer-2024-Update-2-24-00-02-006.part2.rar.htmlFreeDLasue6.OpenTunnel-Designer-2024-Update-2-24-00-02-006.part1.rar.htmlasue6.OpenTunnel-Designer-2024-Update-2-24-00-02-006.part2.rar.htmlLinks are Interchangeable - No Password - Single Extraction
