05 de Abril de 2026, 21:26 *
Autor Tema: PTC Creo View 12.1.0.0 Win x64 Multilanguage  (Leído 49 veces)
« : 15 de Octubre de 2025, 12:00 »
Free Download PTC Creo View 12.1.0.0 | 2.1 Gb
PTC Creo View 12.1.0.0 Win x64 Multilanguage is the latest version of PTC's powerful visualization and collaboration software for 3D CAD models and product data. This release enables engineers, designers, and stakeholders to easily view, analyze, and share complex 3D designs without requiring the full CAD application. With enhanced performance, multi-format compatibility, and multilingual support, Creo View 12.1.0.0 improves communication and reduces design errors across teams. The intuitive interface, advanced markup tools, and integration with Creo Parametric make it an essential solution for efficient product lifecycle management (PLM).
Category: Software / CAD CAM / 3D Visualization
Languages Supported:  English, Deutsch, Français, Italiano,
Español, 日本語, 中文, 한국어, Português, Русский.
PTChas released Creo View 12.1.0.0 is a simple but powerful enterprise visualization technology that enables virtually effortless collaboration across local and global design teams.
Owner:Parametric Technology Corp.
Product Name:Creo View
Version:12.1.0.0
Supported Architectures:x64
Website Home Page :www.ptc.com
System Requirements:Windows *
Creo View 12.0 Key Highlights
Creo View 12.0 (Clients & Toolkits)
-    Removal of Native PDF License Requirement
-    Removal of the Massive Assembly License
-    Markup Creation in Creo View Express
-    Export Drawing Files to PDF with Embedded Simple Markups
-    Display Part and Branch Link Loading Issues
Creo View Adapters 12.0
-    Publishing Capabilities Using Microsoft Office 2024
-    TIFF Output Compatibility in Creo Elements/Direct Drafting
-    Optimized PDF Sheet Sequencing for NX Multi-Sheet Drawings
-    Enhanced Word Document Publishing with Bookmarks Conversion
-    Excel Publishing with Advanced Scaling Options
-    Multi-Byte Files Publishing Support with Adapter for Office Worker
-    Custom Font Support for Office-Based Publishing
-    Enhanced 3D Thumbnail Generation Using PVSThumb
-    2D Thumbnail Generation Improvements
-    Custom Properties Publishing for SolidWorks
-    Application Support Updates
What's new in Creo View MCAD
Improved PDF Print Quality
Description
Printing from the native PDF viewer now creates higher quality output. Now the document is directly sent to the printer without requiring rasterization, improving the quality of the output.
Benefits
Enhanced print quality when using the native PDF viewer.
Full Support for Exporting Drawing Markups to PDF
Description
All markup types are now included in the drawing-to-PDF export. Measurements and construction geometry are now supported in PDF exports.
Benefits
All Creo View markups in the drawing view are now included when exporting 2D drawings to PDF.
End of Support for Office 2019 in Creo View Office Toolkit
Microsoft will end support for Office 2019 in October 2025. In alignment with this, starting with this release, Creo View Office Toolkit will no longer support Office 2019.
What's new in Creo View ECAD
Collaborative Solder Mask Support in ECAD Visualization
Description
Creo View ECAD now supports collaborative solder mask workflows, enhancing ECAD-MCAD collaboration. This feature allows users to visualize, compare, and validate solder mask areas defined in ECAD designs. With this release:
- Creo View ECAD parses solder mask attributes, such as layer, ID, type, owner tool, from IDX/EDA files.
- ECAD Compare supports attribute, geometry, and placement comparisons for solder masks, with configurable presets and detailed reports.
- ECAD Validate displays solder mask transactions from incremental IDX files, with full interaction and cross-selection with Creo Parametric.
Benefits
- Streamlined board-level collaboration.
- Improved design accuracy.
- Ensured traceability of solder mask changes across domains.
What's new in Creo View MCAD Adapters
OAuth2-Based Authentication for File Synchronization Worker in Windchill
Description
As Single Sign-On (SSO) adoption grows in Windchill environments, traditional IP-based Trusted Host authentication for remote CAD workers has become outdated and less secure. Starting with Windchill 12.1.2, the old method is deprecated. Windchill 13.0.2 introduces a secure, modern alternative-OAuth 2.0 with Client Credential Grants (CCG). Creo View Adapter 12.1 now supports this capability for Creo Parametric workers. CAD workers can be configured with SSO using OAuth CCG, enabling secure, scalable, and standards-compliant authentication for publishing workflows. This enhancement simplifies the setup, strengthens security, and aligns with the best practices of enterprise authentication.
Benefits
- SSO support for worker configuration simplifies secure workflow publishing using the OAuth-based authentication.
- Enhanced UI allows users to easily enter OAuth parameters for a seamless SSO setup.
- Improved security and integration align with enterprise-grade standards, reducing manual handling of credential, and improving interoperability.
Expanded Export Formats for 3D Models and Drawings
Description
Starting with this release, Creo View Adapter for Creo Parametric supports exporting to a broader range of file formats as additional output options:
- 3D Data-Supports export to 3MF and CGR formats.
- Drawings-Supports export to Medusa, Sthenos, and TIFF formats.
- TIFF Export-Available as both a default and additional format for enhanced flexibility.
Benefits
- Greater flexibility with output formats-Supports diverse workflows and external system integration.
- Improved compatibility-Facilitates sharing and archiving with widely accepted formats.
- Streamlined publishing-Reduces post-processing and format conversion efforts.
Improved Visualization of Holes and Blends in PVZ Models
Description
Before the Creo View Adapter 12.1 release, PVZ models displayed holes and blends as square shapes, reducing visual fidelity and causing confusion. This issue is now resolved: holes and blends are rendered accurately, preserving geometry and improving clarity.
Benefits
- Accurate representation-Enhances visual accuracy for reviews and downstream processes.
- Improved user confidence-Reduces misinterpretation during analysis and collaboration.
- Streamlined workflows-Minimizes manual verification and corrections.
Built-In Startup and Maintenance Scripts for CAD Workers
Description
Starting with this release, Creo View Adapter for NX, Inventor, and SolidWorks includes basic startup and maintenance scripts by default. For example, the SolidWorks worker directory includes a swstartup.bat file. This script runs automatically during each worker start or restart. By default, it deletes the WWGM cache located at\.wf, as defined by the PTC_WF_ROOT variable in the worker configuration.
Benefits
- Automated maintenance-Ensures consistent cleanup and environment readiness.
- Customizable scripts-Can be extended for additional setup or cleanup tasks.
- Improved stability-Reduces issues from leftover cache or temporary files.
Support for the following application versions is added:
- Creo Parametric MORs 10.0.9.0, 11.0.5.0 and 12.4.1.0
- NX 2506
- Inventor 2026
Support for the following application versions is removed:
- NX 2206
- Inventor 2023
Removal of Microsoft Office 2016 and 2019 Support
Microsoft will retire support for Office 2016 and Office 2019 in October 2025. In alignment with this, starting with Creo View 12.1, the Adapter for Office will no longer support these versions for publishing workflows. This change ensures compatibility with the latest Microsoft security and performance standards.
What's new in Creo View ECAD Adapters
ECAD Application Support Updates
- Siemens EDA EDM 2409
- Siemens EDA PADS Layout 2409
- Siemens EDA PADS Logic 2409
- Siemens EDA xDX Designer 2409
- Siemens EDA Xpedition PCB 2409
- Siemens EDA EDM VX.2.12
- Siemens EDA PADS Layout VX.2.12
- Siemens EDA PADS Logic VX.2.12
- Siemens EDA xDX Designer VX.2.12
- Siemens EDA Xpedition PCB VX.2.12
Creo Viewis a simple but powerful enterprise visualization technology that enables virtually effortless collaboration across local and global design teams. Access to multiple forms of engineering data including 3D CAD models, 2D drawings, electrical schematics, and printed circuit boards both interactively at your desktop or through augmented reality (AR) allows design authors, project managers and downstream suppliers to quickly and easily access and share information between themselves and other stakeholders. Creo View makes the comparison and validation process easy, with single-view interrogation of mechanical and electrical design, project and part data. With Creo View, you're on the way to faster and higher quality design reviews, improved user and extended design team collaboration, and higher quality products at a lower cost.
Creo View Best Practices
This webinar provides a comprehensive overview of the Creo View toolset, ensuring attendees have a solid understanding of its capabilities and functionalities. The session will delve into various use cases and roles for the software, illustrating how different professionals can leverage Creo View to enhance their workflows.
PTChas the most robust Internet of Things technology in the world. In 1986 we revolutionized digital 3D design, and in 1998 were first to market with Internet-based PLM. Now our leading IoT and AR platform and field-proven solutions bring together the physical and digital worlds to reinvent the way you create, operate, and service products. With PTC, global manufacturers and an ecosystem of partners and developers can capitalize on the promise of the IoT today and drive the future of innovation.
Conclusion:
PTC Creo View 12.1.0.0 Win x64 Multilanguage delivers a streamlined and efficient approach to 3D visualization and collaboration. Whether you're working in product design, engineering review, or manufacturing, this version provides the tools you need to inspect, annotate, and share models effortlessly. Download it today to experience faster workflows, improved compatibility, and superior design visualization with Creo View 12.1.0.0
Uploady
rj4zz.PTC-Creo-View-12-1-0-0.rar
http://peeplink.in/992a5ffd68a9
rj4zz.PTC-Creo-View-12-1-0-0.rar.html
