Free Download Golden Software Surfer 30.1.218 (x64) Portable Fast Links | 280 MbSurfer is a contouring and 3D surface mapping program that runs under Microsoft Windows. It quickly and easily converts your data into outstanding contour, 3D surface, 3D wireframe, vector, image, shaded relief, and post maps. Virtually all aspects of your maps can be customized to produce exactly the presentation you want. Producing publication quality maps has never been quicker or easier.
Surfer contour maps give you full control over all map parameters. You can accept the Surfer intelligent defaults to automatically create a contour map, or double-click a map to easily customize map features.
Display contour maps over any contour range and contour interval, or specify only the contour levels you want to display on the map. And with Surfer you can add color fill between contours to produce dazzling displays of your maps, or produce gray scale fills for dramatic black and white printouts.
Key features of "Surfer":
· Contour Maps
· 3D Surface Maps
· 3D Wireframe Maps
· Vector Maps
· Image Maps
· Shaded Relief Maps
· Post Maps
· Base Maps
· Map Overlays
· Gridding
· Variograms
· Faults and Breaklines
· USGS DEM Files
· Digitize Boundaries
· Active X Automation
· Worksheet
· Object Manager
System requirements:Windows 7, 8 (excluding RT), 10 or higher
32-bit and 64-bit operation system support
1024x768 or higher monitor resolution with minimum 16-bit color depth
At least 500 MB free hard disk space
At least 512 MB RAM
Home Page-http://www.goldensoftware.com/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator989f1.Golden.Software.Surfer.30.1.218.x64.Portable.zip.htmlFikper989f1.Golden.Software.Surfer.30.1.218.x64.Portable.zip.htmlFreeDL989f1.Golden.Software.Surfer.30.1.218.x64.Portable.zip.htmlLinks are Interchangeable - No Password - Single Extraction
