Free Download Autodesk InfoWorks ICM 2026.2 | 3.3 GbAutodeskhas released
InfraWorks ICM 2026.2is a powerful, integrated catchment software for modeling simple to complex hydraulic and hydrologic network elements quickly and accurately in a collaborative environment.
Owner:Autodesk Inc.
Product Name:InfoWorks ICM
Version:2026.2 Ultimate
Supported Architectures:x64
Website Home Page :www.autodesk.comLanguages Supported:english
System Requirements:Windows **
The accuracy of hydraulic models has dramatically increased in recent years as innovations in hydraulic modeling solutions have put more and more power into our hands. However, as is often the case, with increased modeling accuracy comes slower simulation times because of the heavier computations that need to be performed. InfoWorks ICM 2026 brings new workflows for speeding up hydraulic modeling through mesh simplification. Subgrid Sampling is a feature that allows you to optionally use larger mesh elements in your model while still capturing highly accurate and detailed topographical changes in your surface. We've developed this using depth-volume variations within larger mesh elements to maintain the accuracy of a finer mesh. If you don't need a finer mesh, you can speed up your hydraulic simulations by reducing complexity.What;s new in InfraWorks ICM 2026.2This topic lists any bugs that have been fixed between versions 2026.1 and 2026.2 of InfoWorks ICM.
The fixes listed below are those that are viewed as likely to impact on users in an unexpected way, mainly changed simulation results, or differences in behaviour that might not be obvious.
Remote meshing- A regression introduced in release 2026.0 meant that meshes generated remotely could no longer be loaded into a network. This has been corrected.
Importing rain gauge boundaries from shapefiles- It is now possible to import rain gauge boundaries from a .shp file where the profile ID is a large integer.
Japanese localisation- A glitch in our localisation process meant that the Japanese version of the software suffered from a poor re-translation in 2026.1. The translations from 2026.0 have been reinstated.
Continuous curb openings- The calculation of total interception length for continuous curb openings that have depressions has been corrected. In previous versions, it was assumed assumed that the equivalent cross slope (Se) was always the same as the actual cross slope (Sx). This is not the case if there is a depression.
XPSWMM import of rain gages- Rain gage IDs imported from XPSWMM are now correct when there is a space in the ID.
Cloud databases with many commits- An "Unable to duplicate file handle" error when trying to open a network with more than 8186 commits in a cloud databa se has been fixed.
Conversion of SWMM ponded area to InfoWorks floodable area- Ponded areas in SWMM networks in square feet are now converted to the correct units when importing into InfoWorks networks as floodable area.
- Conversion to InfoWorks networks of SWMM nodes with a surcharge depth-
- When importing from SWMM into an InfoWorks network, nodes with a positive surcharge depth are now converted to flood type "Stored" and assigned a flood depth.
SWMM import of external time series files- Some issues with the import of external time series files from SWMM have been fixed.
Import of SWMM outfalls with tide gates- SWMM outfalls with tide gates are now imported to the correct geographical location in InfoWorks networks.
SWMM time patterns- The first item in a SWMM time pattern can now be selected.
Import of SWMM network into InfoWorks network- A further fix has been made to the creation of duplicate runoff surfaces when importing from SWMM to InfoWorks.
Converting sideflow weirs from SWMM to InfoWorks- The Weir Crest height is now converted correctlyfrom SWMM network to InfoWorks network for 'SIDEFLOW' type.
Pre-processing of water quality simulations- A bug causing pre-processing to fail when having potency factors are defined but no non-attached pollutants present has been fixed.
HEC-RAS import- A bug in the import of section data from HEC-RAS has been fixed.
XPSMM import- Performance of the XPSWMM importer has been improved when there is a large amount of data that cannot be handled by InfoWorks.
HYDX import- A crash in the HYDX importer when a link is missing its upstream node has been replaced with an error message.
Area take-off- A regression meant that polygon categories could no longer be selected for area take-off. This has been corrected.ICMExchange
- A crash when using the select_changes method in ICMExchange has been rectified.
DWG import-
- When importing duplicate objects from a dwg file and selecting theOverwrite option, the objects in the network are now overwritten.
Simulations without rainfall results- A crash when viewing results that have rainfall results excluded no longer occurs.
2D simulation results in SWMM networks- 2D simulation results are now shown in the coordinates panel when the option to do so is selected.
Crash when open a network in a cloud database- A crash when multiple users are working with the same object in a scenario and the base in a cloud database has been fixed.
Error accessing a new network or branch copied from a commit- When trying to access a network or branch copied from a commit, in rare circumstances an error was triggered "Error downloading commit blob: URL rejected: No host part in the URL." This has been fixed.
Vulnerabilities- The following security vulnerabilities have been addressed: CVE-2025-3277
InfoWorks ICMis an advanced integrated catchment modeling software. It allows small utilities and large enterprise organizations to model complex hydraulic and hydrologic network elements quickly, accurately, and collaboratively. InfoWorks ICM helps you plan for capacity improvements, system expansions, and emergency scenarios for water and wastewater professionals. Sewer and stormwater engineers, planners, project managers, and consultants use InfoWorks ICM to face evolving challenges driven by regulations, level of service, customers, environment, and operations.
The latest on InfoWorks ICMAutodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorAutodeskInfoWorksICM20262.htmlFikper1m3jb.Autodesk-InfoWorks-ICM-2026-2.part1.rar.html1m3jb.Autodesk-InfoWorks-ICM-2026-2.part2.rar.htmlFreeDL1m3jb.Autodesk-InfoWorks-ICM-2026-2.part1.rar.html1m3jb.Autodesk-InfoWorks-ICM-2026-2.part2.rar.htmlLinks are Interchangeable - No Password - Single Extraction
