04 de Abril de 2026, 23:04 *
Autor Tema: Native Instruments Traktor Pro 4.3.0.7  (Leído 23 veces)
« : 24 de Octubre de 2025, 00:11 »
Free Download Native Instruments Traktor Pro 4.3.0.7 | 612.8 Mb
Professional 4-deck DJ software. Traktor is the go-to software for hundreds of thousands of DJs, at every level. Mix beyond the standard with freedom, flexibility, and powerful creative performance tools.
Stem Separation
Transform the way you mix and remix with stem separation powered by iZotope's legendary RX technology. Precisely isolate and manipulate drums, bass, instruments, and vocals. And with each stem waveform right in front of you, you can mute, control the volume, or apply filters and effects with a high level of accuracy.
Layer legendary drum sounds
Bring the sounds of iconic drum machines and leading producers to your sets. Pattern Player is packed with percussion kits, including the signature drums of industry legends like Rebekah, Luke Slater, Len Faki, Chris Liebing, and many more.
Studio-quality effects
Take your tracks to another dimension with iconic Traktor reverb, stretching algorithms, creative delays, and much more. Dial in and combine over 40 options across four assignable effect processors to twist, tweak, or totally transform your music.
Remix on the fly
Chop and re-edit tracks however you like with the industry's most reliable loop, Hotcue, and beatjump tools. Plus, add samples and effects and trigger them in sync with the rest of the mix with Remix decks.
Flexible Beatgrids
Mixing disco? Hip hop? Jazz? No problem. Flexible beatgrids are ideal for moving between genres or mixing tracks with a changing tempo. Traktor Pro 4's flexible beatgrids precisely follow each tempo change throughout the track. And unlike other DJ systems, there's no impact on the audio quality when you hit sync. Get your mix sounding just right with highly-accurate looping, beat jumps, beat effect layering, and beat alignment.
Maximize your sound with Ozone
Take your sounds and sets to new heights while protecting the mix from clipping and distortion. Ozone Maximizer utilizes technology from iZotope's award-winning Ozone mastering software. Its Intelligent Release Control allows you to boost the loudness of your sets without distortions.
Any setup you like
Plug and play with any club-standard mixer, turntables, or CDJs. Traktor Timecode Control Vinyl (DVS) means you can keep the feel of mixing vinyl with all your digital tracks, plus Beatport or Beatsource Streaming. And if you're blurring the lines between DJing and performance, MIDI syncing and Ableton Link let you connect with external software and hardware to build extensive hybrid setups.
https://www.native-instruments.com/en/products/traktor/dj-software/traktor-pro-4
http://peeplink.in/567f819ca705
cs0ax.Native.Instruments.Traktor.Pro.4.3.0.7.rar.html
