06 de Abril de 2026, 22:08 *
Autor Tema: Metric Halo DBVerb v4.0.89  (Leído 40 veces)
« : 11 de Noviembre de 2025, 16:09 »
Free Download Metric Halo DBVerb v4.0.89 | 30.3 Mb
Over his long career, multi-platinum award-winning Super Producer / Engineer David Bendeth has developed an amazing workflow to blend multiple reverbs applied to a channel or a bus for a layered and nuanced sound. What happens when you take that workflow and wrap it around a custom reverb engine that provides the key reverb patches that he has dialed in and used on the classic recordings he is known for?
You get DBVerb.
DBVerb replicates 12 of David's favorite reverb patches.
The plug-in also implements his signature workflow for dialing in the perfect reverb by putting 4 different reverbs in parallel, each with a dedicated fader to allow you to quickly blend the contribution of each verb into the overall response.
It is fast and fun to use and allows you to dial in a perfect reverb sound without spending hours scrolling through patches and parameters. It is easy to get a great sound, and virtually impossible to create a bad setting.
Each reverb strip allows you to select from 3 different reverb patches.
Solo and Cut controls on each strip allow you to easily audition the individual contributions without changing the balances.
The plug-in also includes post-reverb High Pass Filter and High Shelf EQ, and an overall pre-delay control, which allows you to increase or decrease the pre-delay of the reverb relative to David's settings.
The integrated gain compensated Wet/Dry control lets you dial the perfect blend of the direct and reverb sound, or simply set the plug-in to 100% wet for use on an aux fader in your mix.
Finally, each reverb strip also includes a length control that shortens the reverb tail for the associated reverb - allowing you to dry up the verb, if needed, or even dial in a fantastic gated reverb sound, without suffering any chattering or level dependent effects.
Key Features:
World-class Signal Processing and Workflow.
12 key reverb patches in 4 engines with a nearly infinite set of combinations.
Per-reverb length controls.
Per-reverb blending faders.
Per-reverb cut and solo controls for audition and automation.
Overall Integrated reverb EQ.
Overall pre-delay control.
Many presets included.
Adjustable UI size.
MH Preset Manager - Provides cross-platform presets.
https://mhsecure.com/products/software/MBDBVerb.html
gbchh.Metric.Halo.DBVerb.v4.0.89.rar.html
