06 de Abril de 2026, 14:00 *
Autor Tema: dbForge Studio for MySQL Enterprise 2025.2.109 (x64)  (Leído 45 veces)
« : 11 de Noviembre de 2025, 16:16 »
Free Download dbForge Studio for MySQL Enterprise 2025.2.109 (x64) | 132.8 Mb
dbForge Studio for MySQL is a high-end IDE for MySQL and MariaDB, a comprehensive solution designed to make nearly every aspect of work with your databases quick and effortless. With its clean and intuitive GUI, the Studio proved to be a perfect fit for beginners and seasoned pros alike - and the wealth of its features covers the following tasks with ease and precision.
SQL Development
Database Design
Data Management
Database Operations
Database Administration
Data Analysis & Reporting
Automation
Version Control
SQL Development
dbForge Studio for MySQL provides you with an exhaustive set of tools to speed up your SQL development.
SQL Editor
MySQL Debugger
Visual Query Builder
SQL Coding Assistance: Code Completion, Syntax Check, Formatting, Quick Info, Parameter Info
Database Projects
Query Profiler
Query Execution Plans
Data Generator
Source Control
dbForge AI Assistant: AI-driven support for complex SQL tasks
If you're into using AI for your daily work, you might just as well use it to completely transform your experience of SQL development-and our dbForge AI Assistant will help you with that!
AI Assistant
Reinvent your SQL development with the integrated AI Assistant that auto-generates, explains, fixes, and optimizes queries, provides helpful insights and best practices for SQL coding, and effortlessly guides you through every feature of the Studio.
Context-aware query generation
Conversion of natural language to SQL
Query optimization
SQL explanations
SQL troubleshooting
Error analysis and recommendations
AI chat
Intelligent SQL Coding
Bring convenience and effectiveness to your daily SQL coding with intelligent code completion, flexible formatting, code snippets, simplified code navigation, quick object information, and instant syntax validation. Using all of these features in the integrated MySQL Code Editor, you can double your regular coding speed in no time.
Source Control
Using dbForge Studio for MySQL, you can set up and streamline effective version control of database schemas and static table data.
Commit and revert changes
Perform fast comparison of database versions
View and resolve conflicts
Scrutinize the history of changes
Database Comparison & Sync
It has never been easier to locate, analyze, and synchronize differences between databases.
Compare and synchronize schemas and table data
Schedule regular synchronization tasks
Generate comparison reports
https://www.devart.com/dbforge/mysql/studio/
jartn.dbForge.Studio.for.MySQL.Enterprise.2025.2.109.x64.rar.html
