06 de Abril de 2026, 01:58 *
Autor Tema: Autodesk Navisworks Products 2026 Update 2 Win x64  (Leído 41 veces)
« : 11 de Noviembre de 2025, 16:45 »
Free Download Autodesk Navisworks Products 2026 Update 2 | 403.2 mb
Languages Supported: English, Français, Deutsch, Italiano, 日本語, 한국어,
Português, Русский, Simplified 中文, Traditional 中文, Español
Autodeskhas releasedNavisworks 2026 Update 2is a comprehensive review solution enabled for construction coordination, simulation and analysis of project information.
Owner:Autodesk Inc.
Product:Navisworks
Version:2026 Update 2
Supported Architectures:x64
Website Home Page :www.autodesk.com
Languages Supported:multilanguage *
System Requirements:Windows *
Software Prerequisites:pre-installed Autodesk Navisworks Products 2026.0
Navisworks 2026 is biggest release in some time with brand new features such as Export to NWD and Property Sets whilst also modernising existing workflows such as Quick Properties. This release has been also focused on addressing product issues and a particular focus to modernising the look and feel and enhancing workflows for our users.
Enhancements in Navisworks 2026.2
User Interface and Usability
-    Columns in the Edit Links dialog now automatically adjust their width to show the full content (NW-61426).
-    IFC 4.3 and IFC 2x3 files now display the same hierarchy in the Selection Tree (NW-62031).
-    You can now double-click a custom property to edit its value (NW-62186).
-    When using a 3Dconnexion SpaceMouse, the navigation speed is now slower, and the fit button fits only the active selection to the view instead of the whole model (NW-62205 and NW-62206).
-    Improved the speed with which alignments are processed and displayed when using civil alignment tools (NW-62218).
-    The Scripter and Animator plug-ins are no longer treated as legacy plug-ins, avoiding unexpected product closures when opening Navisworks (NW-62106).
NWD Files
-    NWD files can now be published with embedded database properties without causing an unexpected product closure (NW-62101).
Appearance Profiler
-    You can now click any point on the Transparency slider in the Appearance Profiler dialog to move directly to that point, instead of gradually increasing or decreasing the transparency (NW-62318).
-    There is now a refresh button on the Appearance Profiler dialog, which can be used to reload profiles after making updates (NW-61984).
-    You can now reorder the rules on the Appearance Profiler dialog (NW-61988).
-    There is now a Hide option on the Appearance Proflier dialog, enabling you to hide objects as part of a rule (NW-61997).
Clash Detective
-    Clash test default assignee and priority fields are now respected when exported as an XML (NW-62138).
Saved Viewpoints
-    Improved handling when dragging and dropping viewpoints into the Saved Viewpoints window (NW-62264).
Navisworks 2026.2 includes the following fixes:
General
-    The decimal separator in AutoCAD Plant 3D property values is now the same between Navisworks 2023 and 2024 (NW-61052).
-    Fixed an issue causing the Find Next option to not work correctly from the currently selected item in several places, including when working with selection sets (NW-61329).
-    The Save as option on the BIM 360 Glue tab now works as expected when saving to a server (NW-61545).
-    Fixed an issue causing an unexpected product closure to occur when opening Navisworks for some users (NW-61955).
-    SOLIDWORKS files now load correctly in Navisworks 2026 (NW-62012 and NW-62069).
-    Navisworks now correctly displays the German umlaut and other URL encoded UTF-8 characters in ✅File Names when opened from add-ins such as the Coordination Issues Add-In (NW-62051).
-    Exporting to NWD when the model contains multiple instanced groups containing different numbers of nodes now works as expected (NW-62102).
-    Changing the units on the Units and Transform dialog now works as expected (NW-62164).
-    Fixed an issue causing Navisworks to freeze when loading certain views from Model Coordination (NW-62219).
-    When importing FBX files into Navisworks, fixed an issue causing some parts of the model using textures to not be visible or not display the correct textures (NW-62273).
-    Saved layouts now work as expected (NW-62277).
-    Fixed an issue causing the color picker to get stuck behind the Navisworks screen when moving between applications (NW-61976).
-    When updating property sets in Quick Properties, the changes are now displayed correctly as columns in the Selection Inspector window (NW-62191).
Civil Alignments
-    Fixed an issue causing an unexpected product closure when using the Measure tool on models containing civil alignments in Navisworks Freedom 2024 (NW-62052).
-    The expiry date calendar in the Publish dialog is now correctly translated to match the locale setting of the rest of Navisworks (NW-61313).
-    Alignment data is now correctly extracted and displayed for DWG files in Navisworks 2026 (NW-62089).
Clash Detective
-    Fixed an issue causing an unexpected product closure when moving clashes into or between clash groups (NW-62058).
-    Using column filters on the Results tab of the Clash Detective is now faster and more responsive when there are many clash results (NW-61264).
-    When using multiple filters in the Tests panel of the Clash Detective, assigning an issue to a user when the filters would result in an empty clash test no longer causes an unexpected product closure (NW-62139).
-    Fixed an issue causing an unexpected product closure when clicking the Clash Point column in the Results tab of the Clash Detective (NW-62146).
-    Dragging a clash and changing its status on the Results tab of the Clash Detective now works as expected (NW-62288).
-    Fixed an issue causing clash test import to fail when the default assignee and priority fields have been preset in the imported file (NW-62392).
-    When filters have been applied on the Results tab of the Clash Detective, selecting two clash groups and changing their status now works as expected (NW-62054).
-    It is now possible to correct the text and change the capitalization of the Assign To field when assigning a clash (NW-62121).
-    Fixed an issue causing Navisworks to stop responding when trying to filter clash results after making bulk clash status changes (NW-62220).
-    Clashes that have an entry in the Description field are no longer incorrectly duplicated when rerunning a clash test (NW-62371).
Appearance Profiler
-    The option to show or hide profiles when no matching selection is found, can now also be toggled to make items transparent when they are not found in any rule (NW-61288).
-    Fixed an issue causing the Color and Transparency fields on the Appearance Profiler to not reset to default as expected when creating a new profile (NW-61347).
-    Improved Appearance Profiler user interface (NW-61412).
-    The color picker now automatically updates to match the colors selected when editing a profile rule (NW-62275).
Viewpoints
-    The comment icon on saved viewpoints is now removed when all comments are deleted (NW-61475).
-    The comment icon now displays correctly on saved viewpoints when comments are added using the Comments window (NW-61476).
IFC files
-    Fixed an issue causing some IFC files to not load (NW-62279).
-    IFC files that use world coordination offset now load in the correct grid location (NW-62280).
RVM files
-    RVM property values are now displayed correctly, including any leading 0 (NW-62053).
-    RVM ATT properties now appear correctly on the appropriate nodes in the Selection Tree (NW-62055).
Autodesk Navisworksis a comprehensive project review solution that supports 5D simulation, coordination, analysis, and communication of design intent and constructability. Multidisciplinary design data created in a broad range of Building Information Modeling (BIM), digital prototype, and process plant design applications can be combined into a single, integrated project model. Comprehensive schedule, quantification, cost, animation, and visualization capabilities assist users in demonstrating design intent and simulating construction, helping to improve insight and predictability. Real-time navigation combines with a review toolset to support collaboration among the project team. Entire project models can be published and viewed in NWD and DWF file formats to provide valuable digital assets from design through construction. Interference management tools help design and construction professionals anticipate and avoid potential problems before construction begins, minimizing expensive delays and rework. Entire project models can be published and viewed usingAutodesk Navisworks Freedomsoftware. The distributable NWC file exporter lets project teams using Navisworks software generate whole-project models for simulation and analysis. Team members can generate optimized NWC files directly from design applications. TheNWC File Export Utilityworks with a range of products, including AutoCAD and Revit software, as well as 3ds Max, Bentley MicroStation and Graphisoft ArchiCAD software. The NWC File Export Utility file format supports transfer of both object geometry and associated metadata.
What's new in Navisworks 2026
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
How to run Navisworks products in a different language?
68ha0.Autodesk.Navisworks.Products.2026.Update.2.rar.html
