07 de Abril de 2026, 05:38 *
Autor Tema: WinTools.net Professional Premium Classic 25.12.1 Multilingual Portable  (Leído 46 veces)
« : 11 de Noviembre de 2025, 20:20 »
Free Download WinTools.net Professional / Premium / Classic 25.12.1 Multilingual Portable Fast Links | 7.90 Mb
WinTools.net is a suite of tools for increasing MS Windows operating system performance. WinTools.net cleanly removes unwanted software from disk drives and dead references from the MS Windows registry. WinTools.net puts you in control of the Windows startup process, memory monitoring and gives you the power to customize desktop and system settings to fit your needs. Adds more speed and stability for your connection. Ensures your privacy and keep sensitive information secure. WinTools.net Premium contains tools: Clean Uninstaller, Scan Files, Scan Shortcuts, Scan Registry, Startup Manager, Tweak UI, Net Tweaker, Your Privacy, Invisible Man, File Shredder...
WinTools.net: Clean Uninstaller
Used for both correctly removing software and for monitoring changes made to the hard drive, MS Windows registry and system files during program installations.
WinTools.net: Scan Files
WinTools.net: Scan Shortcuts
Used for periodic cleaning of your Desktop, Start-menu, Application data and hard drives from dead shortcuts, These shortcuts remain on the hard disk and increase drive access time.
WinTools.net: Scan Registry
WinTools.net: Startup Manager
This tool allows you to monitor, add, remove, enable and/or disable individual startup items. You can also adjust applications initialized during the loading process of the operating system.
WinTools.net: Tweak UI
WinTools.net: Net Tweaker
The tool is used for speed increasing of data transfer and for greater stability of connection by changing hidden network settings. Available only in "Professional" edition.
WinTools.net: Your Privacy
This is a kit of tools which ensure your privacy and keep sensitive information secure. Available only in "Professional" edition.
WinTools.net: Invisible Man
This tool is used for saving private information and its later restoration. This is useful if you don't want any information saved by the system.
WinTools.net: File Shredder
This tool is used for full secure deleting documents, programs, and any other files without possibility to restore them.
WinTools.net: IE Favorites
Little tools for quick delete, backup and restore Internet Explorer Favorites. Remove unused or damaged links.
WinTools.net: RAM Memory Booster
This tool serves for monitoring, cleaning and optimisation of RAM. It is used for increasing of operating system performance and for releasing RAM for usage by other processes. If you have a possibility, we recommend to use RAM Saver Pro instead of RAM Memory Booster.
Operating System:Windows 10/8.1/8/7/VISTA/XP/2k8/2k3/2k
Home Page-http://www.wintools.net/
oiwax.WinTools.net.Classic.25.12.1.Portable.rar.html
oiwax.WinTools.net.Premium.25.12.1.Portable.rar.html
oiwax.WinTools.net.Professional.25.12.1.Portable.rar.html
