07 de Abril de 2026, 13:24 *
Autor Tema: Lansweeper 12.6.0.11  (Leído 47 veces)
« : 14 de Noviembre de 2025, 23:05 »
Free Download Lansweeper 12.6.0.11 | 374.8 Mb
Lansweeper is an automated network discovery and asset management tool which scans all your computers and devices and displays them in an easy accessible web interface. There is no need to install any agents on the computers, all scanning is done by standard build-in functionality.
Software inventory
With Lansweeper it's easy to track and audit all your installed software, you can create powerful software inventory reports to find out which application is installed on which computer. Google unknown software and publishers right from the web interface and find out who is running software that's not up to date.
Hardware inventory
Lansweeper cannot only detect all hardware devices in your computers but with it's change tracking it can find out when a device was changed or removed. Not only does Lansweeper scans windows devices, it also gathers details about all other IP enabled devices on your network from the network discovery scan. (Linux, Printers, Routers, ...)
License compliance
If you want to keep all software and operating systems licenses up to date it can be a time consuming work. With Lansweeper computer inventory it doesn't need to be...
The webinterface will tell you how many software versions are installed and how much licenses you are missing.
Compliance reporting
Every company needs policies to get a smooth running network. Compliance reporting and the dashboard can help you to make all kinds of asset management reports. Who doesn't have the latest version of our virus scanner, Who is missing the latest patch for our ERP solution. The only limit is your imagination...
Active directory integration
Lansweeper gathers all active directory user and computer details for your scanned machines. Create reports based on OU, integrate user pictures, Clean up your Active directory...
Eventlog integration
Every windows computer logs errors into the Eventlog. Thanks to Lansweeper you can now consolidate all these errors and get an alert e-mail as soon as an important error occurs.
Windows client machines must have .NET Framework 4.8 (or higher) installed in order to run and be scanned by LsAgent. The following operating systems support .NET Framework 4.8 and hence can be scanned by LsAgent, if .NET 4.8 (or higher) is installed:
Windows 7, SP1 (32-bit and 64-bit)
Windows 8.1 (32-bit and 64-bit)
Windows 10 1607 or higher (32-bit and 64-bit)
Windows 11 (64-bit)
Windows Server 2008 R2, SP1 (64-bit)
Windows Server 2012 (64-bit)
Windows Server 2012 R2 (64-bit)
Windows Server 2016 (64-bit)
Windows Server 2019 (64-bit)
Windows Server 2022 (64-bit)
https://www.lansweeper.com/
gnn2x.Lansweeper.12.6.0.11.rar.html
