07 de Abril de 2026, 10:20 *
Autor Tema: Maplesoft MapleSim 2025.2 Build 1971053 Update Win x64  (Leído 75 veces)
« : 16 de Noviembre de 2025, 23:16 »
Free Download Maplesoft MapleSim 2025.2 | 987.7 mb
Languages Supported: English, 中文 (traditional and simplified), 日本語, Danish,
Español, Français, Ελληνικά, 한국어, Magyar, Português, Русский
The TeamMaplesoftis pleased to announce the availability ofMapleSim 2025.2. This update includes updates to MapleSim and some of its add-ons, as well as to MapleSim Insight.
MapleSim 2025 includes a new component library to support the modeling of motor drives, updates to several in-product apps that make it even easier to perform optimization and analysis, and an upgraded computation engine to take advantage of recent improvements that became available in Maple 2025.
Owner:Waterloo Maple Inc.
Product Name:MapleSim
Version:2025.2 (1971053) Update
Supported Architectures:x64
Website Home Page :www.maplesoft.com
Languages Supported:multilanguage *
System Requirements:Windows *
Software Prerequisites:pre-installed Maplesoft Maple 2025 and Maplesoft MapleSim 2025.1
What's new in MapleSim 2025.2
MapleSim 2025.2 offers a series of enhancements to save you time and effort when creating and analyzing simulations. This release includes updated tools for comparing models and analyzing simulation data, and changes to the simulation code that improve runtime performance for MapleSim connectors.
The MapleSim 2025.2 update includes the following:
-    An upgradedRerun Paneladds a faster means of performing a parameter sweep on a chosen parameter. This allows easy results comparisons from within the Results Manager.
-    TheParameter Sweepapp now allows filtering by summary variables, making it easier to group and select them in larger models. The app has also received a performance boost when re-initializing between sweeps.
Updates to the MapleSim Web Handling Library
The MapleSim Web Handling Library, an add-on to MapleSim, is used across the R2R (roll-to-roll) community to model and explore web lines and converting processes.
The 2025.2 update supports the following:
-    Halt simulation during extreme web responses: You can now define maximum web tension, maximum web stress, and minimum width (neck down) values to interrupt the simulation when reaching practical web limits.
-    Enhanced modeling of Spans: The web Span has improved handling of loss of tension, and the Sagging Span inputs now include the bending stiffness of materials.
Based on customer requests, when entering web speed you can use the units m/min.
Additional updates to Drives and Controls:
-    Using the new Tension Control with Torque Output component, engineers can apply a control approach using torque as the controller output.
-    Enhancements to the Controls section:
.        Gain scheduling is available as an option for all Control RW blocks.
.        All Position Control components now allow for sensor effects in the simulation.
-    New Utilities section:
.        The new Rewind Tension Definition component lets users define the target tension profile in winding to align with PLC settings (Options: Constant, Taper, and Curve).
.        Additional roll radius input components make it easier to include radius measurements, by either simulating input from an ultrasonic sensor or by estimating roll radius from two speed signals.
This update also includes in-product MapleSim model examples highlighting the recent Drives and Controls features.
Additional Improvements to MapleSim Add-ons
-    The MapleSim CAD Toolbox offers support for recent software releases from Creo, NX, Parasolid, and other CAD tools.
-    The new releases of B&R MapleSim Connector and MapleSim Connector for FMI offer additional speed-ups to their respective initialization code, as well as options that allow a more efficient compile for targets using C macros.
MapleSim Insight 2025.2
- The 2025.2 release of MapleSim Insight provides a maintenance update to align with the latest updates in MapleSim 2025.2.
MapleSimis the advanced system-level modeling solution based on the Maple mathematical engine and analysis environment to design and simulate multidomain systems, plants and controls in one single environment. The schematic diagram interface enables rapid model development, thanks to the Maple symbolic computation foundation providing a highly concise, numerically efficient model formulation. MapleSim enables Engineering System Designers to answer the most critical questions faced in the everyday activity "Will the system work as required?", and "Can we make it work better?", by developing virtual prototypes of multi-domain dynamic systems and performing functional validation, critical system-level parametric studies and optimizations. The Control System Developer will be able to leverage MapleSim to develop high-fidelity models of complex dynamic systems for plant characterization and integrating models through automated code generation into (typically) MATLAB/Simulink for controller development.
Tutorials: MapleSim
Waterloo Maple Inc.is a Canadian software company, headquartered in Waterloo, Ontario. Maplesoft has provided mathematics-based software solutions to educators, engineers, and researchers in science, technology, engineering, and mathematics (STEM) for over 35 years. It is best known as the manufacturer of the Maple computer algebra system, and MapleSim physical modeling and simulation software.
c5xih.Maplesoft.MapleSim.2025.2.rar.html
