06 de Abril de 2026, 04:22 *
Autor Tema: Autodesk Inventor 2026.2 with Updated Content Win x64 Multilanguage  (Leído 80 veces)
« : 18 de Noviembre de 2025, 21:06 »
Free Download Autodesk Inventor 2026.2 with Updated Content | 2.8 Gb
Languages Supported: English, Čeština, Français, Deutsch, Italiano, 日本語, 한국어,
Polski, Português, Русский, Simplified 中文, Traditional 中文, Español
Autodeskhas announced the release ofInventor 2026.2is computer-aided design (CAD) software for modeling, simulation, visualization and documentation.
Autodesk Inventor Professional 2026 delivers meaningful improvements, from file management and parameter control to advanced sheet metal and assembly tools. With the transition of more commands into the modern browser panel interface, users benefit from enhanced usability, better visualisation, and fewer clicks in daily workflows. Sheet metal tools have become more flexible and standardised, with new presets, direct rule selection, and enhanced punch workflows. In Assembly, features like mirrored associativity and improved model state editing offer greater precision and efficiency. Additionally, Inventor's strengthened interoperability with Revit through BOM category assignment, improved placement tools, and metadata presets helps bridge the gap between design and construction.
Owner:Autodesk Inc.
Product Name:Inventor
Version:Professional 2026.2 with Updated Content *
Supported Architectures:x64
Website Home Page :www.autodesk.com
System Requirements:Windows **
Software Prerequisites:pre-installed Autodesk Inventor 2026.0 and above
Inventor_2026.2_Update.exe
Inventor Interoperability 2026.2
Chinese-Simplified Language Pack for Inventor Professional 2026.2
Chinese-Traditional Language Pack for Inventor Professional 2026.2
Czech Language Pack for Inventor Professional 2026.2
English Language Pack for Inventor Professional 2026.2
French Language Pack for Inventor Professional 2026.2
German Language Pack for Inventor Professional 2026.2
Italian Language Pack for Inventor Professional 2026.2
Japanese Language Pack for Inventor Professional 2026.2
Korean Language Pack for Inventor Professional 2026.2
Polish Language Pack for Inventor Professional 2026.2
Portuguese-BR Language Pack for Inventor Professional 2026.2
Russian Language Pack for Inventor Professional 2026.2
Spanish Language Pack for Inventor Professional 2026.2
What' new in Inventor 2026.2
Add-Ins - Cable and Harness
- Improved stability in Cable/Piping sketch route when using route workflow. INVGEN-86740
Add-Ins - Content Center
- Resolved issue with cell colors: For expression columns, the values are now displayed in blue; for other columns, they are displayed in black. INVGEN-74895
- Resolved issue where Content Center components were not recognized after updating CC parts. INVGEN-80544
- Resolved issue where a Content Center part showed as out of date after refresh. INVGEN-84378
- Improved stability when the Content Center window was locked via VBA. The window no longer stays open during the OnClose() event, which previously cleared the window's content and some pointers, leading to crashes when the user clicked anything. INVGEN-84844
- Resolved issue with being unable to create a component when placing from Content Center for a published custom iPart based on a custom Content Center member. INVGEN-85055
Add-Ins - Design Accelerator
- Resolved issue where the bolted connection did not sit correctly when using the concentric constraint. INVGEN-85705
- Resolved issue while creating an internal groove using the standard DIN 5842-30 with Involute Splines Connection Generator. INVGEN-86545
Add-Ins - Design Checker - Feature Recognition - Mesh Enabler
- Improved stability when converting the mesh to a base feature. INVGEN-86211
Add-Ins - Frame Generator
- Resolved issue where Break Reuse Members was not working for specific part in design. INVGEN-83385
- Resolved issue where the "Merge Frame Members" option was unavailable when using a derived 3D sketch for Insert Frame. INVGEN-83510
- Improved stability while inserting frames and zooming in and out. INVGEN-84963
- Improved stability while doing some operations in Frame Generator dialogs. INVGEN-86584
Add-Ins - Simulation
- PDF format is now available for installed MS Word or MS Edge web browser (using Print to PDF). INVGEN-85358
Add-Ins - Simulation - Frame Analysis
- Improved stability when simulating a frame analysis. INVGEN-85484
- Improved stability when simulating a stress analysis. INVGEN-85519
Add-Ins - Simulation - Stress Analysis
- Improved stability when activating the stress/frame analysis add-in with a 3D mouse. INVGEN-84212
Add-Ins - Task Scheduler
- Resolved issue where Task Scheduler stopped running on multiple processes. INVGEN-67056
- Resolved issue where printing files from IDW to PDF using Task Scheduler would not complete if a different model state was activated other than primary. INVGEN-84155
Add-Ins - Tube and Pipe
- Resolved issue where editing fitting orientation does not work after replacing a component in Inventor. INVGEN-84848
- Improved stability while using "Routed Systems: Cable & Harness" and "Routed Systems: Tube & Pipe" add-in. INVGEN-85382
- Resolved issue where the fitting thickness was not maintained when creating a pipe run. INVGEN-85384
Add-Ins - iLogic
- Improved stability by resolving an unhandled exception that occurred with the message "StartIndex ('-2') must be a non-negative value (Parameter 'startIndex')" when a parameter was inserted in the iLogic editor using the UI double-click interface. INVGEN-83524
- Resolved issue where the update of parameters linked to Excel was disrupted by the iLogic log. INVGEN-84527
- Resolved issue where the iLogic function DeleteAllRulesInDocument threw an error when called from a rule in the document. INVGEN-85927
AnyCAD - FDX
- Improved stability when loading a data exchange into Inventor. INVGEN-85904
Assemblies
- Improved stability placing a component in an assembly. INVGEN-85509
- Improved stability when in-place editing a part and right-clicking on a custom feature node. INVGEN-85994
- Improved stability when updating the assembly. INVGEN-86699
Assemblies - BOM
- Resolved issue where the model could not be opened from the Bill of Materials. INVGEN-85531
Assemblies - Constrain - Joint - Assemble
- Improved stability when using constraints with a circle. INVGEN-85399
- Resolved issue while defining a constraint and confirming it using the "Apply" button. INVGEN-85753
- Resolved issue where the second rotation arrow displayed flipped in the graphic symbol for motion constraint. INVGEN-85870
- Improved stability when dragging the part to create an insert constraint. INVGEN-85912
Assemblies - Create - Place - Edit
- Improved stability by resolving the issue related to AMxChangeCompState::OnTerminate as identified. INVGEN-86068
Assemblies - Derived - Simplify
- Resolved issue where the Include command was grayed out in drawing. INVGEN-82133
- Improved stability when editing a simplified assembly. INVGEN-85972
Assemblies - Update - Rebuild
- Improved stability while working on an assembly file or while executing the update command. INVGEN-85731
Cloud Services - Inventor IO
- Resolved issue with 3D annotation improvement during SVF export generation on the Autodesk Platform service. INVGEN-68752
Drawings
- Resolved issue with incorrect thumbnail size in the drawing. INVGEN-85209
Drawings - Balloons
- Resolved issue where attached balloons could not be moved. INVGEN-84411
- Improved stability when selecting a line of a Parts list. INVGEN-86737
Drawings - Dimensions
- Resolved issue where Punch notes removed the tolerance value from the previously created dimension. INVGEN-81898
- Resolved issue for Angular Sum dimension type creation. INVGEN-85127
Drawings - Print - Description
- Improved stability when viewing a print preview of a drawing that is rotated by 90 degrees. INVGEN-85782
Drawings - Styles
- Resolved issue where changing the color of the layer did not change the tolerance color. INVGEN-84745
- Resolved issue when editing Tolerance Text Style in the Styles manager did not set the correct text style. INVGEN-85346
- Resolved issue where the section view hatch angle set in the style was not applied correctly. INVGEN-85498
Drawings - Symbols
- Resolved issue where, in a drawing view within a break view environment, creating a centerline for a slot on the side of a cylinder resulted in an incorrect centerline. INVGEN-80165
Drawings - Tables
- Resolved issue where a backslash was replaced by a double-backslash in the revision table. INVGEN-84046
Drawings - Text
- Resolved issue where the property source of drawing notes was getting lost. INVGEN-83959
- Resolved issue where the GeneralNote.FormattedText.Replace(OldText, NewText) function broke ordered number lists. INVGEN-84671
- Resolved issue where View Sheet Zone was not updated after changing the sheet size. INVGEN-85126
Drawings - True Connect
- Resolved issue when editing a view after using Save Copy As for an Inventor DWG drawing. INVGEN-85577
Drawings - Views - Aux - Section - Detail
- Resolved issue where the hatch on the large-scale views was rendered outside of the geometry. INVGEN-85832
Drawings - Views - Break - Break Out - Slice - Crop
- Resolved issue where the crop disappeared after placing a constraint on the crop line. INVGEN-83027
iAssembly - iPart
- Resolved issue where a sheet metal iPart could not be switched in the flat pattern environment. INVGEN-86185
- Resolved issue where the iPart table became disorganized when setting key parameters. INVGEN-86601
- Improved stability when switching iAssembly member. INVGEN-87078
Measure
- Resolved issue where Face.GetClosestPointTo() returned the same point as the specified point. INVGEN-86569
Model States
- Improved stability when deleting a column in the Model States Table. INVGEN-85544
- Improved stability by resolving the issue where opening a file with many model states caused Inventor to hang. INVGEN-86039
Model States - API
- Resolved issue where FullFileName in OnFileDirty returned the [Primary] model state name. INVGEN-85917
Parameters
- Resolved issue where, after editing a linked spreadsheet without making changes and then saving it, the referenced files threw warnings in Inventor. INVGEN-82260
Parts
- Improved stability while opening the IDW. INVGEN-83991
Parts - 2D Sketch
- Resolved issue with the Textbox formatted text for font size. INVGEN-68932
- Resolved issue where the Sketch.OriginPoint could not be changed to a SketchPoint in a sketch block via iLogic. INVGEN-77837
- Resolved issue where the parameter of the sketch pattern pitch could not be seen. INVGEN-85353
- Resolved issue related to Sketch Circular Pattern. INVGEN-85710
- Improved stability by resolving the issue where checking the SketchCircularPattern Fitted option caused Inventor to crash. INVGEN-85715
- Improved stability when adding a dimension. INVGEN-86830
Parts - Extrude - Revolve - Sweep - Coil
- Improved stability by resolving the edit feature failure. INVGEN-86500
Parts - Finish Feature
- Resolved issue where the Finish feature could not be created on multiple occurrences of the same body or face in an assembly. INVGEN-86300
Parts - Loft - Draft
- Improved stability when deleting the sketch while creating a surface loft. INVGEN-86521
Parts - Mirror - Pattern
- Resolved issue where a renamed axis was not displayed when selecting the direction to add a pattern. INVGEN-84360
- Improved stability when restoring the second framework window from being minimized. INVGEN-85365
Parts - Sheet Metal - Face - Flange - Contour Flange - Corner Seam
- Improved stability by resolving the issue where making the sheet metal thin caused a crash. INVGEN-81991
- Resolved issue where the face or edge of a sheet metal part could not be selected. INVGEN-83099
- Resolved issue where, when opening previous version data that created contour flanges in two directions from one sketch, the position of the second contour flange moved. INVGEN-84207
- Resolved issue where the flange error was caused by the Sheet Metal Default overriding solid-specific thickness in multi-solid part files. INVGEN-84914
Platform
- Improved stability when migrating Style Libraries. INVGEN-85287
- Improved stability when updating an assembly. INVGEN-86732
- Improved stability updating the mass properties of an assembly. INVGEN-86767
- Improved stability of File Dialog. INVGEN-87302
Platform - API
- Resolved issue where the BrowserPane.Activate did not function correctly for the Model browser pane. INVGEN-82910
- Improved stability when closing all documents that had been checked into the Vault. INVGEN-83765
Platform - API - Drawing
- Resolved issue where running an iLogic rule placed the parts list onto the sheet. INVGEN-83666
- Improved stability when selecting a dimension after executing the DLxCopyDimPropertiesCmd. INVGEN-85760
Platform - Framework
- Improved stability of keeping the customization of the ribbon through different Inventor sessions.  INVGEN-84061
- Improved stability with the file dialog. INVGEN-84563
- Resolved issue where saving files showed them as outside the project. INVGEN-84888
- Importing application options setting from the command line no longer overrides the iLogic external paths. INVGEN-85237
- Improved stability for the File Open Dialog. INVGEN-85329
- Improved stability with Design Assistant when selecting a Project. INVGEN-86477
- Improved behavior of File Dialog's project dropdown list to sort by ✅File Names instead of file paths. INVGEN-86802
Platform - Graphics - Drawing
- Resolved issue where radial dimensions disappeared on a drawing when moving views. INVGEN-80626
Presentations
- Improved stability when editing the Storyboard of a Presentation file. INVGEN-86083
Translators
- Improved stability when opening the PRT file. INVGEN-84975
UI
- Improved stability of customizing the QAT with commands. INVGEN-81263
- Resolved issue by adding support for the scroll wheel to work in the Application Options dialog. INVGEN-84034
UI - Framework
- Resolved issue where the Property Panel commands, such as Rectangular Pattern, Fillet, did not hide the tool palette when switching to the Home. INVGEN-85027
Autodesk Inventor3D CAD software provides professional-grade mechanical design, documentation, and product simulation tools. Powerful blend of parametric, direct, freeform, and rules-based design capabilities. Integrated tools for sheet metal, frame design, tube and pipe, cable & harness, presentations, rendering, simulation, machine design, and more. Trusted DWG compatibility and powerful Model-Based Definition capabilities for embedding manufacturing information directly in the 3D model.
Inventor 2026 What's New Overview
Discover over 140 enhancements to help you solve your everyday design challenges. Each of them are carefully crafted to improve user experience, enhance functionality, and streamline design processes. Check out the following video demonstration for some of the highlights for this release.
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
o7zbg.Autodesk-Inventor-2026-2-with-Updated-Content.rar.html
Alfafile
https://alfafile.net/file/AFAS7/o7zbg.Autodesk-Inventor-2026-2-with-Updated-Content.rar
