06 de Abril de 2026, 07:49 *
Autor Tema: Autodesk Factory Design Utilities 2026.1 Win x64 Multilanguage  (Leído 48 veces)
« : 18 de Noviembre de 2025, 22:50 »
Free Download Autodesk Factory Design Utilities 2026.1 | 2.6 Gb
Languages Supported: English, Español, Português,  Polski, 한국어, 日本語, Italiano,
Deutsch, Français, Čeština, Русский, 中文 Traditional, 中文 Simplified
Autodeskhas releasedFactory Design Utilities 2026.1. This solution enables you to conceptualize, plan, and validate manufacturing facilities for optimized workflows and accurate equipment placement.
The Factory Design Utilities 2026 includes improvements to performance, automation, and core workflows in these areas: added new Connector Class dialog for creating and editing asset connector classes and the commands that enable you to manually update the DWG and NWF file with any existing changes from the LAYOUTDATA file. Also addressing multiple issues to significantly improve the user experience on 4K monitors.
Owner:Autodesk Inc.
Product Name:Factory Design Utilities
Version:2026.1 *
Supported Architectures:x64
Website Home Page :www.autodesk.com
System Requirements:Windows **
What's New in Factory 2026.1
Performance Enhancements (What's New in 2026.1)
- Discover performance enhancements that make workflows faster and more responsive. This release focuses on significant performance improvements across multiple areas of Factory Design Utilities:
Open Factory Layouts in Inventor
- Improved performance when opening Factory layouts in Inventor. This enhancement reduces loading times and provides a smoother experience when working with complex Factory layouts.
Save Large Layout Files in Inventor
- Optimized performance when saving large layout files in Inventor. This enhancement significantly reduces save times for complex layouts with numerous assets, improving overall productivity.
Open in AutoCAD Command from Inventor
- Improving performance when using the Open in AutoCAD command from Inventor. This improvement ensures a faster and more efficient transition from Inventor to AutoCAD, enabling you to work more seamlessly across applications.
Edit Properties of Large Assets in AutoCAD
- Improved performance when editing properties of large assets in AutoCAD. This enhancement ensures that property modifications are processed more efficiently, especially when working with complex asset configurations.
General Enhancements (What's New in 2026.1)
Discover new features and improvements that enhance workflow efficiency. This release introduces two key enhancements:
Highlighting Asset Search in Layout
When searching for asset instances in a layout, the corresponding assets are now highlighted in the layout view. This visual feedback makes it easier to locate and identify specific assets during search operations, improving navigation and asset management efficiency.
Highlighting Obsolete Asset in Layout
When an asset is marked as obsolete, it is now highlighted in the layout view to provide clear visual indication of its status. This enhancement helps you quickly identify obsolete assets in your layouts, improving asset lifecycle management and layout maintenance.
hese release notes contain important information regarding issues addressed in the FDU 2026.1.
- Resolved an issue that caused text in an asset to become centered after resizing or editing the asset.    INVGEN-72805
- Improved stability when opening a LAYOUTDATA file in AutoCAD.    INVGEN-67000
- Improved stability when opening a referenced drawing (XREF) in AutoCAD.    INVGEN-64664, FDS-14405, FDS-14400
- Resolved an issue where user assets didn't appear in search results when using the Asset Browser in Inventor.    FDS-14740
- Resolved an issue where an error message appeared in AutoCAD Architecture when placing an asset.    FDS-14727
- Resolved an issue where changed parameters reverted to their original values after clicking the Apply button in Inventor.    FDS-14724
- Resolved an issue with the Connector Class, where connected conveyors didn't update simultaneously.    FDS-14700
- Resolved an issue where switching to the Custom option in the iLogic Form used old parameter values.    FDS-14658
- Resolved an issue where the Factory Help link pointed to the staging site instead of the production site in Inventor.    FDS-14617
- Resolved an issue where an asset definition was deleted locally before checking user download privileges.    FDS-14579
- Resolved an issue where right-clicking and selecting Enter canceled the command and prevented asset placement in AutoCAD.    FDS-14574
- Resolved an issue where text overlapped when rotated at 90 or 180 degrees using the TORIENT command.    FDS-14557
- Improved stability when saving a new layout in a folder with a long name in AutoCAD.    FDS-14546
- Resolved an issue where changing the Numeric Parameter in iLogic Form created unnecessary new asset instances.    FDS-14521
- Resolved an issue where Inventor experienced instability while modifying an asset and then checking it into Vault.    FDS-14519
- Implemented a feature where assets marked as obsolete are highlighted and displayed as obsolete within the layout.    FDS-14518
- Resolved an issue where the Asset Instance Search panel didn't work in AutoCAD/Inventor.    FDS-14517
- Resolved an issue where asset properties changed in the Factory Properties weren't updated in AutoCAD.    FDS-14412, FDS-14414, FDS-14184, FDS-14180, FDS-14155
- Resolved an issue where annotations weren't centered when the asset was rotated to a vertical position despite selecting the Center option in the 'Options' dialog.    FDS-14408
- Improved stability while publishing assets multiple times in Inventor.    FDS-14404
- Improved performance when opening migrated layout.    FDS-14299
- Improved performance when selecting multiple assets to change parameters using the iLogic Form.    FDS-14272, FDS-13887
- Improved performance when adjusting the configuration of an asset.    FDS-14261, FDS-13938
- Improved performance when opening an assembly.    FDS-14228
- Resolved an issue where nested referenced drawings (XREFs) were duplicated in AutoCAD.    FDS-14220
- Improved performance when updating asset properties in the Factory Properties in AutoCAD.    FDS-14192
- Improved performance when checking in Factory Layouts with DWG Underlays.    FDS-14187
- Resolved an issue where AutoCAD Architectural and Factory Design Utilities stored the incorrect date after import.    FDS-14176
- Improved performance when checking into Vault.    FDS-14157
- Resolved an issue where the screen appeared blank while placing an asset in AutoCAD.    FDS-14148
- Resolved an error when generating the 2D drawing while publishing an asset to Vault.    FDS-14147
- Improved performance when using DWG Underlay in Inventor.    FDS-13905
Factory Design Utilitiesis an interoperable 2D and 3D factory layout and optimization solution that's used to design and communicate efficient layouts by creating a digital model of your layout. Factory Design enhances AutoCAD and Inventor software with direct-access to layout workflows and factory-specific content, and allows layout designers to begin their layout process in the desired Inventor 3D parametric environment or the 2D AutoCAD environment they are familiar with. Factory Design supports bidirectional associativity between AutoCAD and Inventor making design workflows accurate and efficient.
Factory Design Utilities Overview
Factory Design Utilities Overview. Visualize and optimize your factory designs.
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Autodesk Factory Design Utilities 2026 Base Release
Factory_2026.1_Update.exe
Language Pack for Factory Design Utilities 2026.1 (Factory Design Utilities 2026)
Brazilian Portuguese Language Pack for Factory Design Utilities 2026.1
Czech Language Pack for Factory Design Utilities 2026.1
English Language Pack for Factory Design Utilities 2026.1
French Language Pack for Factory Design Utilities 2026.1
German Language Pack for Factory Design Utilities 2026.1
Italian Language Pack for Factory Design Utilities 2026.1
Japanese Language Pack for Factory Design Utilities 2026.1
Korean Language Pack for Factory Design Utilities 2026.1
Polish Language Pack for Factory Design Utilities 2026.1
Russian Language Pack for Factory Design Utilities 2026.1
Simplified Chinese Language Pack for Factory Design Utilities 2026.1
Spanish Language Pack for Factory Design Utilities 2026.1
Traditional Chinese Language Pack for Factory Design Utilities 2026.1
http://peeplink.in/3a6267f1d9fb
72dcu.Autodesk-Factory-Design-Utilities-2026-1.rar.html
