04 de Abril de 2026, 17:33 *
Autor Tema: Al Amin Hensive 2 v1.2 (Win/macOS)  (Leído 54 veces)
« : 20 de Noviembre de 2025, 17:37 »
Free Download Al Amin Hensive 2 v1.2 (Win/macOS) | 4.1 GB
Get inspired with another great comprehensive virtual instrument powered by the one and only Al AMin! Coming with 270+ Instruments and a multiple choice of categories, we believe that HENSIVE 2 will help you push the envelope and workflow of your music production.
Hensive 2 is a plugin that will help start your projects from scratch. We believe that you will need no additional plugins to start or finish your projects with its comprehensive sounds. Now get inspired by our best and most extensive virtual instrument, powered by the one and only Al AMin!
With its realistic and up-to-date sounds, you don't need to hire musicians: you can create full orchestral arrangements or top-notch electronic compositions with ethnic instruments, brass, strings, leads, choirs, keys, and even more!
FEATURES
This VST Instrument brings more than emulations of hardware or real-world instruments; it can push boundaries of synthesis, harness the power of powerful processors and visualize the parameters and controls in ways not plausible in hardware.
The embedded user interface provides effects so that you can add reverb, glide, pitch, low pass, high pass filters, and many more. In addition, the velocity variation will give your sonics suitable, realistic shapes: these notes will sound different depending on how hard you press your keys.
Hensive 2 LFO engine has several waveforms to choose from. Customize an LFO to one of its presets, and you'll hear it 'wobble' up and down, just as if you were tweaking the parameter yourself! The LFO's Rate control sets the speed at which it oscillates, while the Depth control determines how far it moves its assigned parameter.
ADSR stands for Attack, Decay, Sustain and Release: Knowing what each part of ADSR means is essential for all music creators. Well, never mind! Every preset already has its own ADSR measure set up and is adjustable if you need more precision.
SUM IT ALL UP
We believe that this plugin will be your go-to virtual instrument. But, we also dare you to find high-quality sounds at a reasonable price! This Product is Available for PC and macOS and loaded with more than 270 presets, and we guarantee your satisfaction once loaded into your DAW!
PRODUCT SUMMARY
INSTRUMENTS :
*270+ Instrument Presets
*15 Categories
*Keys, Bells, Synths, Leads, Guitars, Bass, Ethnic,
*808, Strings, Brass, Pads, Winds, Choirs, Drums, FX.
FX & MODULATION SUITE :
ADSR, LFO, Cutoff Filters, Convolution Reverb, Glide, Pitch.
TECHNICAL REQUIREMENTS
FORMATS:
VST2, VST3, AU
OPERATING SYSTEMS:
macOS: 10.10 and up (including Native M1 Compatibility)
PC: Windows 7 and up
DAWs:
Works with all DAWs (except ProTools)
https://producersources.com/product/hensive-2-vsti
http://peeplink.in/74e928a7fb10
t405s.Al.Amin.Hensive.2.v1.2.WinmacOS.rar.html
AlfaFile
https://alfafile.net/file/AFutc/t405s.Al.Amin.Hensive.2.v1.2.WinmacOS.rar
