05 de Abril de 2026, 05:04 *
Autor Tema: Autodesk 3ds Max 2026.3 with Updated Extensions Win x64  (Leído 49 veces)
« : 21 de Noviembre de 2025, 13:35 »
Free Download Autodesk 3ds Max 2026.3 with Updated Extensions | 6.6 Gb
Languages Supported:  English, Deutsch, Français, 日本語, 简体中文, 한국어, Português-Brasil
Autodeskhas released 3ds Max 2026.3, the latest version of its 3D modelling and animation software for architectural visualization, motion graphics and VFX. It's another fairly small update - although not as small as 3ds Max 2026.2 - with changes to the Conform Modifier, Material Switcher, and the USD and Arnold plugins.
Owner:Autodesk Inc.
Product Name:3ds Max
Version:2026.3 with Updated Extension *
Supported Architectures:x64
Website Home Page :www.autodesk.com
System Requirements:Windows **
Autodesk 3ds Max 2026 it's another iterative update, with workflow and performance improvements to 3D modeling, retopology, texturing and animation, and updates to the Arnold and USD plugins.
What's new in Autodesk 3ds Max 2026.3
Conform modifier gains distance & fall-off
The Conform modifier, used to project one mesh onto the surface of another, now offers dedicated distance and fall-off parameters when using the Shrink Wrap projection method. This gives users finer control over how far the modifier searches for the target surface and how the influence decays. It results in more predictable deformations when wrapping geometry-helpful for architectural visualisation, game asset prep, or surface-fitting tasks. As always, test in your own scenes before deploying in production.
Materials: animated index in the Material Switcher
The Material Switcher, which lets artists manage variant materials on assets, now supports an animatable material index. This allows dynamic switching between up to 9,999 different materials during animation or scene changes. It is particularly useful for large asset libraries, scene variants or motion graphics work that requires frequent material swaps. The "up to 9,999" figure is vendor-supplied and should be tested for performance impact in real-world scenes.
USD plugin enhancements
The USD for 3ds Max plugin, now at version 0.13, introduces several workflow improvements. A new Asset Resolver allows users to set custom search paths and tokens to reduce "asset not found" errors. The viewport now supports duplicating prims using the Shift-drag shortcut, and artists can rename, delete and re-parent prims directly. The USD Importer now supports MaterialX materials referenced in USD files, while the USD Exporter adds support for Shell materials. For studios using USD pipelines across DCC applications, these changes improve interoperability and scene organisation. Nonetheless, compatibility with downstream tools should be verified before adoption.
Arnold integration updates
The Arnold for 3ds Max plugin (MAXtoA 5.8.3.2) updates to the Arnold 7.4.3 core. It introduces a new Inference Imager, allowing image-to-image machine-learning models via the ONNX framework to stylise rendered output. There are also performance improvements in global light sampling and GPU volume rendering. The ML-based Inference Imager is potentially interesting for stylised render pipelines, though users should evaluate render time and output quality within their colour-management setup.
Fixes and workflow polish
Several workflow refinements improve day-to-day usability. The Slate Material Editor's thumbnail cache now holds unique thumbnails for different colour-management settings, avoiding unnecessary re-renders when toggling view transforms. Users can disable "Update Browser Samples" to speed up interaction when preview accuracy is less critical. Stability fixes address Biped crashes when keyframing twist bones or setting IK keys with sub-animations enabled. In the Skin modifier, weight changes made using the Remove Zero Weights tool are now properly committed when switching bones. Cloth simulation behaviour has also been restored to match results from previous versions after inconsistencies in 2026.0-2026.2.
3ds Max 2026.3 is not a major overhaul but a purposeful iteration. It strengthens modelling precision, improves material management, expands USD interoperability and introduces an ML-based stylisation tool in Arnold. For production artists in arch-viz, motion graphics and real-time asset pipelines, these modest but thoughtful refinements can streamline daily work. The Inference Imager's machine-learning workflow should be evaluated for integration stability and render-time overhead. The "up to 9,999 materials" limit on the Material Switcher may vary depending on scene complexity. USD enhancements look promising but must be validated against existing DCCs and pipeline tools.
Autodesk 3ds Maxoffers a rich and flexible toolset to create premium designs with full artistic control. With 3ds Max you can create massive worlds in games, visualize high-quality architectural renderings, model finely detailed interiors and objects, and bring characters and features to life with animation and VFX.
3ds Max 2026 New features explained
Lets see the updates on max 2026,  new plugins for animation and AI in development,  amazing scenes created  in 3dsmax and more!
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Autodesk_3ds_Max_2026_3_EFGJKPS_Win_64bit_001_002.exe
Autodesk_3ds_Max_2026_3_EFGJKPS_Win_64bit_002_002.exe
USD3dsMax2026-0.13.0-0.13-release_013.msi
RayFire 1.88 for 3ds Max 2026
Retopology3dsMax2026-1.8.0-2026.2-release_016.msi
3dsmax-component-mnplugins2026-1.11.0-2026.3-release_006.msi
Arnold SDK 7.4.4.0
MAXtoA 5.8.4.0
http://peeplink.in/78ae2853e5b4
x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part1.rar.html
x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part2.rar.html
x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part3.rar.html
x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part4.rar.html
AlfaFile
https://alfafile.net/file/AFG3Z/x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part1.rar
https://alfafile.net/file/AFGLt/x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part2.rar
https://alfafile.net/file/AFGLM/x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part3.rar
https://alfafile.net/file/AFGLa/x7nya.Autodesk-3ds-Max-2026-3-with-Updated-Extensions.part4.rar
