04 de Abril de 2026, 22:47 *
Autor Tema: Performance Samples Solos of the Sea Solo Violin B KONTAKT  (Leído 70 veces)
« : 22 de Noviembre de 2025, 17:11 »
Free Download Performance Samples Solos of the Sea Solo Violin B KONTAKT | 491 Mb
Solos of the Sea - Solo Violin B is a very simple solo legato instrument. This library explores a fairly specific sound: a loud, ff-esque dynamic with heavily slurred legatos. You can trigger even more dramatic portamento legatos by playing hard velocities on certain idiomatic intervals. In addition, this release also has same-note bow-change repetition samples which can be triggered by repeating notes with the sustain pedal pressed down.
The library continues along the lines of the unfolding Con Moto series with 'active-bow' sustains and legatos recorded con moto (with motion). The latter is here expanded upon with a 'pitch-memory' adaptation, which helps minimize a musician's susceptibility to timbral variation between sustain and shorter legato assets.
•Solo violinist
•One dynamic layer (in the territory of ff)
•Slurred pitch-memory legato, recorded con moto (with movement in the bowing and vibrato)
•Dramatic portamento legato, triggered by playing velocity 100-127 on upwards-intervals of P4-P8
•Same-note bow-change repetitions, triggered by repeating notes with the sustain pedal pressed down
•"Active-bow" sustains (non-static longs that move and evolve while simultaneously maintaining the dynamic/timbre)
•Short, responsive release samples
•One mic position - recorded at a moderately close distance in a hall with a stereo pair
•48kHz / 24bit
•NCW-compressed, ~517.2 MB total
•Built for Kontakt 5.8.1 and above - full, retail version of Kontakt required
NOTE ON DELAY: this library has a moderately delayed response (140 ms) when playing, to further the musicality of the legatos. The library is heavily optimized for this delay amount. All the elements of the library (legatos, sustains, attacks, releases, etc) are on the same delay, which allow you to play in your parts, quantize them, set the track delay to -140 ms and have everything be on the beat.
home page
https://www.performancesamples.com/solos-of-the-sea-solo-violin-b
http://peeplink.in/22e0eeb18756
Pass UnLock: 123
Fileaxa
0zr3h.Performance.Samples.Solos.of.the.Sea.Solo.Violin.B.KONTAKT.rar
0zr3h.Performance.Samples.Solos.of.the.Sea.Solo.Violin.B.KONTAKT.rar.html
AlfaFile
https://alfafile.net/file/AFzHo/0zr3h.Performance.Samples.Solos.of.the.Sea.Solo.Violin.B.KONTAKT.rar
