Free Download 3Dsurvey 4.0.1 (x64) Multilingual Fast Links | 140.7 MB3Dsurvey 4.0.1 is a powerful land surveying and photogrammetry software designed to process aerial and ground imagery into professional mapping and 3D modeling outputs. With any standard digital camera or drone, you can generate orthophoto maps, 3D terrain models, DSM/DTM data, and perform fast volume calculations. The software uses advanced automated matching algorithms for accurate and efficient data processing.
Key Features• Works with any drone or digital camera, including DSLR and GoPro devices.
• Produces high-accuracy land surveying results such as orthophotos, point clouds, and 3D models.
• No flight log (.LOG) files required - simply import your images and start processing.
• Automated workflow speeds up terrain modeling, mapping, and measurement tasks.
• Developed using real data from over 300+ professional surveying projects.
What You Can Generate with 3Dsurvey• High-resolution orthophoto maps
• Digital Surface Models (DSM)
• Digital Terrain Models (DTM)
• 3D mesh and point cloud models
• Cut/Fill volume calculations for construction or mining
• Elevation profiles and contour lines
Why Choose 3Dsurvey?• Professional accuracy trusted by surveyors and engineers
• Easy-to-use interface suitable for all experience levels
• Efficient processing designed for real-world field conditions
• Affordable alternative to high-cost photogrammetry software
• Fast and stable even on large terrain datasets
System RequirementsOS: Windows 7, 8/8.1, 10, 11 (64-bit only)
CPU: Multi-core processor recommended
RAM: Minimum 8 GB (16 GB recommended)
GPU: Dedicated graphics card recommended
Storage: SSD recommended for faster data processing
Home Page Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorynov1.3Dsurvey.4.0.1.x64.Multilingual.rar.htmlDDownloadynov1.3Dsurvey.4.0.1.x64.Multilingual.rarFreeDLynov1.3Dsurvey.4.0.1.x64.Multilingual.rar.htmlAlfaFilehttps://alfafile.net/file/AFRaJ/ynov1.3Dsurvey.4.0.1.x64.Multilingual.rarLinks are Interchangeable - No Password - Single Extraction
