Free Download Craft Edge Sure Cuts A Lot Pro 6.079 Multilingual Fast Links | 86.6 Mb"Sure Cuts A Lot Pro" is an extremely easy program to allow you to cut virtually any shape with your electronic cutting machines, vinyl cutters and Descriptionters. Great for sign making, vinyl cutting, crafts and so much more. With the combination of using your fonts, importing custom artwork and drawing your own shapes, the possibilities are endless!
What's New in Version 6:
New effects added, including Cast Shadow, Monogram, Rays, Rhinestone Scatter.
More options to customize Rhinestone designs.
Create Data Source Copies, to easily replace text for different variations of the same design.
Set cut lines to be scored.
More options to choose, select and replace colors.
More path options to Divide overlapping shapes.
Convert square corners to rounded corners.
Text is now imported from SVG and PDF files.
Larger workspace area.
Generate bar codes.
Options to control the cut order.
Apple Silicon (M1,M2) Native Mac version.
and more!
Sure Cuts A Lot Pro supports a variety of electronic cutting machines:
Black Cat Cougar/Lynx
BossKut Gazelle
Brother ScanNCut (export as FCM compatible files only) *
Craftwell eCraft
CraftRobo
Cricut Air/Explore/Joy/Maker (export as SVG to upload into Design Space only) *
GCC
Graphtec
Foison
i-Craft
Ioline
Janome Artistic Edge
Jinka
KNK
Liyu
Mimaki
MyDigiDi
Pazzles Inspiration/Pro/Vue
PrismCut
Ramtin
Roland
Saga
Secabo
Seiki
Silhouette SD/CAMEO/Portrait/Curio
Silver Bullet
Siser Juliet/Romeo
SkyCut
StarCraft SOLO
Teneth
USCutter Copam/LaserPoint/MH/PCUT/SC/TC/TITAN
Vicsign
Vinyl Express
Wishblade
and more!
Pro Features
Extended cutting length to cut longer than 72 inches
Weeding options to easily add weeding boxes and lines
Tiling
Duplicate cutting
Cut by color
Color layer alignment
Print & Cut (Contour Cutting)*
3D shadow
Import DXF, PLT
Create bar codes
Assign cut presets to layers
System Requirements:Pentium processor-based PC or compatible computer
Windows XP SP3/Vista/7/8/10/11
512 MB of RAM or more
At least 50 MB of available hard disk space
USB Port 1.1 or 2.x
Home Page-http://www.craftedge.com/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator3kccn.Craft.Edge.Sure.Cuts.A.Lot.Pro.6.079.Multilingual.rar.htmlFreeDL3kccn.Craft.Edge.Sure.Cuts.A.Lot.Pro.6.079.Multilingual.rar.htmlLinks are Interchangeable - No Password - Single Extraction
