05 de Abril de 2026, 08:53 *
Autor Tema: CAMWorks 2025 SP4 for SolidWorks Win x64 Multilanguage  (Leído 116 veces)
« : 27 de Noviembre de 2025, 23:59 »
Free Download CAMWorks 2025 SP4 for SolidWorks | 2.0 Gb
Languages Supported: 中文 Simplified, 中文 Traditional, Français, Deutsch, Italiano, 日本語,
Polski, Português-Brazilian, Русский, Español, Türkçe, 한국어, Čeština
HCLSoftwarehas releasedHCL CAMWorks 2025 SP4is an intuitive, feature-based CAM software that helps to increase productivity using best-in-class technologies and adaptable automation tools to maximize CNC machining efficiency.
The release of CAMWorks 2025 introduces several innovative features and enhancements designed to streamline manufacturing processes and improve productivity. With compatibility updates, advanced simulation capabilities, and improved toolpath management, this version offers significant improvements for CAMWorks users. CAMWorks 2025 has strengthened its integration with SOLIDWORKS and the 3DEXPERIENCE platform. It now runs seamlessly as a Partner Gold Add-in within SOLIDWORKS applications, enhancing data management and collaboration in cloud environments. This update ensures a more cohesive workflow for users leveraging SOLIDWORKS and CAMWorks together. New simulation features provide users with greater control and precision.
Owner:HCL Technologies (HCL)
Product Name:CAMWorks
Version:2025 SP4
Supported Architectures:x64
Website Home Page :www.camworks.com
System Requirements:Windows *
Software Prerequisites:pre-installed SolidWorks 2024 - 2025
What' new in CAMWorks 2025 SP4
1. CWR-2175 CSR-25844 Toolpath For the Z-Level operations, contrary to Help documentation, the "Use Entry Holes" option remains available even when the Cut Type is set to Helical. Additionally, when set to Z-Level, selecting a hole center for lead-in fails to adjust the toolpath, resulting in gouging along the cylinder sidewall profile.
2. CW-139503 CSR-29232 Toolpath For the specific Mill part, the Curve feature is created from a sketch. The toolpath for the Contour Mill operation generated for this feature is incomplete and only displays the lead-in moves. However, the toolpaths for Contour Mill operations generated for Curve Feature created from edges or a Boss feature created from the same sketch are generated correctly.
3. CW-138104 CSR-28941 Toolpath For the specific Mill-Turn part, the toolpath fails to generate by assigning a specific tool from the front turret when a user-defined holder is assigned to that tool.
4. CW-137922 CSR-28873 Simulation For the specific Mill part's Contour Mill operation, Ramping is enabled and the toolpath Center is set to 'Without Compensation'. During simulation, the toolpath for this operation incorrectly displays the tool moving to the center of the part after each pattern instance. However, there is no error in the output posted code. Simulation is corrected if ramping is disabled.
5. CW-107778 CSR-15720 Toolpath For the specific Assembly file, the Contour Mill toolpath generated for a rest-machined Irregular Boss feature does not apply Leadin and Leadout moves on the second depth. The issue is observed when the 'Depth processing' is set to 'By region', while it works correctly when set to 'By level' or when Rest Machining is set to 'None'.
CAMWorks for SOLIDWORKSwas the first fully integrated computer-aided manufacturing (CAM) solution designed exclusively to operate in SOLIDWORKS and the first to offer knowledge-based, feature recognition, and associative machining capabilities within SOLIDWORKS. CAMWorks uses the same SOLIDWORKS geometry to generate toolpaths to ensure the part you machine is the same part you've modeled. Toolpath simulation allows users to compare "as designed" parts to "as machined" parts. The part model-to-toolpath associativity in CAMWorks increases machining productivity and lowers manufacturing costs by eliminating time-consuming CAM system rework due to design updates. CAMWorks eliminates the drudgery of CNC programming with Intelligent Machining through automation. Pioneered by Geometric Technologies, this suite of tools automates the generation of toolpaths based on a knowledge-based database. It eliminates hours of complex programming through Automatic Feature Recognition (AFR) that automatically defines prismatic machinable features, while the TechDBTM (Technology Database) defines machining operations to automatically generate accurate toolpaths at the click of a button. CAMWorks machining modules include: 2½ Axis Mill, 3 Axis Mill, Turning, Mill-Turn with 5 Axis Simultaneous Machining Support, 4/5 Axis Simultaneous Machining, and Wire EDM.
CAMWorks and SOLIDWORKS CAM - Adding Interactive Features
Learn the definition and differences between features and how to create and modify them in CAMWorks.  Quick Tip presented by Kregg Egan of GoEngineer.
HCLSoftwareis a division of HCL Technologies (HCL) that operates its primary software business. We develop, market, sell, and support over 30 product families in the areas of Customer Experience, Digital Solutions, Secure DevOps, Security & Automation.
i7xmw.CAMWorks.2025.SP4.for.SolidWorks.rar.html
Fileaxa
AlfaFile
https://alfafile.net/file/AFNM4/i7xmw.CAMWorks.2025.SP4.for.SolidWorks.rar
https://turbobit.net/3uf2a0t2o9il/i7xmw.CAMWorks.2025.SP4.for.SolidWorks.rar.html
